I'm continuing with planking, it's going very slowly - so far I have about two-fifths of the hull done, including nailing. And although I was as careful as possible when manipulating the hull, I managed to break off part of the stem. Fortunately, it is only in the glued joint, so the repair will not be difficult.
Beautiful and clean work, marsalv. I usually delay attaching the knee of the head until after planking and work on the external hull is complete, to prevent it breaking off. Also, it is not in the way when planking the bow.
Fantastic and inspirational.
Regarding CNC: are digital files included in the monograph, or do you scan the paper copies?
And do you have a list of the different woods you have used?
Edited by EspenT
Thank you guys for nice comments.
To druxey - For Le Gros Ventre I did the same as you, but there were some problems when gluing the knee of the head - the knee of the head does not fit well to the keel and a small gap can form there. That's why I've chosen a different procedure now, the joint between the knee of the head is perfect, but it has other negatives.
To EspenT - Unfortunately, the monograph does not contain digital drawings, so all drawings are scanned and further processed in a CAD program. The list of wood species is as follows: unsteamed pear (used for internal planking), steamed pear (has a slightly pinkish color shade - external planking), black hornbeam (substitute for ebony). Boxwood will also be used (carvings and decorative moldings), castello boxwood (planking above the wales), maple (decks). That's about it.
marsalv that is such lovely work especially the way you have fitted the planks into the rebate on the wing transom.  That is as I have found difficult to get right so that they look square but you have it spot on.  Very brave too with the amount of frames removed - I'm glad I've seen you do it as this is what I want to do with my next build.  Happy Xmas and a very happy new year
Fantastic work!  When I had a go at Samson posts I thought about using a mill.  But actually I found them really nice to make just using a chisel.  Maybe I'll try a mill next time as your results are lovely.
Hi No Idea,
at Le Gros Ventre I made Samson's post using a shape cutter. Here it's completely CNC - the result is nice :).
I continue with the deck beams in the lower front part of the hull. These deck beams will be attached to the inner planking on one side, on the other side, where the frames are cut out, the ends of the deck beams will be in the air, which makes their installation somewhat complicated. I made an auxiliary jig for this purpose.
Beautiful work the bits could be a stand alone model.  I've been watching some tutorials on Vcarve and at some point may take the plunge on trying to learn it better.  I was wondering how you take the drawings and transpose them into Vcarve?  I'm a total novice with Vcarve and CNC so I expect your answer will give me more questions than answers.
To No Idea - Vectric programs can read DXF files. So it is necessary to have a CAD program available in which I draw what I need to mill and save such a drawing in DXF format. I then load it into Vectric's Aspire program and then create the milling data there.
