I am building the Nieuport 28 flown by then Lieutenant and later Captain Eddie Rickenbacker in 1918.
The kit looks to be quite excellent with all appropriate markings:
I haven’t built a Roden kit before, but they look good and I’ve heard good things about them.
Building:
1:200 Russian Battleship Oryol (Orel card kit)
Lots of subassemblies getting ready for final cleanup and prep work prior to initial priming and base coating.
I only build in plastic every once in a while, so I’m having to recall some skills.
I will now vouch for Roden’s quality.
There is very little flash and the molding is nearly perfect.
Everything has been going together pretty much perfectly.
I will warn inexperienced builders that there are no alignment pins on the fuselage halves.
I have never built a WWI plane in plastic before.
The rest of them were balsa for me.
Edited by GrandpaPhil
Building:
Thanks for the thoughts about Roden.  Not sure my pile of wingnuts kits will ever be finished, but if I ever work through them, I will try one.  My dad's stash had a lot of Roden models, but keeping the wingnuts ones alone gave me as many WW1 planes as I will have time to build. I'm looking forward to seeing your progress.  Looks like your model is coming along great!!
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
From what I have seen and heard, the Wingnut Wings kits are the best WWI plastic kits ever made.
The plastic and the style of construction of this kit reminds me a lot of the wargaming miniatures that I have built.
Building:
I built the 1/48 Roden N28 in 2018 as part of a WW1 centennial display at the Seattle Museum of Flight.  One feature of the Roden kit that I found interesting that I really liked was that the cockpit is built outside of the fuselage and then carefully slid in place through the front before the engine and cowling are installed.  The N28 is one of my favorite WW1 aircraft due to its sleek lines and that it was the first fighter employed by the American Expeditionary Force.  I think you will enjoy this build.
Wawona59
John
Current Project: Wooden model kit purge
Wawona Lumber Schooner
Quote
Other than a single 1/48 Eduard kit I haven't built anything WW1 other than WNW, so I can't really comment on "best."  I will say they are amazing in terms of their research, detail, and engineering.  They were a little bit on the expensive side, but they occupy me for 3-4 months each, so worth the cost.  Copper State Models has gotten a great reputation as an alternate with the same quality.  I have one of their Nieuport's on the shelf and am looking forward to finding out how good they are.
This one is going to a friend of mine’s office and in one of their display cabinets.
We’re planning on putting a 54mm figure of Eddie Rickenbacker standing next to the plane, all mounted on a wood base with model railroad grass to simulate a grass field.
All subassemblies are made now and awaiting priming and painting.
I test fitted everything a little bit ago.
Everything fit perfectly.
The next step will priming everything black and then painting the interior stuff.
I only have the paints for my anchors for the Esther at the moment, but that will cover most of the model except for the camouflaged exterior.
I need to get into my stash of eyebolts for the rigging and install them before final assembly.
Building:
Nice work so far!  I'll be following along and hope to see more of your work on this project.  I have a Nieuport28 in my stash.  It's the 1:16 Model Airways kit.  I'll get to it someday after I get my current projects finished and delivered to the recipients.
Wawona59
John
Thank you very much!
I have the model initial assembled and know how I want to do the diorama:
The initial base coating for the underside of the model is done:
I wanted to put Eddie Rickenbacker in scale standing next to his aircraft, but that figure sold before I got a chance to but it.
The remaining ones are rather expensive and also in an unsatisfactory pose.
So, I’m just going to make my own!
Eddie Rickenbacker stood 6’ 2” tall, which makes for a 2 5/16” figure in 1/32 scale.
I like this picture so it is the one that I will use:
I have a posable artist’s marionette which I will use to design the carving.
The pose still needs some work and adjustment, but that will get done once I finish the plane.
I have never carved a full human figure before, but I have never let that stop me before.
One thing I learned here is that you don’t know what your full capabilities are until you push your limits.
I have carved/made 3 figureheads, to include the HMS Victory, and 2 sets of stern carvings before.
I carved the carvings for the Revenge and I made a set of stern carvings for the Winchelsea while on a business trip one time (which are unfortunately not in a usable scale).
