Build log part 22
the pinrails are removable for Access to the eyelets (shrouds and backstays fastening)in between
mizzem mast pinrail, the nameplates are aside the poopdeck and at stern
bowsprit netting
swivible bumpkins for bracing tackle rope guides
the tack Position of the Forward mast lower yard
Build log part 23 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
build log part 23
Here the mizzen mast unpainted....
hooters, Radar station
lower platform antenna
top antenna
Mast top
middle gaff boom bearing
set of masts, yards
Build log part 24 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
build log part 24
Preparing for the captains Launch (Pinasse 9,2m )
the Yards have to allow bracing to utmost Position before they touch the backstays
checking alignment through topgallant platform before the final backstays are set
the boats Derrick attached to the mainmast
the mizzenmast bears no yards
have the most masting parts done...
the ventflaps for the scupper openings are attached
my master raft Containment template for moulding the semi halves
BUild log part 25 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 25
Need 28 halves of this raft Containment, so ist worth doing a mould.....
the half of the metal model is pressed into schoolkids clay, this being the mould (s)
when making the boats there is always, before it cures off, some Polyester left, so is goes
into the moulds (without wasting it)
sanding, primering, Fitting of the halves, and preliminary mounting (some cradles to be made first)
fastening with brass wire straps
fitted on to the raft Container launching flipboards
a wooden model is made for the three boats of the Gorch Fock. The making of the boats Pictures shall follow later on
Build log part 26 to follow.....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Great work.  Will the captains boat have a build log of it's own?
Bob
Current build:  SS_ Mariefred
Bob,
within tomorrows Picture lot there will be be pics of the making of the boats, but for the capt`s. Launch in scale 1:95 please do not expect a seperate build log.
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful detail!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
thank you JesseLee
Nils
Current builds
-Lightship Elbe 1
Completed
build log part 26
a boats model in Wood is built for making a mould
the boatrack with the raft Containments is positioned
two half-moulds are made from plaster
for easy seperation I use car-wax
before filling the Polyester in a inner form has to be placed half into the mould
remaining Polyester is given into the clay moulds
Build log part 27 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 27
this wooden form gives the inner space of the boat after removing it
gratings for the boatrack
aft bumpkins mounted
middle bumpkins mounted
produce 3 left and 3 right halves from the two moulds
the deck inner portions are cut out
made sitting Banks from Card templates and stained ply to match the boats interior contours
ready for fit check
Build log part 28 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
You certainly know what you are doing! Looks amazing! So much attention to detail. Love it.
Regards, Scott
Completed builds:
Awaiting construction:
Build log part 28
bottom Planks an sitting benches fit well
parts glued together and bulwark rails fitted
a Little bit of painting done and rudder fitted
the ouitcuts for the oars are done
three simular boats completed
the captains pinnace is done in wood
Fittings attached
the figure in the Cockpit is scale 1:87 (a bit too large)
nav lights, bulls eyes and windowframes still missing
Build log part 29 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice work on the masts and small boats Nils. What type of resin are you using?
Michael
S. Coleman,
thank you for your comment
Nils
Michael,
thanks for your comment. The 2-componet resin I used is an ordinary liquid Polyester mixed with appr. 3% hardener. It cures in about 15 minutes time and can then be removed from the mould
Nils
Current builds
-Lightship Elbe 1
Completed
The small boats are nice. If you get much smaller you can put them in a bottle.  The double cloths pin clamp is great, thanks.
Bob
Bob,
I was wondering if anybody would recognize that....
that double pin was not my own Invention, I saw it once somewhere in tips for modelling and also found it great and worth remembering. Meanwhile I glued some together and always have them Handy in order to clamp larger distances with more or less parallel closing in clamp-toungues
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks David,
same answer as to Michael today...
The 2-componet resin I used is an ordinary liquid Polyester (like for car repair) mixed with appr. 3% hardener. It cures in about 15 minutes time and can then be removed from the mould
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Mauro,
I`m happy that you like the model
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
I thought I would pay a visit to see what you are up to.This took me down memory lane a little as I built the 1st Gorch Fock as a child from a plastic kit.Your work is fabulous,I particularly like the metal work,it is fantastic.A very impressive model of a very attractive and sleek ship.
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Nigel,
thanks for your "likes" and for visiting the Gorch Fock 2 on my Yards slipway, and for your nice comments.
The GF 2 I am doing is very much orientated to the 1:150 scale Version of that legendary Plastic kit from Revell. It resembles the Version of the late 60`s. Unfortunately it is not produced any more since many years, and one must have great luck to get such kit e.g. per Ebay auction. I had luck, and so had very nice samples for the Rating dimensions, wich of course had to be magnified to scale 1:95, and the parts had to be scratch built.
Still the plastic model remained unbuilt, so the complete kit could be sold further on to another happy modeller
Nils
Current builds
-Lightship Elbe 1
Completed
too cool Nils!   a real nifty way to create them as well!   very well done!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
your comment is well appreciated
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 29
decks ready for Fitting out
Stern and bow of hull so far done
checking backstays alignment with regular Cotton thread strings first
set of masts and Yards painted
Build log part 30 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 30
check for cutter on the boats rack
captain`s pinnace goes besides the cutter
first deck Skylights....
Build log part 31 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Torture pain agony how can you do this. My feeling of supiority and self esteem are fading. Great work. I would like to do a vulcan mind meld and absorb all of your talent and skills. Bravo on a job well done.
David B
very nice words David,
makes me feel good this morning, thank you
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 31
aft deckhouse (command cabin and nav- and Chart-room) and spare aft anchor.
the blue guy had always become too much Porridge as a Baby already and now has to leave the Crew for his size
chest-cover to sit on, for the auilliary rudder mechanics, here still without wheel
some brass pinrails to the deckhouse, and the main rudderstand saddle for the 3 steering wheels, this rudderstand (the wheels) is operated manualy if necessary by up to 6 men
the Long boom outside starboard bulwark is swivible and required for fastening the boats in water (when rigged 90° square to the hull). The brass wire through the top spanner-eyelets is only preliminary and prevents the spanners from tilting down between bulwarks and inboard pinrails
vents and Skylight added on top of the small well-deckhouse
Build log part 32 to follow.....
Nils
Current builds
-Lightship Elbe 1
Completed
