Post 23
Completing the boarding.
The outer boards, one each side are a construction of two 1/32nd strips, one atop the other leaving a rabbet on the outer side.
As with the wide boards I opted to glue the base layer first followed by the top layer.
0071
There was a degree of fettlin’ to get the planks tight against the broad planks, and an even rabbet along the outer side.
The nail positions were marked with the top planks in situ and removed for the drilling and ‘nail’ insertion.
0076
0075
On completion a coat of w-o-p was applied.
Moving onto the platforms.
B.E.
05/06/2024
Post 24
Platforms.
After a break in Devonshire and taking advantage of recent fine warm weather to work in the garden, I return to the Longboat build.
Has it really been a month, better crack on.
Fore and aft platforms are now to be fitted.
Aft Platform
Initial assembly is quite straightforward, it’s the notching to fit over the frames that is the tricky part.
0086
I followed the sensible approach of using card templates to mark the notches to fit over the frames before committing to the real thing.
Even so, fine tuning the notching proved to be a frustrating business.
Chuck indicates that the platform should be ‘pretty low’ on the model, but how low is low?
0083
I made a simple height jig from the plan to gauge where the forward edge of the platform sat above the floorboards, and notched away until I got close to the level.
0088
2479a
0093
For me this involved cutting notches somewhat deeper than the  guide photos indicated.
0087
I hadn’t otherwise modified the boards at this point which seem to finish at the forward edge of frame seven from aft. Mine extended beyond frame 7 with a complete notch.
One final puzzlement I had with the platform was the nailing pattern.
platform.thumb.jpg.d1f7b7744f1b809f8e8d31eb3ae10936.jpg.602ab358f41a3766ec7d0b68db61d3ed.jpg
There are five rows of nails running across the planks, but to secure to what? There are no corresponding supports below these points.
Chuck has indicated the use of three random beams across the underside to secure the boards and provide lateral support but they bear no relation to the nail runs except perhaps for the  fore-most one beneath the front edge.
0090
In terms of a fully planked version this has little relevance but for the open framed version what lies beneath is open to scrutiny, not a good look I think.
As the frames drop away from the boards with their ‘V’ shape, a more logical approach would seems to be to have support beams holding the planks together either in line with the frames or between them.
I think I need to change this.
B.E.
10/07/2024
The nails appear to be just in front of or just behind the frames. The most logical answer to me seems that you add some cross beams secured to the side of the frames right below where the nail patterns would be. This makes intuitive sense as the platform has to be secured to something and that something really should be secured to the frames.
Great work as allways.
Edited by Thukydides
Nice job getting those notches done, BE. That was a tricky step for me as well.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Daniel, I obviously didn’t have my old brain in gear when I followed Chuck’s lead which is directed towards a fully planked hull, where such details don’t matter.
What I don’t know is how permanent these platforms were. Could they be removeable for access to the space below, merely slotting into place between the frames, even fitted in two halves?
Either way, I will replace the random supporting boards with specific support beams which match the nail runs and hopefully look aesthetically better from beneath.
Regards,
B.E.
Post 25
Platforms continued
Modification of the aft platform has been made.
0095
The forward end has been trimmed to create a half notch and  support beams added to fit adjacent to the aft sides of the boat framing.
0096
For these I use 3.3 x1.3mm strip that I just happened to have in stock.
Each beam was pva’d into place and the nail points marked.
0111
Using 10lb fishing line the ‘nails’ are inserted, secured with pva.
0125
0124
0113
0116
0118
Regardless of any authenticity aspects I think the underside now looks acceptable.
Still some finishing off to do but I’ll complete the bow platform first.
B.E.
12/07/2024
Post 26
Bow Platform
To make this platform, as suggested by Chuck you really need to start with a card template.
The pattern of this platform is oversize so won’t conveniently fit between the forward frames to get a start with the notch for the bow stem.
I found it necessary to indulge in a little origami to achieve the result.
0109
The pattern is folded in half and the notches marked and cut out on one side and when flattened out should fit across the board.
The platform has to sit low down, a mere 16mm or so above the footwaling.
0098
I again used a height gauge to check the correct level of the platform.
0097
By these means I was able to get a reasonably close fit at the right level.
Not out of the woods yet, with an open framed model there is no defining outer planking to guide the internal fitting.
0130
I used Tamiya tape to give a guide for the missing planking, to aid the platform final shaping.
0134
0136
0132
This shows the variation necessary to the basic wooden platform. (My build only, other builds may vary)
IMGP0137.thumb.JPG.eec7a63e6fb77d5905f309676a97f79b.JPG0137
0138
0148
Supporting beams were added as with the aft platform.