All came out reasonably well, so…we’ll make some wood shavings when the time comes, and see what happens.
Building:
The initial base coating is done:
It had a 5-color camouflage scheme which I duplicated to the best of my abilities.
I don’t have an airbrush, so everything was freehand brush painted.
I will finish touch ups and minor details, and paint the engine cowling, the struts, part of the propeller, and the vertical stabilizer, white the next time I work on the model.
Then it’ll be time to add some eyebolts and decals, attach the upper wing and on to rigging!
Then it’ll be carving time!
Building:
looks great!  I can never get my brushing to look that good.
Excellent progress and I can see why you chose that particular picture as the basis for your carving, that is a good pose.   I'll be interested to see how the carving goes.  I've dabbled in a little bit of wood carving over the last year, carving a couple of dogs and a penguin.
I had the model about 90% complete:
And then I had a disaster.
I noticed the port side aircraft number (within the squadron, not the tail number) was wrinkled and my attempt to repair it nearly destroyed the model.
Root cause analysis:
I have not built a plastic model in a long time and forgot the nature of water transfer decals.
I should have let the model dry overnight prior to sealing and then tried to install the upper wing.
I plowed ahead.
Bad decision!
My efforts to straighten out the decal resulted in the stripping of the paint from the area and destruction of about 1/3 of the decal.
I also busted the upper wing loose.
Fortunately, all is not lost!
This is salvageable.  Believe me when I say that I have worked with far worse (my Solferino was a near total loss a few times, among other models), and made models that I have been, or would be, willing to display publicly.
Time to repair all paintwork/markings and then let it sit overnight before I seal the model.
I will then attempt to use the original wing struts one more time and then replace them with wood utilizing steel pins as guide pins.
Building:
Sorry to hear of your woes  with this,  I have been in this position myself  - far to many times, I am sure  you will rescue it.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you all very much for the moral support!
It is always disheartening when that happens, but it is an opportunity to improve at the same time.
I fixed my paintwork yesterday:
The Admiral found a couple spots that need touched up, so I am going to fix those, let the model dry for a bit and then seal it.
In the meantime, I’ve been working on a papercraft 1/467 USS Sulaco, from the Aliens movies, that I found over on the Paper Modelers forum.
I started it right after finishing the Solferino, about 22 months ago, prior to starting the Revenge.  I found it while rearranging the house and decided to clear one of my started projects off my slate.
I may make a build log for it at a later date depending on how it turns out.
I have been working on it for a month or two now.
Building:
The upper wing is on and the base is made!
Now, I need to do a final round of touch ups, sealing and then apply a highlight coat before gluing the model down once the base dries!
Also, I now need an Eddie Rickenbacker.
Captain Rickenbacker stood 6’ 2” tall.
Allowing 2” for his hat and the soles of his shoes, that makes for a total height of 76”.
At 1/32 scale that is 2.375” or 2 3/8” and approximately 3/8” thick by 3/4” wide, assuming normal proportions.  Allowing for the leg crossed over, we’ll start with 1/2” thick.  The arm will be carved separately.
Building:
Dont know if this is any use to you Phil  -  its  1/30   scale.
OC.
https://squadron.com/1-30-campaign-miniatures-captain-eddie-rickenbacker-model-kit/
Current builds
Completed works.
48 minutes ago, GrandpaPhil said:
Carving failed, I just ordered that one.
Thank you very much, OC!
Glad to help Phil.
OC.
Current builds
Completed works.
The plane itself and the base are done:
I treated the rigging exactly like stays on a warship.
I used cotton thread treated with beeswax.
I might get EZ line later on to try out, especially with the number of early 20th century warships that I have sitting in my stash.
Now, to wait on my Eddie Rickenbacker figure to finish the diorama.
Building:
Thank you very much, Alan!
I got the Eddie Rickenbacker figure in the mail today!
It’s a super nice resin kit.
This is my first Campaign Miniatures figure kit, but it is definitely top notch.
Building:
That figure looks  top notch  - cant wait to  see him made and painted Phil.
OC.
Current builds
Completed works.
