Dear all
The Launch is not far off completion so I have been thinking what might be the next project. I really wanted to embark on a long journey, 10 years or more, and built something with many masts and frames etc. Certain funding issues though came about so this journey will have to wait.
That same day though I came across a lovely boat in the gallery by @Kevin. I 've always liked Tug boats and looking at this wonderful model I was immediately sold. I would build Hercules!
Now, there of course the kit by Occre but I should be able to scratch build it, shamelessly guided by the images on their website. This would be my first POB boat.
But of course, some lines would be necessary so off to the internet to get any boat lines that would be close enough. To my surprise, google returned a wealth of information - a specific site https://www.themodelshipwright.com/high-resolution-ship-plans/cargo-ships/steam-tug-hercules/ was of great help.
This site had everything - offsets, info, photos and lines. Apparently the boat was in dry dock for repairs and they took the opportunity to lift some lines.
Untitled.thumb.jpg.76ebb6e997c8c10665d39e537ebf71c0.jpgUntitled2.thumb.png.9166a387ca8ac2913a30ab8163d23197.png
Indeed a wealth of info but of course serious lofting would be needed. First thing to do was to get everything onto CAD (I am hopeless in drawing with a pencil) and see whether I could get a hull out of this ocean of numbers.
So a brief hibernation period for the Launch to get this project under way. I am not sure how it will work, what scale or the level of detail but we ll figure it out along the way, at my usual snail pace.
I hope you ll join me on this new journey and thank you for visiting.
Best wishes
Vaddoc
Ok, so I have been playing a bit with the lines on CAD and first impression is that this is not going to be straight forward.
First we need to define the sheer. This is the first line according to the table of offsets:
It looks fair but it is not. With a bit of attention, we get a fair line
Screenshot(52).thumb.png.173d81a388b893c104d826e6107ca40b.pngScreenshot(55).thumb.png.40a4bb42953388461b9097f0dc660165.png
Same for the second view
And combining the two we get a sheer (not THE sheer - this will come later)
We can create a bit of surface, just for fun
Now, this is incomplete as the stern is missing, it does not reach the stem and is not clear how wide the keel is but it is a start.
Then, we get the waterlines and buttocks - All needed a bit of work to become fair
Combining everything we get an idea of the hull. This is not the actual hull - A lot more work will be needed to get there. I also added the keel which is not given in the offsets.
Next I actually used the plans to draw the frames and all other lines by putting the image sized appropriately as background and drawing lines on top. I combined all and this is what came out
It actually seems pretty close, it even gave a smooth hull. But it is not ready yet.
After a lot of work, the hull and lines were getting tighter but far from true. A lot of eyeballing was used, moving lines were it seemed they wanted to be.
Now that I had an idea of the shape, it was time to start again. I first faired the diagonals which I had not used at all so far. Then I rearranged the buttocks to reach the keel where they were supposed to. Finally, I tweaked all these lines to make sure they were fair and interacted at all intersections. This took a lot of work.
But when I added a couple of waterlines, these diagonals and buttocks had to be adjusted again to interact with the waterlines and with each other.
Only the upper waterline is completed. There are 7 more and incorporating these into the hull will certainly need revisiting every other line. There are also a few areas in the hull that are of concern, the first frame near the bow where so far the hull is taking a bit of an acute turn, the cut out for the propeller, the curve at the bow but these bridges will be crossed at a later time.
This is all I ve managed to do but so far it looks promising.
Till next time
Vaddoc
Vaddoc,
I have generated 3D drawings of several hulls from the numbers in the Table of Offsets. As you said, it is a lot of work!
I found several errors in the offsets for each of the hulls. They were usually off by 1 foot, 1 inch or 1/8 inch - the units used in the tables. First an engineer created the offsets, probably using a slide rule or maybe a mechanical "adding machine" for some of the older hulls - the first chance for error. Then the engineer had to write all of those numbers down - the second chance. Then the draftsman had to read the engineer's hand writing (a third chance for errors) and copy all those numbers onto the drawing - the fourth chance for error. And, of course, I had to copy them all into the computer. Five chances for error. It is a wonder that any of it came out right!
And then, after finding and correcting these simple numeric typo mistakes, I found that the station/frames generated from the data didn't fair smoothly after all. Like you I spent a lot of time tweaking the lines to get a smooth hull. But even so, I am sure the hull dimensions are more accurate than if I had just traced lines from the hull lines drawings.
Your hull is looking good!
Phil
Current build: USS Cape MSI-2
I had a look at the site - excellent information - even the plating drawing.