0143
I have not applied w-o-p at this point or fixed the platforms in place. I’m not even sure if I need to, the platforms are a nice snug fit.
B.E.
13/07/2024
7 hours ago, Blue Ensign said:
Post 26
Bow Platform
0109
0098
0097
0130
0134
0136
0132
0138
0148
0143
B.E.
13/07/2024
Looks very good.  I seem to remember I tried 4 or 5 times to get a front Platform that I was happy with
Thank you Diver, I had more than a couple of card template goes to get the pattern that fitted.
You will see that I have deviated from the  kit pattern for the bow platform by notching it into the bow stem, which was a good fit for my particular version.
The contemporary model of the Longboat, seems to have a different set-up around the inner stem and framing, with two platform notches before the stem, but there is no really clear photo of this area.
Cheers,
B.E.
Post 27
Installing the Risers.
This is always a tricky area; getting the risers at the correct height and ensuring that the thwarts sit level and square across the boat.
0173
Careful measuring is required and as with my Queen Anne Barge build I used a simple depth gauge to mark the positions at each frame along the hull.
There is a degree of sheer to the risers and the position does vary slightly along the hull.
Before I commit to glue I do a lot of dry fitting.
0177
0171
0169
This extends to making up dummy thwarts to check the alignment.
At near midships the thwart sits 32mm above the footwaling.
This equates to 30” at full scale.
The thwart above the aft platform is 20mm equating to 19”
 In modern parlance this is about the difference between a desktop and a chair.
 The dummy thwarts  allow me to use my ½” scale rower to check relative heights.
The 1:24 scale figure at 70mm represents a figure of 5’6” height.
0153
0158
Something looks a little awry here, there seems a very long drop to the footwaling.
0151
0165
Except that is for the stern sheet section, where the fit is spot on.
The thwarts can’t be any lower because that would throw out the angle for the rowing action.
The conundrum is that the same figure used on the 1/2” scale Royal barge model fits well for a realistic rowing position.
01712(2)
01713
Note the stretchers sitting above the bottom boards.
02526
Royal Barge seating.
Unlike the Royal Barge, there are no stretchers fitted to brace the rower’s feet. I don’t recall seeing stretchers or cleats on the bottom boards of 18thc boats.
0163
Even so he does look somewhat incongruous sitting there.
Fortunately, I’m not thinking of crewing this model so the disparity will not be apparent.
On with the show.
B.E.
16/07/2024
Post 28
Risers fitted
Before gluing the risers I followed Chuck’s lead by applying the ‘nail’ heads using 10lb fishing line.
0179
I double checked the fixing marks before committing to glue and completed the Starboard side first.
0177
The port side rear riser was then clamped into place and the temporary thwarts used to confirm level and squareness.
0181
Moving onto the forward section riser on the port side.
0182
Multiple checks and re-checks are made to ensure that the thwarts are level.
0185
The temporary thwarts are used to confirm the levels at each point.
I use the Proxxon vice to support hull and get a true level, and tweak as necessary.
0205
Forward portside risers glued into place, always relieved when this part is over.
0196
0207
Moving onto the thwarts proper.
B.E.
19/07/2024
Post 29
Mouldings and friezes
I was going to move onto fitting the thwarts but decided this was a better stage to fit the friezes and fancy moulding.
0220
The paintwork of the cap rails was firstly re-done and the outer edges cleaned up.
The decoration which follows the contemporary model of the Medway Longboat 1742, is probably an artistic embellishment.
It is unlikely that a heavy workhorse boat would in reality have such fancy work, although she may well have had a plain painted topside and stern panel.
Still, it makes for a nice enhancement on the model.
0217
Before cutting out the frieze patterns, they were sprayed with Artist’s fixative. This also brings out the colour a little.
0219
0221
The friezes were applied using slightly diluted pva.
No issues in fitting, if only I could say the same for the Transom.
1721807503072-176665e2-b36a-41c8-845a-5b264e5287d9_1.jpg.5f2589effcbde7bfcff3c2bc679fc504.jpg
Chuck has provided several slightly differing transom patterns to hopefully give a little leeway to compensate for slightly differing stern shapes.
NMM Fully planked Medway Longboat
The idea is that an evenly sized border is created around the pattern, formed by the hull planking at the lower end.
NMM in frame Medway Longboat
On this contemporary model the margin is apparent at the lower end of the transom where one otherwise might expect the planking alone to form that border.
None of the provided kit patterns were a good fit for my stern so I converted the pdf to jpg and tweaked it by degrees on a word doc to create an acceptable fit.
