Ok, so it seems my Chevy FFW truck build is back on the back burner waiting for replacement parts. I've gotten about as far as I can with it, so I've been looking for something to help pass the time. About a year ago or so, I picked up this kit as my GF at the time had expressed interest in trying to build a scale model, so I had bought her the Airfix Spitfire starter set, and I got myself this one so I could build along. Well, things didn't quite pan out and the situation changed over the summer, shall we say.
I had built the earlier iteration of this kit, so I have a pretty good idea of what I'm getting into.
Four sprues of the new Airfix dark grey plastic, along with one clear sprue containing the canopy parts. It's still a fairly new tool, so there's very little flash to speak of.
I purchased some aftermarket decals to do a Canadian Spitfire. Kitsworld have a pretty decent set:
Spitfire EN921, YO-A from 401 Squadron RCAF.
After checking over the parts, the first order of business was to engage in some hacking and slashing. The Airfix kit is a MkVc and the plane I wish to model is a MkVb (that's not a typo in the build title!). To change a C into a B requires the removal of one of the cannons as well as a reduction in the blister in the wing. As you may have noticed from the photo of the kit parts, both the regular and the clipped wing are included. EN921 was a clipped wing Spitfire. Fortunately, I had saved the leftovers from the last time I built this kit, so I felt free to hack and slash without fear, as I had a backup in case things went wrong.
The two canon blister is enormous. I'm not sure how accurate it really is, but no matter, it's going away!
I taped around the offending blister and began to sand it away using some pretty coarse sanding sticks. It didn't take too long to smooth out the blister. Airfix moulded a recess on the underside of the blister, and this was perilously thin after the initial savaging. Looking at it, it's about the right size, shape and almost the right location for the single canon blister on the B wing Spitfire. Using my knife, I cut away the remaining thin layer of plastic, and opened up a big hole in the wing.
Using some styrene sheet, I cut out the approximate shape and sanded it to fit snugly into the hole, while at the same time leaving the new blister proud of the wing surface.
Using some fire sanding sticks, the new blister was given a pleasing aerodynamic shape.
You can see the difference in the blisters, as well as the different plastics that Airfix use. Overall I'm pleased with the results, and I will use the older parts in place of the new kit pieces. I will fill the extra holes for the canons after assembling the wings, later on in the build using the kit parts themselves.
I'm sure the purists will point out a whole plethora of other differences between the two types of Spitfire wings, but I'm happy enough getting the bit details sort of, more or less, almost but not quite, correct.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
17 minutes ago, amateur said:
(something completely different: you once started a model of a great lakes self-unloader. Did you ever finish that one?)
Jan
Oh, wow, yeah, that’s going back a long time. Honestly I haven’t touched that project in years. Because of life circumstances, I’m no longer a member of the model railway club for which it was intended. The model has been sitting in a closet ever since.
Andy
Edited by realworkingsailor
USF Confederacy
I'm not a purist, but I suspect some of our members may not know the significance of the a, b, and c (and later e) in Spitfire parlance. These were not sub-variants, as seen for example in designations like P-51D or Bf-109G, but rather indicators of the type of wing used on the aircraft. Each wing could accommodate a different armament configuration:
  • a wing: eight .303 machine guns
  • b wing: four .303 machine guns and two 20mm cannon
  • The c, or universal, wing could be configured with the a loadout, the b loadout, or with four 20mm cannon, as well as bomb racks.
  • The e wing could take four 20mm cannon or a pair of cannon and two .50 cal Brownings.
Personally, the clipped wing Spitfires have never caught my fancy, which is why I don't have the Halinski Mk. XIV in my stash, but the clipped wing improved roll rate, so I can understand why they were built.
Cheers!
Cheers!
Thanks for contributing the explanation of the various Spitfire wings! I’m sure I would have got that in somewhere, but no I don’t have to 😁!
The clip winged Spits aren’t really my favourite either, but it’s different enough from the first time I built this kit that it’s not a total repeat. I would still rank them above the high altitude wing, though… those look like the result of a spy who tried to copy the original wing and didn’t get things quite right….
Andy
USF Confederacy
Thanks for the likes and kind comments!
Having built this kit once before, work has proceeded reasonably quickly, only the wing mods are "new" territory. As I mentioned earlier, I was satisfied with my canon blister mods, so I kept the older wing upper surfaces.
Skipping ahead in the instructions, I went and made the wing assembly. After adding the parts for the wheel wells, I set about removing the small blister on the underside of the wing and then filling the spent casing ejection port.
After these had been sanded smooth, the wing assembly was completed. Part of the reason for the skip-ahead was waiting for the paint to dry on various components of the cockpit and fuselage sides:
Of all the 1/72 Spitfires I've seen, I think this Airfix offering has one of the most out-of-the-box detailed cockpits. All of the components find in a two-piece lower cockpit tub. I used a Tamiya rattle can to spray the silver/aluminium, then Vallejo interior green for the remainder of the parts, along with some Vallejo black to pick out various controls as well as the instrument panel. Yes there are some ejector pin marks (rather prominent after a black wash), but rest assured, they will invisible after assembly.
