Building the new Vanguard Resin 26’ Launch.
Partly out of curiosity I decided to get one of Chris’s new hot off the press resin launches. It will provide an interesting exercise in woodifying the resin hull and allow me to compare with the wooden kit versions.
It may also help to lay the ghost of my failure with the Indy kit version, and if nothing else I will avoid the frustration of breakages.
A look in the package
4748
This is what you get.
4743
Internally the Keelson is represented together with mast and davit steps.
The solid floor footwaling is represented by broader planking sections for which there is historical evidence.
My current Medway Longboat also has much broader floor  planking.
4741
The moulding is very nicely done and looks to need very little clean -up beyond washing the resin.
4742
I note that there is no indication of external planking strakes, possibly thought unnecessary because the hull must be painted and they would be pretty fine and not show thro’ the paint.
The oar arrangement is for double banking, which is appropriate given the Admiralty order of 1783 regarding Launches.
4745
The significant feature of a Launch, the windlass, is also supplied in resin. I am pleased that this feature has been included, these are tricky to make at 1:64 scale, I know, I made one to go with the Launch for Sphinx.
4746
The remaining Resin fitting is the davit.
I don’t think there are any instructions with these kits but then there is not much in the way of construction required to complete the model. All the hard work has been done, internal framing and the all-important thwart supports are moulded in.
The thwarts and stern sheets are of 0.8mm Pearwood and look to simply slot into place with minimal effort.
The key factor in producing a fine model is all in the painting with this medium, we’ll see how I get on.🤔
Both the Resin and the alternative wooden kit versions are the same price at £29.00. The difference is that with the wooden version brass etch grapnels and boathooks are included, along with a good serving of tricky building time, but it doesn’t have the windlass.
I wonder if the Resin fitting would be appropriate to supply with the Pearwood Launch version as an optional extra?
 On with the assembly.
B.E.
21/05/2024
Go to Windows search and type " snipping tool "..
You can copy any part of the screen you are looking at.  It goes to the clip-board, so you can paste it directly into the discussion.
You can edit in "Paint", or do whatever you like.
Even though it's telling you to press all those keys, all you really need to do is press Ctr+N..
― Jimmy Buffett
Slow crawl:    Rattlesnake
Progress on the hull.
Post 2
The only area that needs cleaning up is the transom.
4751
This has a pimpling effect from the moulding that needs sanding smooth, a simple and quick exercise.
Note there are two little protrusions on the transom and stern post that relate to the rudder and shouldn’t be mistaken for flash.
4762
With the resin washed and the parts carefully trimmed as necessary, they are now primed.
I use Vallejo surface primer.
In considering the colour scheme, my aim is to create a look that tones in with the wooden kit boats on ‘Indy’ purely for comparison purposes.
The internal areas of boats were usually painted and with a resin model it is necessary.
I have read that left over paint mixtures known as sad were often applied to the internal planking of ships boats.
Once the internal painting has been done the windlass can be fitted.
4766
It slots into the housing perfectly, with very little effort. It then provides a useful point to hold the boat for painting the external hull.
4763
The outer hull painted with a mix of ¾ Burnt umber / ¼ Natural wood.
This was followed by a wash consisting of Flat earth lightened with Ochre brown and tinted with a spot of vermillion.
This was applied over the base and dry brushed.
With acrylics it is easy to play around with colour mixes until a tone that suits the eye is achieved.
4769
4772
The lower hull was painted using Vallejo Ivory.
4779
4784
Onto the internal fittings.
B.E.
23/05/2024
The new 3D molds look really good, especially with the inclusion of the windlass and davit. The resin does paint well with only a simple base acrylic primer. I use a Tamiya rattlecan (grey) for this and it's compatible with Vallejo paints.
iPad screenshot: press the "Home" button and the "Power" button simultaneously and then release; a thumbnail will appear in the lower left corner which can then be tapped on to enlarge it with various file options (Save, share, delete, etc.). No "snipping tool" required.
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Post 3
Internal fittings
All the wooden internal fittings are laser cut on 0.8mm Pear sheet.
4788
The thwarts fit perfectly in their allotted positions, and at a correct rowing height.
4797
4799
Always good when the feet of a scale figure are a perfect fit for thwart and footwaling.
The stern benches are notched to fit over the frames, and again are a perfect fit.
4796
One feature that caught my eye was to see that the benches fitted over the aftermost thwarts.
The drawing would support that view, at least on this design of Launch.
The Rudder
This is fairly fragile at 0.8mm, and the head of the rudder split a little in the area of the tiller insert.
26footlaunch1.jpg.afb38c53b6869110acfad99d83f02838.jpg.16f4a94b92f194acacc112903f204832.jpg
The kit set-up has the addition of side cheeks, for want of a better word, either side of the head, between which the tiller is inserted.
I don’t recall ever seeing such an arrangement on boat rudders. I wonder if it is supposed to represent a sort of tiller cowl that slots over the rudder head?
4804
I don’t know if such an arrangement ever existed in the 18thc, but either way I thought it looked a little odd, and rather ugly, so I re-made a new rudder using 1mm Pear. (left hand version)
Oars are supplied in 0.8mm Pear and I note that Chris has designed in the broader elements of the loom. The blades are also finer than on other editions.👍
4807
I think the oars more than fulfil their purpose at this scale.
The next post will see the completion of this long weekend project.
B.E.
25/05/2024
Post 4
The launch is completed.
The only modification to the provided kit is a replacement for the rudder.
I have also added the following:-
Lifting rings to the keelson.
A cap square for the mast
A brass etch grapnel from the Indy kit.
A turning bar to the windlass.
I have also utilised the boat chocks from the Indy kit to support the hull.
This has been an enjoyable little project and I am pleased with the result.
2284a
2287a
2290a
2292a
2296a
4828
Below is a comparison with the wooden 24’ Launch I made for Sphinx.
2283a
2273a
2279a
Both versions in my opinion look good and I think they represent the best available options at this scale.
The Resin/wood combo is a good match and almost fools the eye into thinking the whole is a wooden construction.
For those who may prefer to avoid the time and frustrations that can arise building the wooden versions, they are an excellent choice.
The wood versions have a slight edge for build match with the Main ship medium, and perhaps give a greater satisfaction in successfully completing these tricky little kits.
I don’t think I would mix resin and wood boats on the same build, but I am happy to consider either to enhance the ship kits.
You pays your money and takes your choice.
B.E.
26/05/2024
