Frames mounted . One thing I learned is not to build with oak unless you realy like to sand..Ready to procede.
  Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
A few more pictures. Fairing war tough with the oak.Now I'll will work in a softer wood.
 Thanks Pete
 Best Regards Larry
                           Constellation by AL
NIce work, Larry.
Hi Larry. I agree she'looking really good. That walnut should look nice when finished.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Looking great Larry. I will follow your build log.
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Thank You one and all.I started the inboard planking .This goes really fast.I'll start the beams today.
 Pete I cut the two lines then used a chisel. Then I used a file to fit and smooth.
 Back to work,  Larry
                           Constellation by AL
Thank You Augie.Just about time to go flying?
 Pride comes before the fall.I was rolling along,proud of my work.I tought let me stain the lower part now.
I applied two coats of pre-stain,one coat of natural.Should have been sealed.Then one coat of 50/50% natural and gloden oak.Turned out awful.It just kept getting worse.I finally had to punt and go down stairs to cut some wood and place a verner to cover it but of a little harder wood.
 I did learn something,I never tought I could cut wood this thin on a bandsaw .050 inch/1.27 mm
    On with the learning and fixing mistakes I learn from :D
Best Regards Larry
                           Constellation by AL
Sorry Larry --- winter just really got here.  I did just complete the winter maintenance schedule though ---- so I'm ready.  Almost hate to see Spring come.....cuts down on building time!!!!!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hmm... the first layer does look, shall we say, well-weathered.  Nice save, Larry.
I may have saved the build,
 Mark,I do know how to create that look(Every Thing Burned but This Part look)
 Augie,Snow skis for your planes thats the anwser.
 Pete,Not sure what kind of wood.It could be cherry.When I go camping I buy bundles of fire wood.It must come from some kind of wood working place.They are all boards oak, walnut,cherry and others.I grab the good ones the rest up in smoke.
   Back to more mistakes so I can learn more.   Larry
                           Constellation by AL
Now that looks nice. If you hadn't shown the before pictures it would be hard to tell there were to layers.
Great job.
It's only a mistake if you leave it.
If you fix it, it was trying something different.
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Or you could go for a 'feature' - to show how they did not do things. Better to just do and redo though as most people get a peverse sense of satisfaction from thinking 'that tiny plank took eight tries and hours to get right and no-one will know'
Nice job Rummy. It's looking good.
Ron
Thanks every one. A little more progress.That dang beam arm is quite the hard thing to make.I think it took me a hole day to make and re-make.It came out ok.I did cut out the pattern and tape it on.
 Tomorrow I will work on the carling,hanging knee,and lodging knee.Just listen to me talk. Before yesterday I did not know what these things were.
       Larry
                           Constellation by AL
Looks nice, hope to get to that stage in a few months.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Looking super Larry.  Those beams are a bear and your's came out perfectly.  :cheers:
looking really nice. Well done
Regards Christian
Before you glue those in it would be useful to sand and possibly oil the inner planking. It will get more difficult to do once the beams are in place plus adding extra risk of knocking stuff out. Your choice though..
Joss.
Thank you Rocker and Christian. Mark I would never say perfect, makeup will hide a lot.Joss I took your advice an stained inside.Pete I dont know if it was just the oak I got or what but it was a bear to fair.So just the frames are out of oak.A few pictures of the staining.I think the wood is cherry and I used pre-stain followed by natural.
 Thanks for looking  Larry
                           Constellation by AL
Larry,
the colour of the timber has come up beautifully. The beam arms are a real bugger to get right, yours look fine. Joss is right about getting the sealing done before building over, it might be good idea though, to not seal where the knees will be placed, your glue may not bond to the sealed surface properly leading to joint failure when you can no longer easily access the area for repairs. Hate to tell you this, from the pictures, it appears your knees are incorrectly sited, they should be alongside the deck beams, not underneath them. Check the drawings.
Regards,
Grant.
Larry, looks super.  I like that color of the finish.  However, Grant is right about the knee placement. :(
Thank you Mark and Grant,I will fix or cover my mistakes
My favorite sayings: Plans I dont need no stinking plans and no I don't need a map :D  :huh:    Larry
                           Constellation by AL
