Take a look here Jim from Dafi's Victory build...shows it nice and clearly and I'm sure is spot on.
http://modelshipworld.com/index.php/topic/76-hms-victory-by-dafi-to-victory-and-beyond/page-52#entry233564
Cheers,
Jason
In the shipyard:
Managed to do some work on trying to 'rig' up the nun buoy by using Dafi's build as a basis, thanks for the link Jason. Will follow up with photos tomorrow hopefully.
Biggest news is that my display case has arrived. Ordered a wood base and acrylic cover as a set from www.widdowsonsltd.co.uk cost £108. Looks the business but got a 'minor' modification to make, so will do quintuple check before I commit but should look awesome and different to anything I've seen.
Few little touch ups and last few coils to add to belaying points and I should be done...!
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Pictures as promised!
This is the display case I received yesterday. Still some work to do on it though......
Here is the first nun buoy attached to the fore shrouds by two coils of rope. Thicker rope attached the bottom of the buoy is also lashed to the anchor.
And finally added guy pendants to the boom.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
And the build is complete!
Got all the little bits and pieces finished. Painted all the rigging hooks, added the second nun buoy and rigged to the shroud and anchor, added the last belaying coils and touched up the white paint around the rudder hinges.
Really happy with the completed build, and while it is not strictly my first build, it is my first completed build and it feels like a major accomplishment. I've added some images of the completed build itself but still got the completed to case to unveil!
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
And onto the second of my completed build posts!
The last part towards completion was the case. I've hinted that I was going to try something a little different and I'm immensely happy to say that I managed to complete the case without any mishaps. And here is the final result:
I ordered a wooden base and acrylic case from a supplier and also a sheet of blue acrylic. The sheet of blue acrylic was to simulate water level and I measured up the approx. dimensions of the ship at the water level and then deducted a few mm to be safe. I then cut out the approximate shape of the ship from the acrylic sheet. Then spent a long while iterating towards a good fit, using a dremel and then files, so that the ship rested in the acrylic sheet at the water line.
Once this was complete (and I polished out the scratches I accidently made), it was onto the main case. I need to drill four small holes to fit 10mm lengths of 3mm diameter acrylic rod through each hole to act as a rest for the waterline sheet. This was the most tense section as I could easily write off £80 worth of acrylic case. Stacked a load of old paperbacks and a piece of wood to brace the acrylic against. Then VERY carefully drilled a 1mm pilot hole by hand. Using the pilot hole I then used the dremel at its lowest setting to drill 2mm and then 3mm.
Everything worked out well and I'm very pleased with the final result.
Thank you to everyone who has followed the log and provided encouragement and support. Now I really must get back to my Snake build.....!!
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
I really  like the acrylic sea. A most pleasurable build to have followed. Many thanks!
Tony
Thank you all for the compliments and the likes.
Eamonn - hope you can see now why I kept this under wraps, there was massive potential for it to go badly wrong....! And that was just the waterline, yet alone drilling into the expensive case.......
Stergios - I will be back onto the Snake in a week or two as I have another unrelated project on the go that I really need to complete. I may post details on the off topic section once I am done.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Can totally understand the problems Jim, I've tried working with that material before  and the word 'Shatter' comes to mind  :P  :P  not something you'd want to do considering the price.. She looks a treat Mate, if my little Ballier comes anywhere near I'll be well chuffed !!
I guess it's onto Snake for you next then..   btw do you have any other builds waiting for the off ? (I just spotted that you mentioned a 'side project')
Congratulations on Completing Ballahoo !!  :D  :D  :D
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Side project is an electronics project I am putting together.
Came off the back of investigating using a micro controller to create flickering LEDs as lanterns on ship builds, something I will incorporate into my Diana build when I finish Snake. I saw using the micro controller to control LEDs in other ways, mainly for creating LED cubes to create a decorative 'show'.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Jim, your Ballyhoo came out great, congratulations!  I really love that case, wow!  Very creative and well done.  I was thinking of doing a diorama type case for a later build with a fake sea, but your approach is very simple and elegant.
Edited by Landlubber Mike
Very impressive Jim, you should be very pleased.  Love the look of the case, well worth the effort and the risk.  Well done on your first completion, a milestone I have yet to reach...
Cheers,
Jason
In the shipyard:
