Great seeing you back with your work story.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
At least the deck was not fixed yet as I have to fix some details still.
But in order to be looking smart, neat and tidy, the stern needed some attention. Great o the outside but the inside ...
... still quite worn, so I ground down the old paint and rediscovered the two square holes on the top that I added eons ago to fix the stern quarter davits, but scraped them later as newer research omitted them.
Looking more cute. See the two metal bits on the top?
Then had to fit the stern part. Great to have good tools.
Never thought to use a plain on my plastic tub 🙂
To be able to still look inside later on, I hid two magnets in the side galleries, fitting the two metal bits 🙂
Then came the cover of the tiller head ...
... build the box ...
... removable of course 🙂
And to give a good fit, a frame on the deck was to be build. Quite tricky in that size, so did an external work on some paper, that was removed by being made wet later on.
Searched for the wheel and the binnacle, made in February 2012, made a small base ...
... and also smartened the anchor cable for protection ...
... and the deciples came to praise her!
And then simply he simply took the model with him ...
... I needed to be strong then ...
Edited by dafi
Do all good things have to come to an end?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Be strong, I had to be too.
XXXDAn
World best Drama Queen 🙂
XXXDAn
Oh it did hurt to see her all alone in the back of the car going to a big trip. What happens if she was bored? Thirstty? Hungry? Or needs a p-brake???
And off it went for the journey, a 1000 km across France to Rochefort. Straight into ships paradise, together with another 150 models and proudly showing the flag ...
... of the german delegation together with the Amerigo from Joachim/Schiffebastler:-)
Rochefort-181017-Ankunftsrundgang_9690.j
Later still came Chapman´s barge from Alexander / Foxtrott ...
... and the Sphinx from Alexander / Alex M. ...
... and me I was obsolet as the kids played all by themselves.
So I used the time ...
... to go and see her great-great-great-...-great niece ...
... together with the other german ship parents that did not have to bother for their small ones 🙂
Yes, in that order!
XXXDAn
And what we saw on the Hermione can be seen her on yesterdays slide show on Modellmarine.de
http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=hermione-rochefort&Itemid=55
XXXDan
Edited by dafi
it was great to see all this activity Daniel......but you did.....you had me confused for a moment there  ;)   I shoulda known......
more of your fine workmanship,  and a trip too! :)    definitely a model to marvel over!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I fell for it, oh well worse things did happen at sea
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Funny enough the organisators eliminated all references upon Heller and plastic from the model description.
Honi soit qui mal y pense 😉
Here a shot down the rabbit hole when she was in France, displaying proudly her colors on Trafalgar day!
Rochefort-181021-Ausstellung-4-2_1792.jp
Rochefort-181021-Ausstellung-4-2_1790.jp
Rochefort-181021-Ausstellung-4-2_1791.jp
XXXDAn
Edited by dafi
Amazing work  - its like watching a set of films.
OC.
Current builds
Completed works.
For those also interested in Marine aviation, there was a nice report from the museum in Rochefort at modellmarine:
http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=rochefort-marineflieger&Itemid=55
Enjoy, XXXDAn
I love the cropping of the title on the homepage
... by dafi - Hell!
Edited by dafi
Despite all this  X-Mess-stress I found a small space for some advent tinkering 🙂
Started as usual in the smaller scale ...
... and then scratched the fitting Brodi-Stove for it by some scrap materials.
Then some trials ...
...for the BBQ-skewer holder and some brass nibbling ...
... bent ...
... and the skewer itself by filing a round brass into a pointed square section.
Some trials in soldering but finally it fitted :-).
The exhaust air propelled skewer drive was easy ...
... but fitting a 1 mm hole for the external axle bearing into a 1 mm brass profile needed the magical trick of flattening the material before drilling :-).
Then some handles and the handrail around and soon some paint could be applied.
I think I will go for a nice eloquent black 😉
Always remember: no food - no fight 🙂
XXXDAn
Edited by dafi
Daniel........the rivet counter in you is showing!  ;)    what a beautiful stove!.........such detail!    very.....very well done  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Sirs, very indulgent 🙂
Others were not. "Too uneven", "roasting spit too thick" and "handles meant for giants"
So out the scalpel and flattening all uneven surfaces and corners, getting the soldering iron out and eliminating the oversized spit.
Filed a new squared and tapered spit onto some 0,5 mm brass wire.
Inserted a new smaller bearing into the spits driving wheel ...
... and mades some more ergonomic handles.
The result looks like this:
Hope that is fine now 😉
XXXDAn
Edited by dafi
Looks fantastic from here, Daniel.   A coat of paint and finished.
Hi Daniel,
Great work!
stove looks nice, such detailed !
Carefully stadied  her fotos from France,you posted above - fantastic job you have done!!!
Wish you all the Best!!!
Merry christmas and a happy new year!!!
Kirill
Edited by kirill4
Thank you Mark and Kirill and all the "likers"  🙂
And we stay hot!
Did not realised that a whole bunch of my pictures has been published in Modellmarine.de
So as a small X-Mess surprise, here are the pictures of the great modeling exhibition in Rochefort last October:
http://www.modellmarine.de/index.php?option=com_content&view=article&id=5410:1er-congress-international-de-modellisme-navale-in-rochefort-teil-1&catid=215:ausstellungen
Part 1
http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=rochefort18-1&Itemid=55
Part 2
http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=rochefort18-2&Itemid=55
Part 3
http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=rochefort18-3&Itemid=55
Enjoy 🙂
Merry X-Mess, XXXDAn
Edited by dafi
:))) ...small X-Mess surprise... :)))
Daniel,
This is Big X mass surprise!
Thank You very much! :)))
Very much not "small" Daniel.   I think Wow sums it up.  Looks like I'll be busy going through the exhibition for a day or two.
Amazing work  and Well done,    all the best to and yours over xmas.
OC.
Current builds
Completed works.
Wow, doesn't it sum it up at all.  I'm speechless.  I think after looking over the exhibition I'm going to shut down my computer and wander off... totally overwhelming images of superb models.
And my small big one among 🙂 What an honor this was!
XXXDAn
As the small side projects are an integral part of my build ...
... I checked the wardrobe ...
... and picked some parts.
What is he up to now?!?
XXXDAn