Marvellous CAD work - I wish I understood it all. Maybe I am glad that my draughting training was completed at the turn of the Stone Age.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hello Vaddoc and congratulations on starting a new project.  This is a vessel I once considered scratching myself, so I will certainly be following your progress with interest.
The Hercules is a great choice and as you probably know, she is a US National Landmark and part of the San Francisco National Maritime Historical Park.  Consequently, much is known about her.  The vessel is part of HAER (Historic American Engineering Record) National Park Service.  The drawings you have are public domain and the originals are available for download at various resolutions from the Library of Congress website.  Also available at the site are photos, photo caption document, and a data document containing interesting stats and brief history.
Steam Tug HERCULES, Hyde Street Pier, San Francisco, San Francisco County, CA (loc.gov)
San Francisco Maritime National Historical Park (U.S. National Park Service) (nps.gov)
The historic park also has a research center that may be of help to you.
Maritime Research Center - San Francisco Maritime National Historical Park (U.S. National Park Service) (nps.gov)
Best of luck on your new project.
Gary
Completed Scratch Builds
Hello Vaddoc,
what degree and what number of control points did you chose for the lines? Do the station lines have a higher point count and higher degree than the longitudinal lines
(buttocks, waterlines and diagonals)?
According to my experience a low degree and a low number of points results in the smoothest curves. But the deviation from the points given by the table of offsets is highest.
If the number of control points equals degree of curve +1 then the curve doesn`t have any abrupt changes in curvature, thus the curvature graph is smooth.
What`s your approach? Do you start with a high number of control point and rebuild the curves with less points if applicable or do you start with few control points and rebuild
with more points if necessary?
Either curves are fair or congruent with the curves of the lines plan or points of the table of offsets. We can`t have it all. So we have to compromise.
I don`t envy you in re-engineering a ship`s hull.
Michael
  • 4 months later...
Dear friends
Please accept my apologies for the huge delay in revisiting the log and replying to your comments - you all know how it gets...
Although I did not find time to visit the log, I did do some work on the boat. So here it goes.
@Dr PR Phil you are absolutely right. I could not make the numbers in the table of offsets work and in the end, I gave up. More on this bellow.
@KeithAug It can certainly be done with a pencil and ruler and actually it is easier to get fair curves with a batten. However, despite having a professional draftsman (woman) for a mother, I cannot draw - I need a computer to help me draw a straight line!
@FriedClams Many thanks Gary, I was not aware of the links!
@Bedford Excellent, as always a pleasure!
@bricklayer Michael, any version is fine. It is actually not too complex - Analysing the curve shows its fairness. If it is not fair, use the fair command. A bit of eyeballing and a bit of manually adjustment of the curves is needed. I use many check points to start with, when the curves are all over the place and as the get closer and fairer, I use less so that the curves get fairer but without allowing the curves to wonder too much off the originals. The lines do need to interconnect when going through a lofting cycle - they do no longer connect after the lofting cycle finishes and the lines are corrected and faired but this is ok. With every lofting cycle the lines get closer but in the end, it does not need to be perfect, just close enough - the wood will correct the rest.
So, I initially used the table of offsets - These were apparently taken directly from the boat when it was in drydock. I started over a number of times as I could not really make things work. Finally I decided to give up on this table. Something did not add up - the keel, the numbers - something.
However, there is also this:
service-pnp-habshaer-ca-ca1500-ca1507-photos-315928pv.jpg.2db56c1994fc590f033deab629c4434b.jpg
This is the half model of the boat and lines were taken of it
service-pnp-habshaer-ca-ca1500-ca1507-photos-315931pv.jpg.73d234308636a80a4bee595b17149d3f.jpg
So I decided to use these line, tracing over and importing into CAD.
Immediately it felt better. A couple frames at the bow were wrong and the stern needed a bit of work but overall, these lines appear better and closer to the actual boat. So after a few cycles I ended up with a reasonably fair surface and frames that are reasonably fair and pretty close to the original tracings.
Screenshot(90).thumb.png.86f00122ce7d9a34510978f8a5765418.pngScreenshot(94).thumb.png.9937fc8e3434b457e19e580694f043ff.png
Screenshot(96).thumb.png.5b2084295a813bdab886461e2506cc76.pngScreenshot(97).thumb.png.9d60a868f043845ba7196826ca701a79.png
I think it is ready to move on further - I hope that tolerances will be corrected with a bit of shimming, bit of filler, bit of sanding.
So, next I made the deck which unrolled gives us the shape of the plywood - I though about adding camber to the deck but I think it will be fine without.
Now, I ve never built a POB boat before and for this project of course I had a look at the Occre model to get some ideas. Now, Hercules is 151 feet long and the Occre model at 1/50 scale makes a pretty huge model 920mm long. I think I ll go with 1/64 which will produce a more manageable 718mm model.
