I’m in the same ‘boat’ - placed an order but haven’t yet been able to figure out a good way to forward a payment from here. They did get back to me by email. Great looking product.
Tim Moore
Perfect is the enemy of good
In progress
DH.9a Ninak, 1/32, Wingnut Wings
Docked for Repairs
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
The Blue Sky Company, 1:48, Sierra West Models
Completed
Triumph 3HW, 1/9, Italeri; Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
had a similar experience. I paid the amount stated in initial email by paypal, then didn't hear anything for a couple of weeks. Then got a shipping notification and can now see package moving on tracking.
Pretty understandable that communications are a bit disjointed considering situation in Ukraine and incredible that their managing to run a business at all under circumstances.
Matt
Current Builds
HMS Winchelsea by Mnewsholme
Duchess of Kingston by Mnewsholme Vanguard models 1:64
 Previous Builds
Lady Eleanor Vanguard models 1:64 completed
Ok, my kit arrived on December 27th. I’m not going to post an un-boxing, James h did an excellent job of that.
so far, I’ve read through the instructions and plans a couple of times. I will do that a couple of more times before I start with unpacking and identifying the parts.
I became ill over Christmas and am still recuperating. I plan to take this one slow and easy. I still have to figure out how to upload pictures.
I hope you start feeling better Jerry.  When you're ready to start building, just add to this topic.  It should be an interesting project.
CDC1FF06-DB44-4132-98B2-80F406E425BA.thumb.jpeg.98e18fe720287dcfd939e210fe401942.jpegOk, the fun has begun!
my plan was to just spend an hour and knock out page 1
That isn’t how it worked out!
it turns out that MDF is really dense stuff. I couldn’t get the scalpel to cut along the lines. The blade stuck and jumped the track even using light pressure.820151F8-47E3-4E11-AC76-593C3A148AF5.thumb.jpeg.5f4dec3014b479eba4727582c81f8e10.jpegmaybe a new blade? Not so easy , same results.
 I wound up just pressing the parts out with steady pressure.1EE17385-262F-4474-A605-4AC8DADA549F.thumb.jpeg.06b1121498131d367b185b47573f6504.jpegthen the fun began. It took a lot of sanding and scraping to get the parts to fit. For the most part, the tabs are a little longer than the slots. C6C14196-5E37-425A-9E3A-53BCD993EA71.thumb.jpeg.136921923f5d3d8be86b4a09379afaf1.jpega lot of dry fitting than adjustment, then dry fitting.
the instructions suggest that you place the first former into the base, add the support pieces, then place the other former. I couldn’t see that working out, so I assembled the two formers with the support pieces and then fitted that assembly to the base.
all in a days workCDC1FF06-DB44-4132-98B2-80F406E425BA.thumb.jpeg.98e18fe720287dcfd939e210fe401942.jpegB5CC0CB5-0262-452E-89A1-DFC49929C7EA.thumb.jpeg.4f642870dff32d46908bc3cbb2a27741.jpegit was more work than I expected, but I like the results. It was good to get a feel for the components, and I’m looking forward to the next steps.
not looking forward to scraping and sanding laser char. The parts so far feel substantial and strong, but once the jigs are done and I get into frames and such, I’m worried about snapping pieces. I think I’ll spend some time over the next few days gluing sandpaper to a bunch of different shaped sticks.
Ok, todays agenda, continue assembling the jig.D6FDB869-942E-4981-A279-FB7EFA1DB76F.thumb.jpeg.5c58936a0130b6b5a6150f206ec92549.jpegthe parts for today all punched out. It’s getting easier402E43C3-50BA-400E-93B6-D8D8E4FE32B6.thumb.jpeg.8d1aca965ea910bb5bf89d766fa18d67.jpegAfter much filing and sanding, it all fits together.FB9550B6-E21C-4F90-8E35-EC18414E07B1.thumb.jpeg.6efa67d95688d590206b9d91b172b133.jpegjust four extraneous parts left over. Now just need to disassemble it and add glue.
looks just like the picture!
Edited by JerryC
Delete dupes
2 hours ago, JerryC said:
I’m getting some extra photos somehow.
Jerry,
Start with checking your uploads -- looks like one photo has been added three times -- then delete the extra copies. You might end up deleting the one  photo from the trio that is inserted in the text; if that happens, just re-insert the remaining photo.
11 minutes ago, JerryC said:
Chris, where can I access the uploads?
Start by clicking the three dots in the upper right corner, then select 'edit' from the drop-down menu.
A tray containing your uploaded images will appear beneath the editing window. Click the 'x' on any photos you wish to delete.
AEAE6AE7-2C1A-4670-A0E9-6F7009F1236F.thumb.jpeg.08a9bd6f7d42b9081fbae36161002596.jpegSo, I’m a little stuck right now. I’m waiting on delivery of an inexpensive set of Jewelers files from Esslingler. They should arrive on Monday. They shipped the same day as ordered. I’m expecting that they will be helpful for removing char from the frame pieces and such.
also, I’m at page 7 of the instruction manual and have no idea what I’m supposed to do. I get the frame part on the bottom, but what’s the upper frame illustration trying to tell me? I think it’s just saying that I will be assembling frames using glue.
the framing diagram shows you which way round the frames go. The little chisel in a circle symbol means you need to bevel the edges of the frames. on the frames closest to bow and stern you will see a line etched on the wood on one side.
You file each of the steps at an angle from the unmarked edge on one face down to the etched line on the opposite face. This creates the angle for the planks to flow correctly. Effectively your fairing the frames before you assemble them into the jig. The etched lines on the pieces need to face down from frames at one end ( frames 6-3) and face up for frames at other end frmaes 19-22).
From memory a couple of the frames have the L and R labelling transposed., s you need to fit the pieces the opposite way round to get the etched face facing the right way.
Matt
Current Builds
 Previous Builds
Wouldn't it be better to fair the frames after assembly?  That way you can ensure an even fair where the futtocks overlap.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
So, a little progress was made today.5CAA50A1-4766-49F2-BA80-182B40D80899.thumb.jpeg.7cec605c5e86c2bfba832f640222df27.jpeggot a nice set of small files. Some of the ferrules are not well fastened. The files work well though. Next time I mix a up a batch of epoxy I’ll take care of that.EF67F989-F2E5-4EB9-9930-739608031D4B.thumb.jpeg.00fe18c4b43837b998a9ee9ea9161acf.jpeggot the keel glued up and fixed in the jig. There was a little adjustment needed for it to fit nicely.F516CBBC-19E0-40AE-8880-EE099FEB0071.thumb.jpeg.2f7ef6de962abf2069ccc2789471bb6c.jpegI got six of the frames worked up. A430E707-9114-4041-8532-088183661EFC.thumb.jpeg.2f102b12ab543a855afed7c6ea3ae1b3.jpeg
When you start adding frames to the keel check that they seat down fully. I found the keel sat too low in the jig to allow this. I glued a 1mm strip to the jig (NOT to the keel) to raise the keel up slightly to allow frames to seat correctly.
Matt
Current Builds
 Previous Builds
CE36DC0E-64E4-4C1B-B2E4-7A2E1A61E10E.thumb.jpeg.87d368629051e7f41e758b1ce5e1909c.jpeghere’s what I’m using to sort the frames.
 I punch out a piece and stick it in the binder clip.
then I use the plastic sanding stick to remove the char.
the files come in handy for small spaces where necessary.
I’ve got lucky thirteen done, enough for today! Tedious.
