On 6/15/2024 at 9:25 AM, Mirabell61 said:
I am evaluating to make the derrick-mechanism workable
I appaluad your ambition Nils, however I suspect that the lack of weight in the boat and the friction in the mechanism will conspire against you. However nothing ventured noting gained.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Right Keith,
I also have my doubts about the boats weight and the friction in the system. It was my early thoughts to include some lead weight or so into the lowered boat boat as well, but,  the intentsion to show one of the boats lowered for entering over the side, would overrule the doubts, even if it should not work as mechanicly foreseen. (only staticly bringing into position)
It is ambitious for me to model that mechanism for this small scale, and what materials would be suitable for doing so. Hope I´ll get it done somehow
Nils
pic out of Helmut Thomas`s  (model) magazine, allthough he did`nt include this shown feature himself
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Nils - I think brass for the runners and wheels would be your best chance of success.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you Keith,
I had already ordered small brass wheels for guiding the lines and brass U-profiles for the slide bar-supports. I think I`ll do the slide structures from 2mm thick 4-layer laminated ply, or from 2mm thick aluminium plate if the ply turns out to be too flimsy
Nils
Current builds
-Lightship Elbe 1
Completed
Hi John,
gravity, yes I thout so....
made the 4 arms of the davits, and the rail round the bridge
Nils
the 2mm tick 4 layer beech ply
the arms for the davits, it looks like the 2mm ply is strong enough
greatly magnified the first prototyp boats hook, with integrated 3mm roll
the bridge rail
stairway to the bridge
Current builds
-Lightship Elbe 1
Completed
made a raw prototyp of the gravity davit with slide function. I may have to make the arms a bit thinner
Nils
just to see if it works .....
lower position
upper position
the slide profile is made from two U-bars
Current builds
-Lightship Elbe 1
Completed
And shorter, as you can see on the above drawing, the side of the boat rests against the fender on the davit arm when inboard. The hanging point, tip of the davit arm, is in the middle (transversally) of the boat.
You'll have to shorten the arm so that the tip is half of the boat width outboard of that fender.
Hope my explanation makes sense...
Roel
Thank you Roel,
your comment is well understood. I think that a sample boat is required now, will have to make that first, a wooden model would do, I could take the silicone mold from that
Nils
Current builds
-Lightship Elbe 1
Completed
thanks for your words Michel,
Nils
Current builds
-Lightship Elbe 1
Completed
Update
I started with the wooden model yesterday out of a light carvable wood, to take the silicone-mold from. The boats are after the pic of the  make actual Fassmer lifeboats. In fact they are little launches with built in Motor.
I put a fender line all around. there will be two cockpits later on cut out of the cast resin outformings. I stll have some silicone with catalyst left over from recent models, for the  port- and stb. half-molds, hoping it would still work, but the resin and its hardener have unfortunately expired lifetime, so I need some new.... Also the wooden plug for the hull inside contoures must still be made.
Prop and rudder / rudder-heel will be mounted to the resin models later on.
Nils
drawing of the actual Elbe 1  boats
the wooden lug ontop is for holding in the vice during shaping
in scle 1:87 the boats will be appr. 84 mm long
bilge keels fitted
fender-line all around
Current builds
-Lightship Elbe 1
Completed
Nicely done Nils. You didn't say much about your carving method and I would be interested. For instance did you use templates or just freehand it?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
thank you very much Keith and John,
Keith.
I made a template of the deck only, the other dimensions are taken from free hand. The silicone mold for the port side turned out quite well. I`ll be going for the stb. side now. There is one little objection near to the bilge keel, where an air bubble got trapped, but that can be easily removed from the later resin casting
John,
I practiced the rope-line fender on my 5 Elbe Pilot schooner`s boats and it worked very well. All details of the rope were cleanly with the cast resin afterwards.
My main concern was that the silicone`s lifetime may have also possibly have  expired, because I had bought this longer ago together with the (now unusable) resin and hardener.
Nils
rope contours are clearly visable in the mold
Current builds
-Lightship Elbe 1
Completed
Thank you very much Rick,
Update
for the stb. side mold I built a better boxing (Balsa) for that half mold. I knew I had a mini platine with very small etch parts which also comprised 5 wee prop 3-blade etchings of only 5mm diam. Finaly, luckily I found it. because these mini etched props were taken from the market for reasons I do`nt know. the wooden plag could easily be removed from the mold thanks to the use of seperating wax -spray applied to the wooden model before.  After removal the wooden plug was bearing no silicone residue. The blades were bent into shape. and the rudder blade was soldered to its shaft. To see what it looks like, all was mounted to the wooden model, as a sample, the heel was cut and drilled fom a small part of brass bar. I find it does`nt look bad, and even the rope contoures come out well.  The polyurethan resin with appropriate hardener is ordered, and I`m eager to see the come-out , in some coming days after the wooden inside contours-plug is finished.
Nils
making the stb. side mold in an improved Balsa- boxing
prop and rudder mounted
the prop etching is only 5mm diameter and soldered to its 0,8mm shaft
Current builds
-Lightship Elbe 1
Completed
Thank you Veszett,
sure, I`ll keep it, for the sake of taking molds for spare boats if needed
Nils
Current builds
-Lightship Elbe 1
Completed
Update
because I had problems with getting the mixture for the 2 components (both exactly the same weight neccessary ) I invested into a small digital weight scale.
After using that, it works well and results are repeatable. I am holding now 6 halves, glued two together and cut out the cockpit areas. I should have done that long ago already.
Nils
the new weight scale
stb. half model with inside contours
outside view
halves glued tother and cockpit areas cut out
Current builds
-Lightship Elbe 1
Completed
Nils - Nice work - what is the resin you are using?
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith,
I`m using a polyurethan resin from "Trollfactory" webshop. its  TFC PU Resin together with TFC PU Caltalyst, each in a 250 Gr. bottle (together for 19,80 EUR)
If mixed together weight wise 1:1 you have about 15 minutes time untill curing starts.
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Update
The boat`s hulls are so far complete, rudder, tiller, prop, and seating area, and hook-eyes built in, now ready for painting. I built total
3 boats, so one in raw condition will be kept for spare.
Nils
the inside is ocre yellow with brown seatings
this is the hook system of the gravity davits
Current builds
-Lightship Elbe 1
Completed
Thank you Gary,
yes, I`m very pleased how the rope came out. I`ll paint it in rope color after the hulls are painted
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Finished the boats, except for the names and the homeport, also the hooh-blocks, the davit arms with line leading points, the soldered brass racks for the gravity system, and the motorized reels for the lines, the reel axis still to be shortend
Nils
equipment for hoisting and lowering the Elbe 1 boats
Current builds
-Lightship Elbe 1
Completed
