HMS Snake by Beef Wellington - FINISHED - Caldercraft - Scale 1: 64 - First wooden ship build
Happy Birthday. May you have many many more.
Mort
Current Build - Caldercraft Victory
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society
Link to comment
Share on other sites
You can see in the picture below how even after fitting these, the bow grating does not lie correctly and would interfere with the bowsprit, simple adjustment to make but required a lot of dry fitting with the appropriate parts to get it to look right...
Hi Jason , please could you explain the adjustment you talk about above. Is it simply a matter of enlarging the slots or do you have the trim the vertical supporting parts to allow the bowsprit to fit?
Previous build -  HM Schooner Pickle
Current build -    HMS Snake 1:64
Future Build -      Sergal Cutty Sark
Link to comment
I think this picture at link below best illustrates it and attempts to explain.  I found the slots needed to be enlarged to the rear only , don't think any adjustment is needed to the other parts.  Hope this helps.
http://modelshipworld.com/index.php?/topic/509-hms-snake-by-beef-wellington-caldercraft-scale-1-64-first-wooden-ship-build/page-8#entry35607
Cheers,
Jason
In the shipyard:
Link to comment
Did you not trim the aft of the bow grating (60) , as you can see in my photos below the gammoning slots in the grating do not match with the stem in the slightest ( unlike yours which is only 1-2mm out), and the forward head rail frame blocks the front of the gammoning slot in the bow grating. Although you might not have adjusted any other parts on you snake, do you think I need to adjust mine so that the bow grating sits further back??
Thanks for you help!!
Pete
Link to comment
Pete - I'd suggest dryfitting with the "Bow Upper Railing" (Part 58) to determine the fitting, these need a little shaping/sizing.  Given these need to meet at the bow, fit the sides of the grating and join the hull correctly I used these to determine the placement of the grating first as this seemed most important, and once that was done then figured out the gammoning slot placement.  From memory, what you are showing looks similar to what mine did, I may have taken a sliver off of the rear of the grating for fine tuning but no major shaping.
I did adjust the height of the Bow Head Rails as described in my log to get all the various alignments where I felt they should go and to allow the bowsprit to fit.
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
Link to comment
Its only a small update, but its the only one I have.  I seem to have got bogged down in the chains, not sure whether I'm obsessing too much or just not getting enough time in one sitting to get in the right frame of reference and get it done because these are proving really fiddly.  To try to get the right line of the chains I used the plans to estimate the heights of the various stays/shrouds and marked on tape on the hull.  One item I may have miscalculated, I realized a little late that perhaps the deadeyes should slope inwards a little more rather than sitting almost vertical on the channels.  I'm hoping this won't  be too obvious as I'm not sure I have the appetite to change, its hard to see on photos of other builds.  Starboard side done, larboard about 50%.
Photos are pretty self explanatory.
post-891-0-55874600-1372727479_thumb.jpgpost-891-0-08263200-1372727480_thumb.jpgpost-891-0-55004800-1372727480_thumb.jpgpost-891-0-12147800-1372727481_thumb.jpgpost-891-0-75373400-1372727481_thumb.jpg
Cheers,
Jason
In the shipyard:
Link to comment
Great work Jason, harmony in all as usual...
May I ask a question?
Under the forecastle deck there is the frontmost cannon. But is there enough height for the crew to fire it easily? Proportionally to the height of the forecastle deck on your model, which height has the original ship's? I asked this because I would like to learn the accuracy of the Caldercraft's plans. Thanks...
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Link to comment
Don't know why you're obsessing... looks fine. I wouldn't worry too much about the inward angle of the deadeyes. Once you add the shrouds and lanyards, they'll tend to pull themselves a little into line anyway. You won't (shouldn't) notice it.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Link to comment
Ferit - the front port under the deck is a bridleport and would not have had a cannon mounted there.  The front and aft "decks" are really just platforms as they are probably about half height of a typical deck.  The original design did not have them, and I suspect they were added to provide some additional protection and functionality.  I can't really comment on the plans with 100% confidence, but comparing them to the drafts on the NMM site (HMS Cruizer and HMS Bellette/Gannet are available) they seem pretty much in line.  Where the plans are a little deficient is in the detailing (ladder size, chain placement) but I none of these present any huge problem, just a bit of thinking.  Once I realized that the plans were not 100% accurate I felt much better just working the pieces in a way that felt like it made sense.
Andy - I'm sure you're right, my main struggle has been with the closure of the deadeyes metal strops on the chain as these tend to pop out if forced (the gap is right at the bottom of the strop, soldering just didn't work for me).  It took a lot of time to make the chains so they were the correct length, the result is that there is a variable amount of play in them.  My main challenge is I never seem to get more than 15mins at a time to work on her so getting 'into the zone' is a challenge.  Your Pegasus continues to look better and better by the way :)
Cheers,
Jason
In the shipyard:
Link to comment
Looks amazing Jason!
hamilton
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch); Off-Centre Sailing Skiff (scratch)
Link to comment
Hamilton - appreciate the support and kind comment, your Blandford is looking great as well!
Finally managed to get a good few hours in today and managed to get the channels and chains close to completion, only some final sanding and another coat of paint needed.
