7 hours ago, Jim Lad said:
She's really coming along, Nils.
John
Many thanks John
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Zappto,
thanks for your kind word, and yes, I intend to do a glass cabinet after it is completed
Nils
Current builds
-Lightship Elbe 1
Completed
Update
made all 4 Davits and am starting with the supportframe  of the front boatsdeck....
Nils
Stb side view of the old steamer of 1918 build
the threaded  rods M1,6 go through the mini spacer-squaretubes. They will also also support the bridgedeck. The angle profile 4x4 will take up the front portion of the boatsdeck
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Thank you for your nice comment John,
I still have some 3 sheave blocks (4mm) and wanted to use these for hanging the boats under the davits. I had ordered some 0,5mm Polyester rope to keep things halfway in scale, with a slight bit of widening the sheave holes with a 0,6mm drill its still a tricky job, but I think it works ....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you ver much Gary,
I`ve just made the stiffening out truss bars for the two outer bridge deck supports, its been a little tricky soldering and the drilling of the tiny pivot holes in the connection rods ....
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks John,
here is the outlook in the crow`s nest ....
with mast ladder, because there will be no ratlines to the shrouds, and access (with handrail) from outside the lookout post
Current builds
-Lightship Elbe 1
Completed
Update
here is the current state of progress, am starting with the rigging .....
Nils
the funnel will be made from this 1 inch OD brass tube
Current builds
-Lightship Elbe 1
Completed
Thank you for your nice comment Rick
Nils
Current builds
-Lightship Elbe 1
Completed
Just found your build Nils. Great job on John Wayne's steamer. I loved that movie and look forward to your build. BTW, in your photos the ship looks much larger than what I would suspect HO gage was. Seems you are emulating Wefalk with the miniatures. Good work.
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Many thanks Ras and John,
Ras,
Thanks for your interest and for having an intensive look into the log.
It seems a bit large at first look, but the base ship without the later look in the movie is the former laker steamer Corsicana and the rating for the model is exactly 1:87
The lines and frames are adapted from the Ferris type freighter of the US-Emergency fleet.
I found a Polish sychronised version of "The Sea Chase" on the web and made  the stand-pics from the video as needed for the details.
John,
you have a good eye, and yes, as the cargo derricks are made from brass tube, they are open at the ends. Thanks for the tip, I`ll have them closed later on.
Nils
Current builds
-Lightship Elbe 1
Completed
Update
have been working on the boatsdeck, the frontportion only gets a wooden planking as well as the bridgedeck later on
dryfit of the boat in the davits
hard to believe that this is going to be part of the boatsdeck. Led weights and clamps keep the deck down as the CA cures out
the port staircase to the boatsdeck
this is my 1:1 workscetch for doing and fitting out the boatsdeck
here something bad happened, I painted parts after soldering the railing to the supports and the paint came off. I should have cleaned the surfaces better before painting. Will now have to carefully remove paint with Dremel brass-wirebrush or so...., and paint new
Current builds
-Lightship Elbe 1
Completed
thanks John,
the large weight is an appr. 3Kg cast lead with cutouts to inbord stradle the deepest hull frames for my schooner "America". Built as a large sailing model for RC and allthough a lightweight design this inbord-weight was required for sailing the ship, it was too heavy so that the hull sunk a bit deeper in than the intended construction waterline. That model was put on hold since then, and the hull was sold inbetween to an other modeler. Never saw nor heared about it again.
Nils
CIMG8189.thumb.JPG.b7131e618fda8ae367025ffb2d8d40b6.jpg.b925952619b51957df6aa7c13c2efef3.jpg
CIMG8188.thumb.JPG.e7e9aa41ff5f3d289dd012bcfd6aa90d.jpg.5238986d98c2e5915d16e1ed3b2ab5b4.jpg
Current builds
-Lightship Elbe 1
Completed
Update
starting with superstructure, officers quaters, mess-room, wheelhouse, bridge and coverplanks for holds...
Nils
parts cut from 2mm multilayer ply
the windowframes will be from sliced brass squaretube and the windows from squarebar silicone, fiiting into the squaretube bits, Doors will be glued to the sidewalls in appropriate places
 the hold covers are from exact fitting 2 x 15mm  stained
pine planks
Current builds
-Lightship Elbe 1
Completed
many thanks John
Nils
Current builds
-Lightship Elbe 1
Completed
thank you very much Rick,
I`m pleased that the intended "glassing" works out for the wheelhouse windows, here in dryfit the first 4 silicone pannels have been pushed into the frames, but the wheelhose cabin will be painted first before final assembly
Nils
"panes" pushed in so far that there is a little back-step to the outside frame frontside
Current builds
-Lightship Elbe 1
Completed
thank you John, I`m pleased you like it
Nils
Current builds
-Lightship Elbe 1
Completed
Update
made aft railing of boots deck and card template of the bridge deck, also dry fit of the stairways to the bridge deck
Nils
front and aft-railings for boots deck
stairways to the bridge deck and card bridge template ( the bridge deck will have a planking). The funnel is not shortend to right length yet
aft view to mid section
poop with emergency rudder kinematic gear housing and rudderchain guides
the rudderchains fit along side the aft hold hatches. The support on the poop is for the long aft load derricks
3 sheave blocks for the boots davits
wheelhouse on the card bridge-template
Current builds
-Lightship Elbe 1
Completed
