Michael, sounds like John did it first but he didn’t tell us which boat he did it on, and anyway I was hoping to follow your lead.
Oh... as soon as the cap is glued I will take a stab at it pictures too.
Michael
So now it’s time for the hawse holes and hawse pipes.
One of the old pictures is looking straight down the hawse holes and it is taken from the top of the sampson post.  I placed a yolk at the sampson post location and used it to guide the drill.  I enlarged the holes to accept a brass tube 9” scale diameter.  After flaring the outside, the tube was cut to length and an oval washer soldered to the inside.  The last two photos show the bow sprit temporarily in place.  I have to admit there was a problem the old picture was of the Lettie after the fore deck was raised.  But my model has the fore deck lowered.  So I drilled the hole in the wrong place and had to raise it to put it into the correct location.  All good now.
Next the chain plates.
Bob
Current build:  SS_ Mariefred
Bob what an excellent job on the flare, that looks fantastic.
Michael
Looks good from here..... maybe a little wear marks from chain paying out. ;)
S.os
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Russ, Michael, David B, S.os, John, Elia, Thank you all for the kind words.  And thanks to those who click on “like”.  I know how it is to not know what to say.
Michael, Thanks for showing us how to make the flare on the pipe. I rounded the point of a nail and used that as the chasing tool.  Not as nice as your tools, but it worked.
S.os, Yes, I like working boats.  Even when I sailed I always bought older boats.  I don’t know if that’s because I feel they should look lived in or if I’m just not careful enough to make them look new.
Bob
very nice job on the hawse hole.......now I see what you were getting at  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye.  We all need help now and then.
Bob
your Lettie Looks great Bob,
well done !
I am expecting a most beautiful created and built schooner under your Hands
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Allan.  That’s why I’m with MSW.  To learn how to do this kind of thing.
Nils, that’s what my admiral is expecting too.  She already has a place for Lettie and says she wants to see lots of gold.  So I won’t be painting the brass.
Bob
My sentiments exactly.
Michael
Just remembered.  Now I have to go back and take the paint off the pintles and gudgeons.
Bob
As I said before, “SHE wants GOLD”.  Now I come to the cove that should be gold.  I looked into gold leaf but not only is it expensive but I don’t need near that much.  Yellow paint isn’t the same and I’ve never seen a gold paint that came close.  Besides with my hands I could never paint a straight line.  So here comes brass.  All I have to do is fasten a strip of brass . . . but I read topics here saying how do you fasten brass to wood?  There are probably many ways but here is how I did it.
The stripe goes in the cove line or in my case where the thin bulwark strake and the wide strake meet.
My plan was to solder .188” of the tip of several .024” brass plank nails to a .032” brass rod.  This is still up in the bulwark area so fasteners had to be placed where the stations are.  I drilled .020” holes into the stations.  I measured the hole locations and soldered the nail tips at the same distances and found out that if you are off by even that little the brass rod doesn’t fit properly.
On to plan B.  I placed the nail tips in the holes leaving about .06” exposed.  Then I soldered on the brass rod and pushed it tight against the wood.  I then filed a flat on the exposed part of the brass to catch the light.
Thanks for the help Nils.
Bob
Drilling for the nail tips.
A nail tip pressed in, waiting for solder.
Rod soldered to nail tip
Edited by Cap'n'Bob
Very sharp Bob, so is that some heat resistant paint that you used?
Michael
Nice soldering Bob.  If you go to Michaels you will find metal leaf kits at a very decent price.
David B
Thanks John, that’s what she says also.
Michael, the paint is acrylic covered with Pledge/Future.  60/40 solder and a low temp solder iron.
Thanks for the info David, maybe next time.
Bob
such a neat idea!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye.  But I got help from the forum.
Keith, I only hope it doesn't become a target for pirates.  ;)
Bob
Bob
It Looks great Bob,
can`t wait to see the fixed rods when pollished in Close ups...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Nils, I can't either.
Bob
You might just have given me some ideas there Bob, excellent!
Steve
I joined the forum to get ideas.  Turns out when I learn others do to.
Bob
 Bob and Steve this seems to be the order of the day.
Michael