0248
I followed the contemporary model by trimming the lower part to show a margin on the lower transom. I thought this was aesthetically more appealing.
Decorative strip.
The makings are provided in the form of Boxwood strip.
I scribed a simple moulding using the Artesania Latina micro shaper set.
0211
One of the profiles is similar to the style used by Chuck; a 3mm x 1mm profile which fitted the strip.
It requires 4 strips to complete the moulding run. I made the joins around 2/3rd along the hull from the bow.
The forward section required edge bending to facilitate the round of the bow and a touch of lateral bending to take the spring out of the strip.
0230
The moulding is clamped to the hull and given the heat treatment to further assist the fit.
0238
I used spots of ca to attach the moulding to the hull. Care must be taken to avoid any spread particularly onto the frieze work.
0252
0251
0249
I can now clean up the outer planking and apply w-o-p.
I think w-o-p can also be applied over both the friezes and stern panel to further protect them.
B.E.
25/07/2024
Post 30
Thwarts ‘n all.
The next stage is fitting the thwarts, pre-cut in cedar and formed of two layers to create a reveal on the thwart edges.
0266
Five of the thwarts require notching to fit over the frames and sit cleanly close to the run of the hull planking.
0267
At this point I have also started to add paint to the cockpit area.
0268
0270
0271
Fairly straightforward with careful measuring, but I did use ‘false’ thwarts  as templates.
I am satisfied that nothing untoward catches my eye in either level or squareness.
0269
Nothing is fixed at this point and the thwarts have yet to be  given the w-o-p treatment.
B.E.
29/07/2024
Post 31
Cockpit benches
I found fitting the side benches of the cockpit somewhat tricky, and they took quite a bit of fettling.
0257
There is a lot of tweaking to get an acceptable fit.
0265
Several coats of paint were applied to the benches prior to fitting, but final coats will be applied once fitted.
I couldn’t quite manage to get the aft end as close to the hull planking as I would have liked, but you reach the point of how much is too much, with the risk of taking it that one step too far and scrapping the whole piece.
It is perhaps fortunate that this area is painted, as it allowed me to take a few liberties that otherwise wouldn’t have been an option.
0282
Side benches fitted and further coats of paint applied. The added support tabs for the central seat can be seen at the aft ends.
0285
The central panel has been fitted atop the stern post, and here the transom knees are tested for fit.
I found it necessary to add small sections of wood to the knee ends to give a tight fit against the central panel.
0287
The final piece is the centre seat, this required a little tweaking to get a nice tight fit between the side benches.
0289
Additional coats of paint added, rubbed down with 1000 grit paper. The final coat will be applied once the whole area is complete.
0292
0293
0297
0298
0299
Starting to look like a Longboat now I think, the thwarts will be removed for the next interesting little construction.
B.E.
01/08/2024
Post 32
Windlass
One of the most striking features of a Longboat is the Windlass, used for anchor handling.
0121
These can be tricky to make from scratch but Chuck has thoughtfully provided templates to set out the octagonal barrel of the piece.
0125
Cedar wood is provided for the makings, and early stages went well.
0132
I found it difficult to get clean square holes for the windlass bars. Repeated fiddling made the situation worse, and it all ended up like a dogs breakfast. As a significant feature I had no option but to reject it.
Version two
This time I went for Boxwood, being a harder wood I was content that it would hold a sharper edge and cleaner cuts.
0133
I was fortunate to have some very old English Boxwood of 10mm square section.
0135
Planed up, this wood is a joy to work with.
0136
0138
I used a No11 scalpel blade to cut the octagons, and a 3mm micro chisel to form the windlass bar mortises.
0145
To finish the windlass small spindles are created at the ends which are rounded.
0140
The windlass brackets are pre- formed and only require the addition of ‘nails’. They sit level with the underside of the adjacent thwarts and are fixed directly to the risers.
0141
I use a section of dowel to check the alignment before the glue set.
0149
Not given the w-o-p treatment at this point.
0150
0153
Satisfied I can now move on.
B.E.
11/08/2024
Fantastic work BE.
I do have a question on the windlass. Were these on all longboats or only the larger ones?
Thank you Daniel,
Brian Lavery, Arming and fitting of English Ships of War  writes that Longboats were equipped with a windlass, as did the Launch that largely superseded it.
Whatever size of the ship the Longboat was the heavy work horse required to  carry the kedge and stream anchors, and lift the cables of  the main anchors.
It is difficult to say whether  the smallest Longboats (19' - 21' ) were fitted with a windlass, but the Medway Longboat according to  W.E. May, scaled to a 28' boat and clearly had a windlass.
Vanguard don't have a Longboat in their ships boats line- up, but in terms of modelling I would always include one, if for no other reason that they are an interesting fitting.
