Glen,
The drawing above is not wrong. The question is what to do with the tackles? Which way do they go? Straight down to the deck or to another block under the top.
Constitution has hers rigged with a block under the top so that the tackles lead upwards from the yard.  Then the single hauling part of each tackle comes down to the deck to be belayed at the foot of the mast or the fife rail.
Regards,
Henry
Henry
Laissez le bon temps rouler !
I went back and reviewed other build logs and I can see where some rig the truss pendants just as you describe.  When I read the description and look at the picture from the BlueJacket instructions, I still don't see the the rigging going upwards to the mast top and then back down.  But what you describe makes sense, so I will go back and see if I can reconfigure what I've already done.
In the meantime, I got the main lower yard hung (which means I will need to reconfigure 2 sets of tackle) and started work on the fore topsail yard.  The topsail yards are hung with different rigging than the lower yards.  Rather than a sling, the lower yards have a double block in the center of the yard with 1 line tied off above the crosstrees and the other running through 2 single blocks on each side of the mast just below the trees and then down to the deck.  Here's the picture from the instructions.
The yards is secured to the mast with a parrel which includes a double row of trucks.  I assume these trucks act as rollers to facilitate the yard being raised or lowered.
I'm using 2mm beads for the rollers with the dividers made from 1mm thick basswood.
Here's the fore topsail yard hung with the parrel in place.
And the front view.
Edited by Glen McGuire
Wow - the trucks and ribs look just perfect on the model.  Very nice!
Steve
San Diego Ship Modelers Guild
I can only second that!!
 I third that!
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
OK, I'll continue the thread - fourth!
Seriously, nice work Glen, looks really good, especially the proportions.
cheers
Pat
I think I'll make a half-hearted attempt at 4 frames of a ship and then go to Glen in despair and ask him to finish it for me 😁
I know, the starting point here was by no means half hearted, but if Glen can do it better, why make the effort...😆
Joking aside, regardsless of some historical accuracy issues (perhaps), you're doing a marvellous job here!
Thanks to everyone for the kind words on the parrel.  The biggest challenge was making 1 of those dang ribs and then trying to make 30 more that were identical.  So don't look too closely at them as I don't think I quite achieved 6 sigma in my process variation.  In the middle of it all, I started thinking about @Ian_Grant and the way he's been using 3-D printing on his WW1 Battle Cruiser Restoration.  Hmmmm!
 Hu oh, the cows are gonna have to get used to a new hum coming from the main house. :)
I am an advocate for that, Glen. I fully intend to enhance my next build, the Endurance, with 3D printed parts!
They are already accustomed to a lot of colorful language coming from the house during these builds, so they might appreciate that new hum!
I was in Boston the past few days retrieving my SIBs from the ship model show after it concluded at the USS Constitution museum.  Olha Batchvarov, who is a superb ship modeler with a great youtube channel, took part in the show/competition and put together a very nice video highlighting many of the models in the show.  If you want to take a look at it, here's the link:
https://www.youtube.com/watch?v=d1sGeEI7xfo&t=10s
Winter is an interesting time to visit the Charleston Navy Yard, where the USS Constitution is docked.  All the yards, top masts, top gallant masts, royal masts, and things above are removed from the ship and you can find some of them lying around the yard.  It's a great opportunity to have an up close look and get a real perspective on how large they are.  Plus, some of the rigging is still attached, which is helpful to me for the stage I'm at with this build.
Here are a few pics I took while wandering around the area.  The first is either the main yard or the fore yard.  The jogger gives you a good idea of how long and large the yard actually is.  The Constitution museum is the boxy gray building in the background on the far left.
There was a discussion earlier in this build log about the slings that hold up the main yard and the fore yard.  The question was whether the rope was eye-spliced or looped around an iron ring.  Fortunately  for me, the sling was still attached to that main (or fore) yard so it gave me the the opportunity to take a close look at how it was configured.  As you can see in the pic below, the rope for the upper part of the sling is looped around an iron ring with a throat seizing.  The rope for the lower part of the sling is double-stacked around the yard and another iron ring.  This is basically the way I configured my slings (except I did not double-stack the rope for the lower part), so I feel good about what I've done.
Here's a trailer holding some assorted smaller yards and what I believe is the gaff (painted black) because it has that block in the middle which I would think is for a lift.
