Hi there,
few progress and a small problem. The problem first: some of the chemicals of the coatings seeped below the masking tapes and crazed the transparent plastic. There is also a mysterious whitish halo close to the yellow spine which probably was caused by the flat agent of the clear coating.
I addressed the transparent by wet sanding with fine grits followed by polishing with Tamiya polishing compound. The halo was cured by spraying over it another bit of clear paint. The underside was completed with the landing gear doors.
Finally, the Starfighter got its stings, the Sidewinder on the port side:
And a Sparrow on the starboard side:
This asymmetric configuration was commonly used by the Italian interceptors. Finally, two overall views taken under natural light to show how the real colors of the camouflage turned out:
Here the blemishes reported before were already cured:
That is all for now,
best regards,
Dan
Edited by Danstream
Hi there,
this time I concentrated on finishing the cockpit. I sourced the Eduard ejection seat M.B. mk7 to replace the one of the kit, which was overall correct, but very simplified. The Eduard resin is very nice (I wonder how they produce these things) and broken down in few pieces. As usual, to drape the photoetched harness made of steel was a serious test of my mental sanity. The finished product, painted and coated with a flat clear was nevertheless quite nice:
This is the seat tested inside the cockpit:
Finally, this is how it appears under the finished canopy:
That is all for today,
best regards,
Dan
Edited by Danstream
That is a very tidy looking bang seat Dan!
Andrew
Completed (Kits):-
Thanks Andrew 😃! The Eduard kit was of top quality. Beside the photoetched things that are always a bit tedious to me, it was enjoyable to finish it.
Cheers,
Dan
Hi there,
the last bits being assembled. The angle of attack sensor vanes glued in place with white glue;
The huge tip tanks that ruin the sleek shape of the plane:
The stabilizer/elevator surface of the 'T' tail:
And finally the nose cone with the long pitot which I managed to knock off only a couple of times:
Next installment will be the last one and will contain the final pictures. Being the plane very long, it won't be trivial to take good pictures with all of it in focus.
Best regards,
Dan
Edited by Danstream
LOCKHEED F-104 S STARFIGHTER
Kit Hasegawa 1:48 scale
These are some of the final pictures of my finished model which depicts a Starfighter in Italian service.
DSC_0009_vintage.thumb.jpg.ac6d7348721bf87612ff1fd089eb3f8b.jpgMy F-104 carries the insignias of one of the interceptors of the 51st Stormo, based at Istrana, North of Italy as it appeared in 1981. This version started to be built by Aeritalia in Turin (former FIAT) in the late '60. It was powered by a more powerful J79-GE-19 and was armed with the version B or L of the Sidewinder missiles and with Sparrow missiles (from which the letter 'S' in the designation).
The kit is the old 1:48 Hasegawa of the F-104 S which is by now outdated by the newer 'state-of-the-art' Kinetic one. Nevertheless, I found that the plastic is still very nice with crisp and finely engraved surface details, thin and clear transparent parts and it well reproduces the distinctive forms of this aircraft. The build log can be found in the previous pages.
To improve the model, I sourced the following after market items:
-    Aires resin jet exhaust;
-    Master brass pitot probe;
-    Eduard resin ejection seat MB Mk7 and harness;
-    Eduard resin Sidewinder;
-    Aires resin Sparrow;
-    Skymodels decals.
The colors that I used for the Italian NATO camouflage were Gunze H-69 (dark sea grey), Gunze H-309 (dark green) and Vallejo Metallic 'white aluminum' for the underside.
Beside the positive points, I am also listing what are, in my view, its few negative points:
-    Overstated rivets on the wings which shouldn't be there;
-    Incomplete range of details for the 'S' version;
-    Absence of external loads and pylons;
-    Decals with yellow/cream color in place of white for codes. I replaced them with after market decals.
The grey paint of the camouflage was slightly post-shaded to reproduce the typical discoloration of this paint. The final finish was obtained by a coat of Tamiya flat clear XF-86 with some clear added to obtain a satin finish.
Little rivet trails and discolorations on the undersurface were obtained by oil colors.
I hope you like my model, thanks for the provided feedback and comments and suggestions are as always welcome.
Best regards,
Dan
Edited by Danstream
@ccoyle, @Canute, @king derelict, thank you so much for your kind feedback which I truly appreciate.
Thanks also to the various 'like's.
To the next build,
Dan
Wonderful build Dan, think your presentation pictures at the end are really good.
Andrew
Completed (Kits):-
On 3/25/2024 at 6:57 AM, Dave_E said:
Outstanding build Dan, top shelf!
Thank you Dave! Thanks for your support.
Dan
Thank you Andrew! Glad that you liked also my pictures.
Cheers,
Dan
12 hours ago, Landlubber Mike said:
Dan, somehow I missed that you completed this one.  Another stellar build!  Well done!
Thanks for your assessment, Mike. I am glad that you like it.
I am thinking to the next build which will be a De Havilland Mosquito.
Cheers,
Dan