Always more questions than answers, Daniel.
Regards,
B.E.
Edited by Blue Ensign
Post 33
Finishing the mast thwart
This particular thwart has supporting braces for the Mainmast.
The kit supplies brass strip, to be drilled, shaped, blackened, and glued and pinned into place.
0169
0181
0174
I use a mast jig to form the clamp shape which is held in position by the thwart straps.
0183
0193
Once satisfied the parts are chemically blackened.
The straps are not glued into place, held simply by cut off brass pins smeared with ca.
There are also four belay pins made from some Boxwood strip.
02625a
These are chucked in the Proxxon mini drill for shaping.
02607a
02616a
0216
Delicate hands required for this task, seven started, five completed, but a morning’s work and it’s done.
0220
0219
0218
0223
0226
The thwarts will not be glued into place until I have finished  with the construction work, and completed the w-o-p finish.
B.E.
13/08/2024
I’m enjoying your rake on this great model.  It’s up next for me after Winchelsea.  Boxwood for the windlass is an excellent choice.
Regards,
Glenn
Current Build: HM Flirt
Thank you Glenn,  I understand why Chuck included Cedar for the Windlass, a 10mm square section of Boxwood would be far more expensive.
It is a preferable wood tho' if you can get it, and I quite like the colour shade difference for this fitting.
@ Cisco -   I use stuff called Carr's Metal Black for Brass, diluted with distilled water 50%.
                   The brass is  cleaned using fine steel wool, and a mild acid solution, before immersion for  a minute or so.
                   I then buff it using a cotton bud.
                   It took well the first time, but I gave it a second immersion  to deepen the tone.
                   I think the main thing is making sure the brass is perfectly clean before starting the process.
Regards,
B.E.
Most of the Winchelsea parts that must hold an edge like pillars, moulding, etc. are provided in boxwood. I love AYC, but as you note the boxwood is both critical where an edge is needed and provides a nice accent.
Regards,
Glenn
Post 34
The Rudder
A Cedar blank is supplied but requires some tapering fore to aft and shaping to get it to the finished article.
The precise degree of taper is not covered in the guide, but the rudder piece is 4mm thick overall, and I am initially working to a 2mm thickness at the aft edge.
 Chuck’s rudder dimensions are a close fit to Steel, who for a 30’ Longboat circa 1800 gives the following.
Breadth at heel.    1’10”  - at scale =23.3mm
Breadth at Hance. 1’3½” - at scale =16.4mm
Breadth at head.     8½”-  at scale =9.0mm
The thickness of the rudder is given as 1½” but doesn’t say at what point, I have taken it to be the aft edge.
0227
To this end I temporarily fix a 2mm Pear strip to guide the taper.
0230
Gudgeons and Pintles.
I have always been a fan of Chuck’s rudder fixings, and this is no exception.
A neat if delicate little Boxwood set is provided.
The standard setting for rudder set up on boats is a long lower pintle on the sternpost, with a long-braced gudgeon on the rudder.
The upper set are reversed with a gudgeon fixed to the transom, and a short pintle to the rudder.
This set-up facilitates easier removal and replacement of the rudder at sea, where it may need to be removed during anchor handling operations.
Before I attached the fittings, I dry fitted them to make sure that the pintles would easily and properly engage.
The trickiest part is fixing the Transom Gudgeon in position which is glued over the decorative pattern. As little movement as possible is desirable to avoid marring the decoration.
0233
My approach was to fix the lower pintle first on the sternpost, followed by the rudder fixing.
0236
The Gudgeon for the transom was then placed in position on the upper rudder pintle, held in place by tape.
A smear of Ca was applied to the inner face of the Gudgeon, and having set the lower rudder gudgeon on the pintle the rudder was pressed into place keeping it vertical.
0269
With ca the set is quick, and the rudder can be removed leaving the transom Gudgeon in place.
Tiller
This is cut from a 2.5mm square Boxwood section.
0239
I couldn’t be bothered to get the large woodturning lathe out;  this Heath Robinson set-up worked perfectly well for the size of the turning.
0242
0245
The tiller has a circular tenon shaped on the inner end.
0274
A Mortise is cut in the rudder to take the Tiller.
This is of a 2mm ø
Rudder finish
0303
The straps are thinned down on rudder and hull and fine brass pins used to represent the bolts.
0295
0302
The final part is to add the small decorations to the rudder head.
I found these tricky little beggars to get a clean oval shape, and had several goes at it.
0311
I found that small, curved nail scissors worked best for me.
0328
0333
Moving on….
B.E.
17/08/2024