The next couple of pictures are helpful for what I was working on right before I left for Boston - the saddles and single-row parrels (single-row meaning one row of trucks) for the top gallant yards.  There were 2 things I was trying to figure out from the BlueJacket instructions.  First, the drawing showed 2 eyebolts, but I was not sure exactly where they belonged.  Second, I could not tell from the drawing if the single-row parrels had ribs in between each truck.  Based on these pictures, the answer is no.  WOOHOO!!  I was not looking forward to making 50 more of those tiny things!
And then there's this.  It appears to be a freshly painted section of the bulwark including the gun port.  I can't see them cutting out a section of the actual bulwark on the ship and inserting this, so I'm not sure what it's purpose is.  Maybe it will be put in the museum?
And finally, some very large timbers lying around.  I'm curious to know what's in store for these giants, but there was nobody around to ask.
Wow, that is some concrete confirmation right there. How fantastic is that to find just what you needed AND be able to get up close and personal with it. Nice!
Thank you for sharing this!   What wonderful access you have given us!!
Steve
Glen,
The large yard in the first photo is a topmast yard.  The lower yards are considerably larger in circumference and length.
The gundeck section was built as a display and the crew sometimes conducts gun drills for the public. It stays out in the yard year round.
Henry
Henry
It is truly amazing to get that close and see how immense those things really are.
That makes sense now.  Thanks for the explanation, Henry.
Yes!  Wouldn't it be great if all of us had such access to the real life version of whatever model we are working on!  Only in our dreams!!
And back to the task at hand.  Without an SIB in work, I've been able to focus on the Constitution and get a lot of work done (although I'm still on impulse power compared to @Knocklouder's usual warp 9 speed!).  The next thing on my to-do list was making the saddles that are affixed to the top gallant and royal yards and provide the buffer against the mast.
Here's one of the yards with the saddle attached and eyepins in place.
Adding the single-row parrel tied off to the eyepins.
Here's the fore topmast yard installed.  20250312_122221.thumb.jpg.6bc2778dbbd3671d7b30d063264269fa.jpg
I was starting to tie off some of the halyard lines to the fife rails at the base of the fore and main masts when I realized the mizzen mast did not have anything near it to off lines to.  A quick peek at the instructions told me I needed to add a spider ring around the base of the mizzen mast.
I had to poach some belay pins from some of the rails inside the bulwark to outfit the spider ring.  My ring is cut in half since the mast is already installed, preventing me from sliding the ring over the end of the mast and into place.
Mizzen spider ring installed.
And then it was rinse and repeat on hanging the remainder of the top gallant and royal yards.  Shortly thereafter, another milestone reached - all the yards are hung!  WOOHOO!!!  :cheers:   :cheers:   :cheers:      I really need @BANYAN to send me some of that Bundy rum so I can properly celebrate these milestones!!
The yards are a bit wonky since I have not added lifts or braces yet.  But I believe she is starting to look a bit majestic now with her arms spread wide!
Well if that ain't the cat's pajamas. You're doing such a fantastic job, Glen.
I agree, she is starting to look real pretty and quite regal. I commend you on your precise work, sir. Very inspirational.
Be over in a jiffy ;)  mate - just have to save my pennies for a while.  Seriously though, your rigging is looking great, clean and proportionate in scale - well worth celebrating.
cheers
Pat
Fantastic work my friend  you have a lot more details than I have on my ship. Maybe that's why it seem that I am going warp speed. :).  Every line looks fantastic  great work, like I said before it will be hard to giver back. Carson definately  will be pleased, it gobsmacked beautiful.
Bob M.  :cheers:
"Start so you can Finish!"
In progress:
Astrolabe 1812 - Mantua 1:50; Golden Hind - 1578-Air Fix.
In queue:
Pegasus - Amati 1:64
Completed:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
Jerry Lee Lewis showed up this week and started banging on his keyboard singing, "Whole lot of hankin' going on!
I haven't done an exact count yet, but I figure I'm gonna need 60 or more of these things.
And that was followed by a whole lot of stroppin' going on.  These are single blocks that go on the ends of all the yards for the lifts and braces.  48 of them for starters.
Here they are secured to the ends of the yards.  The top one in each circle will be for the lift and the lower one will be for the brace.