A lot of work that will be eventually hidden away, never to be seen again. But that's the way we like it!
After the cockpit is assembled, the fuselage is next. The fit is excellent, the seams will only need a minimum of care afterwards.
I went back to the wings to finish up the last outstanding issue in the conversion, the extra canon barrel and hole in the wing.
Airfix provide options for the "C" wing that include either the full canon barrel for those armed with four canons, or the nub that covered the vacant mount when only fitted with two canons. I fitted the upper half of the canon stub, and when the glue had dried, I snipped of the nub and sanded everything down flush with the leading edge of the wing.
Time to glue the wings to the fuselage!
From what I've seen online, early builders of this kit had issues with a prominent gap at the wing root. I've built this kit twice, both the early and now the second release, and I've never had this problem. The way I see it, the gap issue could stem from three possible problems. First, not seating the upper wing properly on the lower wing, as the upper wing fits overtop of the lower wing (if you look at the second photo I posted above), there is the chance for the upper half of the wing to slide ever so slightly outwards when glueing. Secondly, there may have been a slight warp in the lower wing half that would have decreased the dihedral angle. Finally if the builder was too aggressive when assembling the fuselage and they accidentally pinched the bottom too aggressively to the cockpit tub. As it is for both my Spits, I've done my best to be aware of these issues, and my fuselage and wing joint has been tight every time.
After adding the wing I added the lower engine cowl and carburetor intake. The last time I built this kit I had to use the Vokes filter, a rather ugly affair that spoils the Spitfire's nice lines. This time around, I got to use the more sleeker setup!
Finally the last bit of assembly was the horizontal stabilizers and rudder:
The stabilizers fit nicely into their little slots, and the rudder fits nicely into a little groove at the back of the tail fin. Nothing unusual here. Everything fits nice and snug.
The way things are going, I'm going to be looking at paint very soon. I'm going to hold off on adding the radiator and oil cooler until after painting, that way I can ensure that the radiator details can be properly masked when painting the underside colour.
Thanks again for the likes and comments, it's very much appreciated!
Andy
USF Confederacy
Great progress Andy, I have also built this kit last year (just did it out of the box and with the box top scheme decals), a nice little kit and as you have been finding with your two builds of it, it goes together really well. 😁
Andrew
Completed (Kits):-
Well, it's been a short while, but I have not been idle!
A major chunk of the painting has now been completed! Yay!
Nothing too fancy, just the typical mid-war RAF fighter scheme! The disruptive pattern on the Spitfire I'm intending to replicate (EN921) looked a little different when compared to the usual pattern's I've seen before. I did my best to follow the very few photos available online, plus I referenced diagrams from another decal set that seemed to agree with those same photos. Most other models I've seen built of this aircraft followed the more conventional RAF pattern, but EN921 had something odd going on around the cockpit. I guess the guys in the maintenance unit were bored with the same old same old!
Back to the Airfix kit, I eschewed the use of the supplied decal sky type "S" coloured band around the tail in favour of paint. I did this a couple years ago on a Typhoon and it produces a much better result. After a few touch ups, and once the paint has had a good chance to cure hard (Vallejo acrylics seem to take their sweet time to fully cure, until then the paint can be frustratingly soft.... ask me how I know....), there remains only to apply the yellow leading edge stripes on the wings.
Thanks, as always for the comments and "likes"!
Andy
USF Confederacy
Some people might think that the same two-color scheme applied over and over again to every type to enter service would be kind of boring, but it's such an eye-pleasing combo that it makes everything look good! Throw in some roundels, recognition bands, unit badges, and kill tallies and, as the English would say, "It just works!"
Wait until you see the nose art that goes on this plane!
USF Confederacy
A small update to add for this week.
The wing leading edge yellow stripes have been successfully painted on:
Once they have had a good few days to cure, I have to do something that may defy all logic!
66b0af40927744be9d88b3f0_60fa873548f86dff3383f2ce_FO-Jack-Sheppards-401-RCAF-Squadron-aircraft--YO-A--with-the-girl-on-the-.jpeg.fd188fb464ddb9b48de514a3351d2521.jpeg
(RAF Photo UK5800l), borrowed from the following web page: https://www.silverhawkauthor.com/post/canadian-warplanes-3-supermarine-spitfires-flown-by-the-rcaf-overseas-during-the-second-world-war-on-loan-from-the-raf
Going by the above prototype photo of EN921, the paint on the wing root walkway area was pretty heavily worn. This plane saw a lot of use while with 401 Squadron. I have planned ahead for this scenario, hopefully things work the way I want them to! Details, and photos will follow whether I succeed or fail!
Thanks for the kind comments and all the "likes"!
Andy
USF Confederacy
Good job on this!