As I've mentioned, I was a little wary of the deadeye strops coming off the chains when I get to rig the shrouds.  To hopefully make this a bit more secure I used some epoxy in the channel slots.
Once all done, the instructions say to use 1.5x1.5mm strip to close the channels, only problem is that the channels are 2mm thick, so I decided to cut my own to be 2x1.5mm.  Think it looks more in keeping.
Onto something else...
post-891-0-20289400-1372976425_thumb.jpgpost-891-0-59664200-1372976428_thumb.jpgpost-891-0-71949800-1372976431_thumb.jpg
Cheers,
Jason
In the shipyard:
Link to comment
Sjors, ZyXuz - appreciate your interest and support
The carronade assembly line is in high gear, and have made some tweaks to my guinea pig carronade (v3) which I hope to replicate, apologize for yet more carronade pics...
1 - breaching rope hole made using 20 gauge wire - not called for in instructions but seems pretty ubiquitous
2 - added training tackle eyebolts which are also not identified in the instructions - although I will not rig training tackles as I think it could be too 'busy'
3 - added some wheels to the trunnion which seems more authentic, and it also help align the angle of the base with the camber of the deck.  I thought about trying to use the white metal parts supplied but they proved to be too high.  In the end, I used some small slices of the supplied 2mm dowel and cut in half for the wheels
4 - handles added to the elevation screw base - I used a some of the small brass etch eyebolts and cut the head off, seams a nice match, the Caldercraft supplied wire is steel colour.  Decided to leave the elevation screw brass coloured, should mellow a little with age
If anyone has any other suggested improvements would love to hear them.
post-891-0-80126200-1373248076_thumb.jpgpost-891-0-52244000-1373248077_thumb.jpgpost-891-0-98365200-1373248077_thumb.jpg
Cheers,
Jason
In the shipyard:
Link to comment
Hi Jason,
Nice, precise, clean as usual...
"If anyone has any other suggested improvements would love to hear them." My suggestion after this sentence (my apologizes):
If you decided to leave the elevation screw brass coloured, should mellow a little with age; may the area which is out of the working section of the screw through the carronade be more darker because these bottom and top areas remain unrubbed?
Edited by ashiponthehorizon
Best Regards…
Ferit KUTLU
Link to comment
I'll simply echo the other comments here - great work. I'm with Ferit on the elevation screw...of course there may be historical reasons for leaving it with the brass finish - I'm certainly no expert! Anyway - keep up the great work! And thanks for sharing
hamilton
Link to comment
BE, Sjors, cheers!
Ferit/Hamilton - thanks for kind words and taking time to help me think it through.  Some commentary from DFellingham who has been doing a lot of reading on Cruiser class history helped my thinking - it seems that the elevation screws were one of those things that certain captains would have kept 'bright', requiring constant polishing, which is apparently noted in some of the ships logs - I wonder if there is an argument that it was considered 'maintenance of the mechanism'.  There is some contemporary evidence in the modern photo below as well.  Its all personal taste really, but something on the deck that's not black or red might be a refreshing touch.
http://modelshipworld.com/uploads/monthly_05_2013/post-891-0-48935400-1368816392_thumb.jpg
Cheers,
Jason
In the shipyard:
Link to comment
Andy - this is a something I plan to keep an eye out for when I head back to the UK in a few weeks with my son to do (amongst other things) the Portsmouth historic dockyard.  I don't think any of the screws would be ferrous for because there is no way that these would be useable with rusting, brass (or some similar alloy) would more likely be used because its self lubricating - I would hazard a guess that the threads in the carronade cascable would also be similar metal by way of some sort of bushing.  The Trincomalee carronade clearly shows a 'brass colour'.  I also found the following photo from my last visit to Constitution, most of them use the wedge elevation, but there is one example where there is a screw, and is brass (or similar), just not polished.  Of course, clearly I'm not an authoritative source and just basing my opinion on examples I can find  :)
Stergios - you're correct, the plan is still to use two 9lb'ers at the two foremost gunports, the rest will be the carronades.
Cheers,
Jason
In the shipyard:
Link to comment
Nice looking carronades much improved over the standard white metal ones.
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Link to comment
Worked on some final tuning of the cannon, unfortunately it took me pretty much an entire evening to do a couple of 'small' things, adding the chains for the cotter pin, and the hinge for the cap square.  I cut each chain to length after having blackened it and attached some Caldercraft 2mm photo etch eyebolts at each end, drilled in the appropriate place and attached.  The hinge was made from wire bent to shape into two pre-drilled holes.  Think this looks much better than the suggested flat head pins to secure the cap square per the instructions.  Thanks once again to B.E. for the pointers.  Must confess I was very happy with the result and some useful skills learned, even though there were many frustrating moments.
I still have the flintlock to install but I'll do that once everything is in place and rigged.
Cheers,
Jason
In the shipyard:
Link to comment
Sorry to say (and this is only my opinion, not necessarily fact), but to me that jack screw looks more like raw steel, than brass or bronze. In any case, regular oiling and working would have kept the metal from corroding.
I'm still interested in what you find out, though.
There's also a chance that in the name of preservation, some things may have been replaced.
Andy
USF Confederacy
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
