Greg, as a matter of fact that looks more realistic with the listing. Glad she didn' sink.
Respectfully
I’m so glad it didn’t sink!  I actually think it’s grown on me, I will have to amend all the figures to NOT have a list. Interesting that the back base resin, the ink is starting to leach upwards )it looks really cool)
Greg
So back to lernin mode; the layer between is still wet and will not set but it is really hot, so I think the AK radioactive resin reacted with the top and bottom layer, so I’ve separated them now so hopefully that’s going to work as the clear resin top layer is hard
Greg
7 hours ago, RGL said:
So it’s  leeching resin at the join of the pours. Few days in the sun to bake it
"Sun you got sun  -  whats  that thing"
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Looking good for curing.
Respectfully
That’s the thing, it won’t cure! Apparently after 48 hours it just worn so I have a sticky mess. The clear stuff is rock hard, if the bottom is sloppy it can just sit in the base
Greg
It's not the radioactive resin from AK, but the dark earth... That's the reason I was asking about that before. I've been mixing acrylic with sand to create bottoms  in the past and then poured epoxy over it. On 2 occasions it started making bubbles very late in the curing process, which then got those bubbles stuck inside the epoxy due to the low viscosity of the curing resin. I believe acrylic gel reacts with epoxy.
In my latest attempt I'm mixing sand with epoxy to pour the bottom, this also would get any air bubbles between the sand grains stuck inside that epoxy layer when hardened.
High temperature/sun affects epoxy curing, but it's not something that starts it. Too hot and the thing will start to go really bad, too cold and the chain reaction of the two components will slow down and stop. It cures by a chemical reaction, that reaction creates heat, which then creates a good temperature for the surrounding molecules to react. When that heat is taken away by the surrounding environment which is too cold, it stops that reaction. If it's too hot around it, the reaction will go really fast, so the heat created by the reaction itself can not get away and builds up till very hot temperatures, creating a boiling effect.
To get a proper curing you need the good quantities of the components (weight wise), properly mixed and be in the good temperature range. Another thing you need to check is whether the epoxy is suitable for the thickness you're trying to pour, again related to getting rid of the exothermic heat by having enough contact with the environment.
However, considering it didn't harden only on that contact surface, I guess it did react to the acrylic. On the other side, the heat you encountered might be caused by overheating in the sun and perhaps melting something on that contact surface with the bottom? It's also an area far away from any contact with the environment in all directions, so perhaps it couldn't release the heat?
Not sure how to solve that though... Is the upper part contact surface still really liquid? Or is there some kind of reaction going on? Opening it up might have helped to get rid of the heat and let the curing proceed. Fingers crossed!
Roel
Greg, that looks amazing...... and I also recognize several of the books in your bookshelf. Have many of them myself.
Respectfully
Now the lights! Because the resin underneath has still (and will never go off), I’ll protect the electrics with a new piece of black cardboard with a clear piece over the globes. So the plan will be that the green with reflect up under the green sludge to look like radioactive glowing sludge
Greg
Wow Greg, I had to catch up a bit on your dio and have to say, it´s one of the most entertaining and educating logs of the last time. Bummer with the resin not curing. I haven´t dared to use clear 2K resin for models bases until now, but used it with furniture. I always poured not more than one centimeter per layer for proper bubble free curing and less heat emission.
I love your setting with the slimy ground, the sunken barrels and the worn boat and hope, you will pull through that obstacle ridden phase.
Cheers Rob
So as part of the great lie (the can’t on the boat) which fits into the narrative of the story (yes, there will be a story and hopefully a Dauchund ) I want it to look ok like the is suddenly turning in and stopping so I will now sart building up a bow wave
Greg