Till next time
Vaddoc
Dear all
I just spent a small fortune in plywood, so should not be long before some wood dust is made - so time for another update.
I also have been unable to work due to creaking bones so an opportunity to do a bit more work on Hercules.
So I ve been thinking how to arrange the keel and frames and what material to use. As I always do I will laminate my own plywood to make sure it is strong and dead flat. Also, I will use plywood for planking - Hercules hull was made from steel sheets welded and riveted together without much care for aesthetics so planking the model in the usual way is not appropriate, I will use sheet material without being pedantic about fairing - the seams probably need to be quite visible. I decided to use 1.5 mm ply - quite an overkill but it will be a big model and I think it needs this thickness to be stable and for the fasteners to hold well.
The hull will be 3.9 mm thick, laminated from 2 pieces of ply 1.5 mm each, 0,9 mm should be the thickened epoxy layer. I will measure it though and if it is less, I will adjust the lines
The frames will be very wide, 5.8 mm, laminated from 2mm and 3 mm ply - again, if the new ply has different dimensions I will readjust the frames (which will be a big job)
So a few photos
The hull is finished! I suspect there will be some pretty large tolerances and gaps but I hope that as I will not be cutting the wood accurately, one mistake will correct the other - of course may make it worse but lets be optimistic.
The stern was tricky to get as there is no transom. In the original design there were many metal beams spreading out at the stern to give the correct shape to the sheer which aft is a vertical wide zone. There will be a lot of pressure at this point to convince the ply to take the turn so I overbuilt the area. There will also be more reinforcing pieces of wood connecting the frames inserted during construction.
The frames are offset to accommodate the hull thickness of 1.5 mm. This is a wonderful feature of CAD - press a button and a complex surface is offset to whatever thickness within 2-3 sec!
The frames should fit a 900 x 300 mm piece of ply
The keel is a bit complex and pretty large at 720 mm
Keel.thumb.jpeg.2fcc3511407d09fa5e2f4686f0ffc73b.jpegKeel1.thumb.jpeg.2b1dd76f6aff28ce6cd602185ed8b1b9.jpeg
The deck will also be 1.5 mm to hold fasteners well - I did not account for this thickness but I think it will not make any difference.
I will start work on the superstructure after I will have laminated the ply, so I will have accurate dimensions of the actual hull.
Till next time
Vaddoc
3 hours ago, bricklayer said:
Or is it daggerboards?
These are just little feet to help keep the keel horizontal!;)
They will be cut off in the end.
Edited by vaddoc
Dear all
Although I did a lot of work on Hercules, I have little progress to show. However, there have been changes and upgrades so an update is in order.
I had to revisit the plans many times as I found mistakes that had to be corrected. My computer however has been playing up badly so I ordered a new one.
I then thought I should not wait for Santa but instead should take things into my own hands. So out with the old, in with the new!
20241207_101026.thumb.jpg.d90b254506f769bceb0c94bf3174212c.jpg20241207_103509.thumb.jpg.2cf178940088411f9d9d79b2123a54e9.jpg
Now, all plywood used will be laminated to make sure it is straight and rigid. In my plans I had set the thicknesses but this meant my laminates should actually be that thick and they were not. So I had to redo the plans to match the thicknesses that the ply ended up having.
Now, laminating ply with epoxy is a dirty messy business but it went ok. This is how I do it - old textbooks, butane cylinders, anything heavy will do
The ply came out very straight, this sheet is 900 mm long. It is straighter than it looks in the photo!
20241217_190918.thumb.jpg.636f011a76cece194f41170dc630eec2.jpg20241217_190937.thumb.jpg.acf969c84d0a05c1da34d70502c6110a.jpg
I ve done a lot of work on the hull and the superstructure. I downloaded the Occre assembly instructions to get some ideas but generally I think I have massively overengineered and overbuilt the thing. Some pics from the plans so far, there are lots of things going on but best explained as the building progresses:
An interesting twist is the propeller structure at the stern. Occre's solution is not very elegant - I think I can do better, we ll see.
Before I make saw dust I need to make a new bench where the table saw will be built in. This will take time and money and I need to find the correct wood. I also need to finalize the plans into printable patterns.
I intend to use 1.5 mm plywood to cut the planks. I am not sure how this will work, this boat's hull was built with steel sheets so it seems reasonable to use ply, provided it can bend both vertically and horizontally to follow the curve of the hull.
Best wishes
Vaddoc
Oh, I've always thought tugboats looks nice. I'm sure this will too.