I built the 1/72 Tamiya Spitfire kit a couple years back and it turned out OK.  I like building at a bigger scale, and basically used it as practice for the next Spitfires build - the beer run kit from ICM.  This kit had quite a few issues, and I never did finish it, found the plastic soft and had some fit and gap issues.  I still have to open and get started on my Eduard 1/48 Mk IXc kit.....  it has the option to build the place as flown by Canadian ace Jerry Billing who happens to be from my area - and our local junior hockey team's logo is based off a Mk IX Spitfire too.
I find the 1/72 too small for my liking, but your build is looking great.
Thanks @JKC27! It would be great to see your Spitfire build(s) here (if you feel up to it)!
So my experiment seems to have worked!
I think that looks fairly good as a worn walkway. Admittedly, it looks a little stark, given the lack of weathering on the rest of the airplane, but that will be fixed in time.
After I had put down a layer of primer, I hit the wing root area(s) with a shot of Tamiya aluminium from a rattle can. I was counting on the Tamiya paint drying to its usual relatively hard finish. The Vallejo acrylics dry (initially) very soft, so I gently started scraping away the acrylic paint with a bamboo skewer to expose the Tamiya paint underneath. I initially smoothed the edges out with some ultra fine grit sandpaper, following that I dry brushed on some Floquil aged silver (a very close match for the Tamiya Aluminium) so further soften and blend the edges. This all has to be done before I overcoat the whole plane with Testors' Glosscoat, as the enamel will make it too hard to scratch anything off easily.
The reason I used this technique is that I don't have any chipping fluid or other substitute in my stash, and I had seen this used to good effect by Youtube modeller Plasmo.
This morning I turned my attention to the exhaust pipes. If there's one thing that looks off about this kit, I would say that this these are it. Looking at the plethora of prototype photos, the Airfix exhaust pipes stick out way too far.... almost like a set of canards. They really ruin the lines of the airplane. You can see above how far they stick out!
Luckily the fix is fairly simple, and some careful work with an aggressive file had my exhaust pipes looking mush better!
On the right, in the above photo is the unmodified part, quite a difference when compared to the treated pipes on the left!
Both sets of pipes have now been given the same treatment, and I think things are looking much improved!
Up next will be some final paint touch-ups (kind of an ongoing thing), then a layer of gloss and decals.
Thanks for the kind comments and likes, as always they are very much appreciated!
Andy
USF Confederacy
After yesterday's excitement of finally receiving the parts I need to continue with my C15 build, I figured it is now a good time to update my progress on here.
Decals are now finished, including a plethora of stencils. Admittedly, I didn't include some of the smallest ones, as they tend to look more like specs of dirt than anything.
As you can see, I have also added the propellor. (I just had to get the spinny whirly turny bit on!)
EN921 had some... uhh..... racy nose art. Maybe a strategy to distract German pilots??
Underneath is grey...... very grey...
Next up will be the landing gear, pitot tube and aerial mast, then weathering and finishing touches. Looks like the end is in sight for this one!
Thanks, as always, for all the "likes"
Andy
USF Confederacy
Unusual to see a Spitfire with such "prominent" nose art! 😆  Good job Andy! :imNotWorthy:
Andrew
Completed (Kits):-
Thanks for all the kind comments and "likes" everyone!
I think I'm ready to call this one done!
After sealing everything in, I applied a little bit of a wash in some of the panel lines and recessed areas. I then dry brushed on some aluminium colour to add a few more signs of worn paint, especially around the starboard wing root and canopy areas. Finally I did my usual soot and heat staining using pastels applied with a brush and blended.
For this plane, I had to go easy on the engine exhaust. From the prototype photos, the lovely lady was reasonably clean, and likely kept that way by the ground crews.
Yes, I decided to add the figure in the cockpit. Even had I left the canopy open, there really wouldn't have been much to see, so with the canopy closed, there's a sign of "life". Spitfire EN921 was assigned to 401 Squadron, RCAF, between July and October of 1943. During its time, it wore the code YO-A and was flown by F/O Jack Sheppard. Over the course of the war, he scored 5 confirmed "kills", all FW-190s.
The wear on the starboard wing would not have been as heavy as the port side, but there's photos of the ground crew standing there, so some foot traffic should be evident!
Overall, this has been an enjoyable, and short little build. As a fairly recent Airfix product, there is an abundance of detail for a 1/72nd scale kit. I encountered no major fit issues beyond what one would reasonably expect for a plastic model. I wouldn't hesitate to recommend this kit to anyone who's interested. A word of note, however; the Kitsworld decal set that I used for the code letters and the nose art appears to be printed, rather than silk screen printed. This means that if you examine the decals closely, there is a grainy-ness to the colours. It's not noticeable from any normal viewing distance, and the decals are still very high quality.
Thanks again to everyone who has stopped by and offered their likes and comments (and thanks to those who have simply stopped by)!
Looks like I will be returning to my Chevrolet C15a build very soon, see you all there!
Andy
USF Confederacy
Excellent finish Andy. I know, as some have said on here, clipped wing Spitfires are not to everyone’s taste, so it is nice to see one done. :imNotWorthy:
Andrew
Completed (Kits):-
