Working on completing the first layer of planking below the main deck. Very slow process on a ship this size. You will notice many glue spots. I want to make sure the planks are very secure as the basis for the final planking. This will get all covered up with the pretty second layer.
Vince P.
ARGGHHH!! I am in the middle of planking the hull and my electric plank bender burns out. Murphy's Law strikes again. I am bending them by hand until a new one gets here. :(
Vince P.
Completed one side of first planking layer below main deck. Sanded it down and filled in any low spots and small gaps between planks.
Before completing the other side, I made sure the masts would seat properly in the slots of the false keel and upper gun deck. It is necessary to mill the lower end of the main mast to a flat of 10.0mm in order to fit in the slot of the keel.
Vince P.
Edited by Vince P.
Still working on the first planking. Almost finished. Also constructing the main deck staircase. This has to be made from scratch and I am getting an education in the process. Even though this will not be visible when the upper decks and fixures are put in place, it was a challenge so I am building it and will place it on the ship. Photos coming soon on this and the finished first planking.
Vince P.
Construction of the main deck staircase from scratch. This is included on the plans but not supplied in the kit. Even though it will not be visible once the upper decks are placed, it was a nice touch and a challenge to build.
Each step is made up of 2 parts and needs to be beveled at 45 degrees. I jig was made from lumber and the steps placed on top of each other. Once the whole thing is completed, it can be lifted off the jig.
I did find some nice stanchions at Model Expo that were pretty close to the correct size, and only had to be cut down a little and beveled on the tops.
I finished the whole thing in red walnut and weathered it to look old. Once the main deck is installed and planked, the staircase hole will be cut and the assembly placed down into the deck. A "C" shaped bannister will have to be constructed to match the staircase and attached to the outside wings so it encloses the opening in the deck on 3 sides.
Vince P.
Edited by Vince P.
Once again I am very disappointed. Having lost my entire SOS build log in the great crash was one thing. Now I see that most all of my early photos in this build log are gone as well. I will have to repost all of them. It will take time to do so, but once again I will do it. There is no sense in posting a log if the users can not see the photos. :angry:  :angry:  :angry:  :angry: .
Vince P.
OK, I have reposted all of the missing photos. There were about 25 of them. Only one photo that was posted by Brian C. is still missing since I do not have copies of photos sent in by others. Having worked for the government for decades, I got into the habit of making backup copies of everything and storing them in a safe place. :dancetl6:  :dancetl6:  :dancetl6:
Vince P.
Vince, thanks for taking the time to repost the pics.  This has been a great log to follow, and we all appreciate you sharing your work.
Just out of curiosity, how did you weather the staircase?  It came out very well.
Hi Mike,
On the staircase, I waited until the stain I applied got tacky and I then took a small sponge wet with paint thinner and dabbed it until the finish took on a uneven faded look. Learned that trick many years ago from another experienced modeler.
Vince P.
I have finally finished the first layer of hull planking below the main deck. This took over a month and a half.  Considering the size of this hull, that was a whole lot of planking. This is definetely the most difficult of the planking. The planks above the main deck are nice and straight, and the second finish layer has a bottom surface to lay it on. The only thing about the finish layer is that it has to be precise and pretty.
Next up is to install and plank the main deck.
Vince P.
Your planking towards the stern is exquisite.
Kits owned: Mamoli Royal Louis, Mamoli Friesland, Mamoli HMS Victory 1:90, Occre Santisima Trinidad, Constructo HMS Prince
Before placing the main deck, it calls for slicing off the top section of bulkhead "B" to accomodate the forecastle later on. When to cut this is not clear, but it does help support the main deck bulwark planks. I decided to add the 4 planks that will make up the main deck bulwarks first making sure not to glue the planks to this bulkhead, and then cut it off. The plans call for an 18.0mm height at the lowest point of the bulwarks, but it should be more like 20.0mm to allow placing the decorative siding later on. With 4 planks it came to about 24.0mm. It can be shaved down later on. Also, the planks need to be longer at the bow by at least 15.0mm past bulkhead "F" and flush with the last bulkhead at the stern. I still need to trim that.
Next up is tp place the main deck and plank it.
Vince P.
Edited by Vince P.
Hi Denis,
It seems like it is going slow to me. I guess I am just anxious to see her progress.
On the deck planking, the kit came with walnut which is a little too dark, but I soaked it in bleach for 20 minutes and it comes out lighter with a weathered look. Looks just like what a deck would be for real.
Vince
The main false deck is glued in place. I did not cut this deck in quarters like the others. The first half was easy to clamp down on the bulkhead, but the second half was different. There was no way to clamp down the section in the middle where the main deck is the topmost deck. I nailed it using tiny brass nails which will stay in place and be planked over.
Next up is to cut out the square opening between the mainmast and the forward edge of the quarter deck for the main deck staircase. The opening needs to be 24.0mm across, but I have not yet calculated how long to make it.
Vince P.
The wood supplied for the deck planking is walnut and it is nice wood but different colors and too dark for realistic deck planking.
I soaked the wood in bleach for 20 minutes and dried it. It came out perfect and will give the deck an authentic look.
In the photos, the wood on top is the walnut as it came with the kit. All 6 pieces were cut from the same strip and you can see the color differences from one part of the wood to the next.
The lower strips in the photos are the bleached wood. The color is good and it bleached out all of the strips to the exact same color. It has a weathered look like a real deck would appear.
Vince P.
What a surprise! I would not have thought the bleached walnut to come out so good. Nice job. Something to remember.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Hi Vince, thanks again for sharing your build.  I've been learning a lot from you, so thank you.  The bleach method for the deck planking looks really great.  Seems to be a cheaper alternative if you want to use the deck planks that come with the kit rather than buy holly or the like.
Just out of curiosity, are you using straight bleach or are you diluting it?  Do you rinse the planks after they have soaked in the bleach?  Any concern that the bleach may corrode the wood over time?
Hi Mike,
I used straight household bleach with no dilution. I did thoroughly rinse the wood 4 times in warm and cold water. Then dried it at 150℉ I don't think it will harm the wood, but we will have to see.
Vince
Hi Vince,
I don't think the bleach will hurt the wood. The bleach just reacted with the tannins in the walnut. It is a great effect and I intend to do the same with my RM deck when I get to that point. Thanks for sharing your excellent build log.
Best
Jaxboat B)
Hello Vince
I admit to all others: Great idea to bleach the wood. I will try this too when I have the need to lighten the wood.
Sometimes the household is the best tool-box ever :D
Cheerio
Max
:10_1_10:
Next: Friedrich Wilhelm zu Pferde by Euro Model 1:47
Finished: Half Moon Corel;  HMY Royal Caroline Panart; HMB Endeavour Occre 1:54; Fregatte Berlin, Corel, 1:40
A life without dogs is possible... but worth to live?