And even though the Occre is RC, the kit prop just looks awful. We are confident that you can do a better job Vaddoc 🙂
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Good to see we are approaching the wood cutting stage.
This seems to be quite challenging but I'm sure you will pull it off.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Happy New Year to all!
I ve been busy these last few weeks so time for an update. Quite a few things going on.
I could have actually done more but the temperatures have been consistently subzero so my garage is a rather unhospitable place to be in.
So, I have finished laminating the pieces of ply I need but things took a funny turn. The laminated ply that was dead straight, warped. This is the first time this has happened to me. Still, with manual bending the opposite side and heat from a hair dryer, it went back to being almost straight.
Now, I need a new bench for the garage. I already have two but my power tools are very cramped and it is difficult to work. For the new bench to fit I had to radically reorganize the layout of the garage - I am halfway into this.
The new bench will have the table saw built in to sit flush with the top. I tried to design it by hand but finally returned to the warm embrace of CAD!
These are the various groups of timber bits
A big advantage of CAD is that it is very easy to arrange how many lengths of timber are needed and which pieces will be cut from each one
When the weather allows, I ll get down on this. Now, back to the boat.
I glued the template on a flat surface and after lots of thought a sprayed it with a protective spray. Ya, right. That did not work.
I printed the pattern again and glued it on a different surface. I used custom settings and long lengths of paper cut from an A2 roll. However, the printer could not align the paper properly and the printout was distorted
20250104_134941.thumb.jpg.e70c40b5db8d5285333ac21a85347c34.jpg20250104_134946.thumb.jpg.2e24ffa149cb083f0cdc740feab1f2f4.jpg
So I printed the pattern in A3 sheets and aligned them carefully. This actually worked fine, I used a piece of string and all lines are straight.
I also did a lot of work to finalise the frames and other parts of the ship. We ll get to these later in the log.
I glued and roughly cut the templates for the frames. There are many dots and lines for alignment purposes. I ll sand them to the lines with the disc sander when the weather improves a bit so I can have the garage door open for the dust to vent away - however sanding of all the bevels will take a long time.
I finished cutting the keel template which again has many points and lines to allow alignment - each has been drilled through in the drill press with 0.55 mm drill to allow a 0.5 mm pin to go through. The mirror template has been glued on the other side - quite successfully.
I have also prepared some extra pieces to glue on the keel to allow some more area to support the planking. These will also help in the alignment and support of the frames. All the bevels are already marked.
I have ordered some different blades as I am not satisfied with the performance of the Proxxon scroll saw - but then again it comes with a very fine blade which struggles to cut the 6.5 mm epoxy laminated ply.
So next steps: To cut, sand their bevels and glue the extra pieces on the hull. To sand the frames including the bevels. I think I will cut the hull rabbet now before even the frames go on - I have marked all the rabbet and bearding lines.
One thing I could have done differently is the thickness of the hull. In my plans the hull is 3.8 mm thick - I did not want to make it thicker as in the plans, Hercules' steel hull is very slim. However, in the bow and stern, the rabbet will need to be up to 1.5 mm deep on each side so not much hull thickness left.
I still am undecided on the planking.
I think using large pieces of plywood will not allow a fair hull. I may need to plank the hull the usual way.
I d like to cut the planks from plywood sheet but plywood does not cut very cleanly on the scroll saw- there are various other blades though.
I could however use wood for the planks or a hybrid approach - use ply at the bow and the stern and wood in between. We will see.
Till next time
Vaddoc
Vaddoc, you know I admire your work so please don't take this as negative criticism, it isn't!
I think we can make life hard for ourselves sometimes, like all the trouble you went to in order to get the deck profile printed. All I do is plot out the relevant points and draw it. You can use pins at all the mold stations and run a fairing batten (a length of thin section flexible wood strip) around them. This not only shows you any station points that are wrong but gives a guaranteed fair curve to the hull.
I've just built a full sized sail boat this way and it's very accurate and symmetrical.
This is a very nice 1:1 model Bedford! I like the exaggerated sheer at the bow - it should handle rough seas (and lakes) well!
Now, you are very right. This is the way to do it. The problem is that it is very difficult to escape the urge to closely follow the CAD plans with their scary accuracy - I have the illusion the end result will be as sharp as the plans! I ve been watching the Tally Ho videos - incredible what these guys do without using CAD, just with battens and pencils!
The hull is very long and not dead straight. The frames will be pre-beveled before installation and even small deviations from vertical will cause problems - I know, they can be sanded or shimed. In the end it will end up with a batten around the hull but I assume the more fussy (or pedantic) I am with accuracy and alignment of the hull and frames, the less intervention will be needed later. This is my first POB boat and plywood responds very differently to solid wood.