First lifts to be installed were for the fore and main lower yards.  For these 2 yards only, the lifts run to a double block that is fixed to an eyepin on the mast cap.  That created a major steady-hand test as I had to drill holes for the eyepins in the mast cap with a spinning bit way too close for comfort to lots of rigging.  I could envision one little blip making an unspeakable mess!  But we got through it ok.  Sigh of relief!
Here's the lifts in place for the fore mast lower yard.
And here's the same for the main mast lower yard.
Hi Glen,
I know it's too late for this build, but you appear to be installing your blocks backwards.  The hole for the tackle line should be closer to the top or strop eye end of the block. The hole represents where the line enters to go around a sheave that has its pin or axle in the middle of the block. The line should appear to pass on both sides almost the length of the block and around that imaginary sheave.
Info for the next build.
Regards,
Henry
Henry
Well dang!  You are absolutely right, Henry.  And I agree that it's too late for this build.  I think it's better to be consistent, even if it's wrong, than to have some blocks done one way and others differently.  So I will continue down my errant path.
I was going to do lifts and braces for the all the lower yards, then top sail yards and work my way up.  But I changed my mind and decided to do it mast by mast and complete the fore mast yards first.  Here's the fore mast lifts and braces threaded but not tied off.
And here they are all tied off.
Here's a shot from the front showing all the fore mast yards nice and parallel with each other.  I highlighted the fore mast yards as it's kind of hard to tell which yards belong to which mast from this perspective.
I find the rigging of the fore mast yard braces on the main mast interesting so I thought I'd show some close-ups of how I did it.  The red arrows point to the fore lower yard brace line as it's tied off at the main stay, runs to a block on the yard arm, back to a single block also seized to the main stay, then thru a bullseye seized to the shroud (at least I can't rig a bullseye upside down  😃), and down to the deck.
Here's the fore top sail yard brace and the fore top gallant yard brace as they are rigged at the main mast.  The arrows follow the starboard side braces.  The red arrows follow the fore top sail yard brace and the green arrows follow the fore top gallant yard brace.
 Looks fantastic, Glen.
That is a nice "tutorial" on how it should be done there, Glen. Thank you, sir.
Work continues on the running rigging for the main and mizzen yards.  I was thinking about ratlines while struggling to get all the running rigging in place.   With ratlines, I kind of get in a rhythm and the more I do, the easier it gets.  I find the opposite true here.  The more running rigging I do, the more lines are in close quarters and the harder it becomes to route them correctly and avoid tangles and interference with other lines.
Two examples.  First, on the lift lines for the main mast yards, I did not notice until after I had tied them off to their belay pins that I had routed a couple of them through the foot ropes on the top sail yard.  I also managed to do this same clever thing on the top gallant yard.  Ugh!
So I had to remove and replace the foot ropes for both of those yards.  Here's the corrected main top sail yard.
Second example.   With braces form the main mast yards routing to the stern and braces from the mizzen mast yards routing forward, some things got a bit messy and adjustments had to me made.  In the pic below, the red arrows follow the mizzen top gallant yard brace running from the yard arm to a double block secured to the main top mast and then down to the deck.  According to the instructions, the double block should be attached to the main mast top head where the green arrow points to.  However, when I put the double block up that high, it caused the forward running brace from the mizzen top gallant to interfere with the rearward brace from the main mast top gallant yard (green circle).  So I had to move the double block low enough to keep the braces clear of each other.
There were a few more similar complications, but those were the easiest to illustrate.  After I got all that sorted out, I grabbed pretty much all the clips I own and fixed them to the ends of all the lift and brace lines.  This put everything under tension so I could make adjustments and get all the yards parallel with each other on both the longitudinal and vertical axis.
Here's a side view with all the lifts and braces tied off.  All of them except one!  The brace for the main lower yard extends rearward and is supposed to be tied off to a boomkin protruding outside the ship at the stern.  I kept whacking it with fingers, arms, tweezers, snips, etc, so I decided to leave it off till I get the gaff and spanker boom in place.  That is why the main lower yard in the pic below is a little off kilter.
You will also notice that my mizzen upper stays got sad and droopy on me.  But that will be an east fix after the gaff and spanker boom are done.
I love this perspective from the bow showing off the symmetry and interplay of the running rigging.
