Going a little off from the directions and instead of doing one side of the deck at a time I first glued both halves together and lightly sanded the seams then I glued the whole decking to the frames and spine a little tricky but got it done. I did put a dowel in the mast hole while installing decking!,
Edited by JoeMacD
Joe, if you are copying and pasting text from another forum, selecting the "paste as plain text" option will eliminate the tan highlighting in your posts.
Great start on a fun build, Joe!  One recommendation might be to paint/stain some of these areas early on, as they will get hidden as you continue to progress through your build and may be hard to reach after a while.  Looking forward to see your progress on this one!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Really nice work
Armed Virginia Sloop - Model Shipways - 1:96                                      Muscongus Bay Lobster Smack - Model Shipways - 1:24
Phantom New York Pilot Boat - Model Shipways - 1:96                         18th Century Long Boat - Model Shipways - 1:48
        Norwegian Sailing Pram - Model Shipways - 1:12
        Lowell Grand Banks Dory - Model Shipways - 1:24
Nice looking build.  Jumping on the train to follow this.
Robert Chenoweth
In the research department:
Nothing at this time.
 I recently bought the holding clamp from harbor freight and works great for me intended purposes!
I then drew out the waterline with the included device.
 I then installed the block and bar into the deck. Working on mast boom and gaff now.
Edited by JoeMacD
Here is some of the mast work, getting closer, I’ll install it after I paint the hull! B1A44FE5-0F3F-461F-A5CE-529BE321EFB5.thumb.jpeg.018d24d86fefd20d604544767c3942b9.jpeg
It took me 3 attempts but 3rd time is a charm!😊 The 2 on the right were a bit anorexic!  😩
The top of the main mast!
 I also started shaping the Boom and Gaff
I glued in the tiller
I painted the trail boards with semi-gloss tamiya black th
en glued them to the boats beak!
I then carefully cut and glued the scrolling from instruction sheet and then glued it to the trail boards, I also used a black sharpie to blacken the white from the paper, I will later seal it with a semi gloss varnish,
I then glued the bowsprit to the boat!
I then made and installed the chain plates for the backstays!
I then made and soldered the masthoops
they will be cleaned up and painted!
Edited by JoeMacD
Looking great, Joe!
Gregg
Tonight I installed the STAYS, the Bob stay, Fore stay, and the Back stays and made lashings to the turnbuckles!
I’m wondering exactly what color should I use on the turnbuckles that would closely resemble the real ones?
Input on this appreciated! please!
Edited by JoeMacD
1 hour ago, Roger Pellett said:
If this is a working craft then rigging hardware including turnbuckles would be galvanized steel; a dull grey.
Yes thank you for your input very much appreciated! I never knew that they are Galvanized steel Taking artistic license I painted them Floquil enamel Bronze,
