My Pandora book shows one piece deck beams from the bow back to about one fourth the length of the ship. The deck beams at the stern are also one piece about one fourth of the way forward. The center half is all two piece notched together.
Edited by SaturnV
Congrats for reaching this milestone, Jürgen. Your hull looks really impressive. I am nosey to see your hull when we meet next year .
Edited by AnobiumPunctatum
Regards Christian
Fantastic work and I am here feeling very intimidated about starting the section build
Thanks so much for the nice comments Daniel and Nigel and also for all the likes.
@Daniel
In terms of this Triton build the most are means the double frame is much easier than the single frame. But I believe that isn't so. I think single frame have a great vantage, to get the right shape of the hull is much easier than in double frame. Although single frame is more time consuming. In relation of the optic I'm with you.
I think you have a nw hobby, Jürgen.
Sanding, sanding :P
Regards Christian
Juergen,
a beautiful build and very nice hull lines of the Triton....
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks so much for the nice comment Mick and also for all the likes.
I would like to install the Main-Wale at next to stabilize the konstruction. But I'm not really sure to do this yet because the most modelbuilder are doing this later.
Are there reasons not to do so?
Edited by jaerschen
Hi Juergen,
I placed my wales first so as to stabilize the framing for sanding. The frames tend to vibrate under the sander and make it hard to get anything done. Now that I have the wales in place the material is coming off more quickly. I'm not following any instructions for this but merely making it up as I go. Kind of fun that way.  :)
Hope that helps.
Richard
Thanks so much for your statement Richard.
I had much trouble with vibration during the sanding. That's the reason for this thought.
If I saw your "mystique photo" (I like it very much) , it was clear to me to do it also.
Edited by jaerschen
Hello Guys
Most of the outside sanding is done and the Main-Wale is started.
The Wale at the bow is strongly curved and it's very hard to bend it as you know. I decided to saw out this part and it worked very well.
post-3439-0-20818800-1416780114_thumb.jpg post-3439-0-25925200-1416780121_thumb.jpg
To fit the following parts were a lot easier
Another difficult part is last ledge at the stern. The ledge must be formed exactly before bonding. This approach should be used at all the parts of the planks because it's much easier.
post-3439-0-91564400-1416780272_thumb.jpg post-3439-0-62881800-1416780281_thumb.jpg post-3439-0-29277200-1416780299_thumb.jpg
The current progress
post-3439-0-05071100-1416780323_thumb.jpgpost-3439-0-38319200-1416780330_thumb.jpgpost-3439-0-86520500-1416780341_thumb.jpg
The next update is coming when the Main-Wale is finished
Really nice progress, Jürgen.
As you know, I am a great freind of oil colors for painting the wale black. ;)
Regards Christian
LOVELY -wonderful work
Normally oil color will harden in a week or two
Regards Christian
Hello, the next step is done and the Main Wale is fitted.
I had I little mistake nearing completion. The following photo should be a little help to declare it.
For fitting the last ledge of the Main Wale it was necessary to sanding the outside of the side counter timber at starboard side (blue arrow). But there wasn't enough material, the part was to small at this point (yellow x) . I had to many material removed at the inner side (red arrow).
The exchange of the part seems like too much effort to me. So I decided to glue a piece of wood to the counter and sanded it down. I believe that must be alright on the finished model.
And now some photos of the Main Wale. It's still to do a bit sanding on the port side.
post-3439-0-57870000-1417989842_thumb.jpgpost-3439-0-20513100-1417989848_thumb.jpgpost-3439-0-16990200-1417989851_thumb.jpgpost-3439-0-24280100-1417989857_thumb.jpgpost-3439-0-29819900-1417989862_thumb.jpg
Excellent fix Juergen B) I agree,for a part that will become invisible when complete,the amount of work required to replace the piece,just isn't worth it.The wales look great B)
Kind Regards
Nigel
Currently working on Royal Caroline
Nicely fixed, Juergen.   I'm with Nigel on it being hidden.
Looks good, Juergen. Just remember not to trim the aft end of the main wale until you have planked the lower counter! (Usually the lower counter is planked first.)
Yes, Juergen, it's irritating seeing rough-cut ends! But be patient, it will be worth it. That will be an outstanding model.
While I think of it: did you taper the thickness of the wale at the bow to fit the rabbet? (I had this conversation with another model-maker today.)
Edited by druxey