Having said that, it might very well not work - in all my previous boats in the end I ended up eyeballing the fairness of the hull!
Vaddoc
Hi Vaddoc,
Good progress, & this is something of a departure for you - most of your builds have been for smaller planked sailing vessels. I look forwards to seeing how this unfolds,
I did a bit more work on the boat, so time for an update.
@Mark Pearse Indeed Mark, I wanted to build something much larger and more of a proper ship. I actually looked into building Ed's Young America POF, but this would be an extremely expensive project which at this time cannot be considered. I bumped onto Hercules and immediately liked the boat - rest is history! (in the making)
So, I cut the space for the propeller and removed some of the paper template so that the frames can slide into place - they do not actually, all the frame slots need filling as they are not wide enough.
I also cut all the filler pieces for both sides and sanded all their bevels. These are needed to give support to the garboard planks as I will not be filling the gaps between the frames with wood. This went remarkably well, although some of the bevels had complex shapes. I only had to redo 3 out of the 30 pieces.
This is a piece that had to be redone, the disk sander is not forgiving.
I also sanded all the bevels in the frames. It went well but some fairing will be needed for the frames at the middle of the hull. These are all the pieces that need to be glued. This will need a lot of work: the paper template will need to be removed and the surface sanded or scraped to remove the glue residue and the pieces temporarily screwed in to check that the frames can slide between them.  I think I ll use epoxy, it is a messy glue but has great gap filling properties.
The elegant curves of the hull and frames, or alternatively Hercules after a dose of Delayed Mouse Making Potion.
I am assuming that my CAD plans are accurate and that I ve cut the wood accurately. Of course neither is certain. The bevels seem reasonable though.
I will need to cut the rabbet before I install the frames. I will first though glue on the filler pieces, as the angle of their bevel will help cutting the hull bevel. In theory, I have all I need to cut the rabbet accurately as all lines and the interaction of the planking with the hull are marked on the templates. However, chiseling plywood is difficult and requires extra sharp chisels.
Take care all
Vaddoc
"in theory" ahh, such beautiful words, then enter the human factor 😄
Jokes aside, I'm confident that you can cut an accurate rabbet on your Hercules Vaddoc.
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Vaddoc,
I appreciate the work you are doing to get the angles leading into the rabbet just right. However, I found on my MSI hull that the only really important part was the shape (curve) of the rabbet. The planks curved based on the bulkheads and fit into the rabbet without much trouble. At the bow I just filled the spaces between the bulkheads and faired the filler with the bulkheads.
And the way I got the rabbet precisely where I wanted it, and to the right thickness, was to glue keel extension pieces to the sides of the keel, to the top edges of these extension pieces formed the rabbet. I did a little cutting to deepen the rabbet a bit at the bow and on the stern deadwood, but I didn't have to be too careful because it is all hidden under the planking.
Phil
Phil, I have no doubt you are right. It will all be hidden and there is nothing that a bit of sanding and a bit of filler cannot correct. And indeed, a small piece of plank material is enough to just find the shape of the rabbet at that frame. I went through your log and of course your hull came out fine.
Apologies, just going a bit overboard with CAD!
Not to worry though, things will soon revert to normality and will start going pear shaped the moment I touch the ply with a chisel!:D
Vaddoc
Your exploration of the hull via CAD was very interesting, & CAD drawings are useful in understanding the object drawn. Like you, I also used CAD to get an initial idea of the planking angles where they meet the keel, stem etc.
Dear all
I thought it is a good time for a short post, mainly one of frustration.
Hercules true to the name is fighting me every step of the way and so far, is winning.
I ve had difficulties with lofting, difficulties printing the patterns, difficulties gluing them. My laminates that usually come dead straight are bent. My computer died and now, my disk sander started playing up and is in for repair under warranty.
But there is more. The new paper template came out in wrinkles. I suspect the spray glue I ve been using has gone bad as all the paper templates I ve glued so far are also coming off very easily. Strangely, the main pattern it is also off by a millimetre or so. The keel does not fully match the pattern - I really cannot figure out why.
But there has been some progress despite the difficulties. After a lot of sanding and lots of scraping to remove the paper patterns and the glue residue, the frames are dry fitted.
I started gluing the filler pieces, at this stage I will also cut the rabet.
I do need to tidy up a bit but it is far too cold.
Lots of things to do: cut the rabet, align the frames, epoxy them in place, glue the strengthening pieces and very importantly the planking. I thought I would get away with it by using flat sheets of plywood but I am not so sure now. I think it will need to be a proper planking job.
I am not entirely sure how things will work out in the end but it is a fun project!
Best wishes
Vaddoc
