I have not built an Eduard in a while if ever and have to say this is a saaweeeet Kit! The fit is just about perfect filler was a minimum on one wing root only.The kit supplied the PE to build up the pit though being a Spit not alot to see but I did use for the first time the SG with the light worked great for the bezels.I have been back with my MM enamels of late having found that MR.Color Leveling thinner for lacquers works Frigg'in excellente allowing me to thin to a 60/70 ratio of thinner and get a good application and is reviving some of the ole paints.The camo was all applied @17psi with the draw back on the trigger set to very light spray.The camo was drawn out with a pencil one at a time hitting the pencil line 2X and filling in the area it took me about 1 1/2 to 2 hrs to paint the whole plane,the airbrush never stops moving in various patterns.I started the build last Monday after shelving it for sometime for lack of interest but I think it's time to clean up those off the SOD.;)
My MM Ocean Grey was to far gone to bring back with the leveling thinner and OG has a tint of blue I went US Intermediate blue I'm thinking a little to blue but the flash also is overstating the blue some what.:rolleyes:
I went back out to the shop to clean the AB definitely not that blue will take final pics outdoors natural light next week.;)
Edited by Javlin
17 minutes ago, Roger Pellett said:
This Spitfire, apparently introduced late in the war has squared off wing tips.  Can anyone explain?
I think the MkXVI's were generally used for V-1 doodlebugs.The tips could be changed easily in the field in minutes.
Your answer;
Clipped = tip of clipped wings
  • Advantage:increased speed and lateral maneuverability. wings reduced by about one meter.
  • Disadvantages: this reduces the bearing surface and increases the marginal vortices
https://aviation.stackexchange.com/questions/77164/why-did-some-spitfire-variants-have-their-wings-clipped
Edgar Brooks:
Clipped wingtips were an essential modification (one of several, in fact,) when fitting the fuel tank behind the pilot, and, even then, the stub-spar, on frame 5, also needed strengthening. (11 Group hated the idea, and fought against it, due to the detrimental effect the mods had on performance,)Post-war, use of the tank was banned, which probably allowed standard wingtips (and elevators, which had to be metal-covered on the XVI) to be refitted.
Edgar
More Ammo;Clipped wing: This mod was found to be necessary on the Spit IX when used for dive bombing, as several cases of severe skin wrinkling occurred in 2TAF. A gain in strength of 10% is obtained by this means. It is considered by the MAP that on a Spit IX or XIV with full bomb load and extra internal fuel, the reserve strength factors would be unacceptably low unless the wings were clipped
Edited by Javlin
2 hours ago, king derelict said:
Thats looking very nice Jav. I need to try an Eduard kit
Alan
They  are excellent  Alan.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
1 hour ago, Javlin said:
she was a quick build
You aren't kidding!!!!
CRACK!!! the lightning bolt hits and before the smoke clears there is a newly born Spitfire....
I wish I was that fast....
Nice work btw... the colors look spot on... (proper pattern as well)
Well Done...
Quote:
Lovely looking Spitfire, with a Gallic twist ! 🇫🇷
Edited by AJohnson
Andrew
Completed (Kits):-
