3 minutes ago, iMustBeCrazy said:
This gives a fairly clear example:
Thanks Craig @iMustBeCrazy that as you say gives a clear example, what a fantastic resource RMG is.
so now I have a couple of names, channel is the block of wood, chainplate is the metal strip. Is that correct?
Now I am thinking I will make mine like this, with a planted strip on the outside.
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
Lets just say the chainplate is metal, it can be a flat bar, a few flat bars, a chain, a really long chain link or a combination.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
here is yet another revision of the chains mockup
I have tried to incorporate the advice you have all given.
Tim
Current Builds :
Found one.
And the channel should follow the deck and or wale. That is, lower forward.
Edited by iMustBeCrazy
Craig.
Tim,
If you haven't this book, it's worth consiidering.   There are some errors but it' does provide a good overview.     zu Mondeld's Historic Ship Models.  Online sources are pretty varied as to content and explanations but zu Mondfeld will get you started.
Another thing I was not really aware of.
Current Builds :
Thanks Mark @mtaylor, I happen to have purchased a copy from the famous Booths bookshop in Hay-on-Wye last summer. I often go there as it's only 40 mins down the road. I paid £5 which was a bargain looking at the prices online.
Now I have some non fiction bedtime reading.
Tim
Current Builds :
10 hours ago, druxey said:
Spacing looks realistic now
Thanks @druxey and I will make sure to follow the line of planking.
Tim
Current Builds :
Managed to get some good work done over the last two days.
working from  Bills booklet
Bulwarks lined, spirketting in place on both sides
now I need to cut away the gun ports, line them and add the waterway fillet
Tim
Current Builds :
Probably too late but the sides of the ports are perpendicular to the keel and the top and bottom are parallel to the deck.
Craig.
Hi Craig @iMustBeCrazy
Not sure which you mean here?
I have got it wrong or they are correct?
I did make them as per the drawings ( yes I know they are in the wrong place  😞 ) and they are trapezoid in shape.
It could be the angle of the photo. You can see it better in the photo in post  #123
On a different topic
Seeing it coming together I do think that the all pale wood is a bit too bland and needs some variation, so I need to do staining. as was discussed earlier.
Tim
Edited by oakheart
Current Builds :
Just one of those learning things. With photos of curved surfaces it isn't easy to tell so it was just a caution. basically, the sill is the same distance above and parallel to the deck, the head is the same and the jams (sides) are perpendicular to the keel. This does often give trapezoidal ports.
Do some tests and on the model, start lighter. You can darken it with another coat if needed.
Craig.
I have still got plenty of those to go..................
Your drawing show it really well, I was not clear before, but looking at the drawing it I am  now. thanks.
Current Builds :
a thousand words, I wonder who first said that.
Craig.
Thank Craig @iMustBeCrazy That's good advice, I will need to mask the deck as I am happy with that.
Will test on scraps first.
Tim
Current Builds :
Mixed up some NotWOP  50% varnish, 50% stain, it gave a nice milk like liquid.
tested it some some scraps, seems to work.....................
Masked up the hull, then I bit the bullet, it was a bit of a pucker few minutes.
Here is a profile view of it drying, I guess it will change tone as it dries but I am pretty pleased with the result.
View of the stem end
Now I'm going to sit down and have a cup of tea, or maybe something stronger  🙂
Tim
Current Builds :
beautiful build Tim
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
16 minutes ago, Mirabell61 said:
beautiful build Tim
Thank you so much. It is difficult sometimes to keep up the enthusiasm but a few encouraging words help a lot.
Current Builds :
@Mirabell61 I just had a quick look at your Pegasus build, it's fantastic, that is the kind build I aspire too.
I would love to do a cutaway ship like yours, but I feel I still have a lot to learn.
Tim
Current Builds :
The hull is now dry, so here it is unmasked
I think that the wale needs to be a lot darker than it is.
The fashion piece ( when fitted ) should be the same tone as the wale
thanks everyone for the likes
Tim
Current Builds :
Thanks Tim,
I wish you a lucky hand for your next cutaway ship project
In my hobby office there is the Pegasus on a shelf and my grandchildren love to look into the model which is in head hight in a glass-case (dust protection)
Nils
Current builds
-Lightship Elbe 1
Completed
There may be a terminology issue: the fashion piece is part of the framing at the stern, under the planking. Perhaps you meant the quarter piece. That attaches aft over the planking above the wale.
Looking closely at the planking I can see that the water based WOP ( NotWOP ) has raised the grain but only where I had not sanded down enough.
The finish had looked really good but scratches left by coarser grits are now showing as raised lines.
Does real WOP do this as well?
Tim
Current Builds :
Thanks @druxey I think you are right there does seem to be different usages of the term 'fashion piece', I am still learning so just use what I see used here on MSW.
Chuck Passaro used the term on his speedwell build, in that instance it was a carved piece, I just assumed it would also apply to a simple uncarved piece applied in the same place.
As I said before, there is so much to learn.
Tim
Edited by oakheart
Current Builds :
51 minutes ago, Gregory said:
I believe this has been referred to as a fashion piece on Cheerful.
I knew I had seen it some other place as well, thanks @Gregory
Tim
Current Builds :
I can't resist playing, placed a few bits on deck just to start to get a feel for how it could look3quarterfrontsomeparts.thumb.jpg.134eec5ff8dda3f38f23717ac3c7b0cf.jpg
off for a snooze now
Tim
Current Builds :
Got a good amount done today.
Darkened the wale and added the rail under the gunports, don't know what it's called.
made the quarter piece or fashion piece, I made it in two parts as the test I did did not bend well
amazing how the photos highlight all of the bad parts as well as the good
I am enjoying having got this far and it does not look too shabby, especially as this is only my second single plank on bulkhead scratch build.
thanks for all of the likes and help / encouragement you have all given me.
Tim
Current Builds :
Now I need to do the opposite side, the cap rail on the transom, then it's onto making and fitting the details.
I will need to keep referring back to thunders @Thunder build for guidance.
Chucks @Chuck Cheerful is also similar enough to be a great help here.
Does anyone keep a list of what needs to be done next?
Tim
Current Builds :
