Thanks for the comments guys and the like button responses the rework although a pain did come out as good as it possibly could have done, I am one starting on the two upper deck fittings starting with the cannons and caronades, much more fun, I will update the build on the guns in a few days.
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
The nine pound carriage guns were made up in the same way as were the eighteen pounders. The caronades were made up in stages as shown in the photos, I first looked for the tackle arrangement and used the one that seems most common, the issue was the fixing of the front carriage pin it shows it pinned through the bulwark on the bottom of the gun port, the problem with this would be, in lowering the bottom of the port to keep the cartridge level, it would be to low and look wrong, so I looked at every photo of caronades I could find, on models, and as mounted on H M S Victory, and most had the front swivel pin going through a block mounted on the deck in front of the port, so that is how I built mine.I am just starting to rig them in place.
Carriage parts
assembling carriages
Carriages built up minus barrels and some rigging eyes
Extra rigging brackets from spruce and 3mm rings
Made up and painted
On deck working out how the rigging will run
Ray
 Completed  HMS Diana
Hi B E
Thanks for the endorsement you are a font of knowledge I researched the front fixing, it as best I could, the plans shown them fitted through the gun port sill. I am going to arrange the guns on the quarterdeck with the two caronades in the middle and two nine pounders either side, and on the foredeck two nine pounders will be set up as bow chasers and the last two caronades in the last forward side gun position.
Ray
 Completed  HMS Diana
Carronades
The first photos show the first carronade fully rigged, next photos show the stages in which they have been rigged, I tied up all the tackles first and then just hooked them on and set them up, glued down the end of the rope and added the rope coils, they look a bit shiny in the photos but not in real life,they just need the paint touching up on the hooks and eyes, next I will add the nine pounders to complete the deck guns on one side of the quarter deck.
The first one being set up
The first Carronade rigged
The second one being rigged
Ray
 Completed  HMS Diana
Sweet very sweet.
Ray, did the carronades come with barrel plugs supplied or did you make them yourself, I've been toying with the idea for some time and it's good to see them in use.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Mobbsie
                  The stops in the carronades were part of the moulding I just painted the ends red so as to highlight them. I have added a photo of the original casting of one of the two I will not use.
Carronade as supplied in kit.
Ray
 Completed  HMS Diana
Ray, your coils look great, very natural. I was on the fence as to whether to do coils or not, and didn't go down that route myself - but maybe next time.  The training tackles make a big difference as well.
Cheers,
Jason
In the shipyard:
Quarter Deck 9 Pounders
The nine pound carriage guns were made up the same way as the eighteen pounders were, and added to the quarterdeck, I have added a couple of photos of the blocks with hooks fitted I make these like this to give as much space between the rigging blocks as possible, they just have a .7mm hole drilled in the end and an opened up and cut down copper eyelet inserted.
Cannon rigging blocks
Cannons made up
Starting to fit
First one done
All done one side
Ray
 Completed  HMS Diana
Hi Ray, very nice mate but aren't those coils a complete pain to do.
I have made loads and am still trying to find a system I like and which will give me a uniform finish, who knows, maybe one day.
Cannon and Carronade's look fantastic.
Be Good
mobbsie
mobbsie
Next Build :-
Hi guys   Flemish Coils
Yes Mobbsie the Flemish coils are a real pain, but they do give best look to rigging the guns in my opinion, I have added a few photos of how I make them, and I wish I could find a more efficient way of doing them. This way works but is slow and tiresome, sometimes it takes several goes to get one started,I lay out the masking tape sticky side up and just stick the rope down wrapping it around the starting loop under my finger and when done paint them over with diluted pva and remove when dry.
Two coils
a strip of coils
A batch done
Ray
 Completed  HMS Diana
Thanks for sharing your tip Ray,
those coils look really fine indeed
Nils
Current builds
-Lightship Elbe 1
Completed
Hi all
I have had a bit of a building break, mainly due to refitting our bathroom, which included a new bath and new sink & loo vanity units. We also had a week looking after two of our granddaughters. I did make up a couple of the deck fittings the capstan and the quarter deck sky-light.
Now back to adding the guns to the other side of the quarter deck, two carronades so far.
Capstan
Quarter deck sky-light
Second side Carronades
Ray
 Completed  HMS Diana
Welcome back,
Just curious. Any particular reason you left the skylight natural as opposed to paining it red and black like the capsan?
Thanks,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Hi Mort
             I might yet still paint the sky-light I just made up a couple of the deck fittings until I could get back to the guns, I will most likely place all the deck fittings dry in place and then decide on the final paint or varnish finish.
Ray
 Completed  HMS Diana
Hi Ray,
I fully understand what you mean by refurbing the Bathroom, I'm doing our kitchen, aint easy mate.
Nice progress on the deck furnishing's and that a really interesting set up for the carronades, very well done.
Be Good
mobbsie
mobbsie
Next Build :-
All the quarter deck guns have now been rigged slow progress due to other comittments and a bout of flu, the only other work has been on some of the deck fittings. I will update on the fitting soon, I will also add the pin-rails, I think they will be fixed to the top of the bulwark below the open rail,I will also fit the cleats plus the eye’s to the rear half of the ship, at this moment I am also thinking the sky light will be painted red ochre and the barricade black as all the wooden components in its construction are different colours.
All the quarter deck guns rigged
Ray
 Completed  HMS Diana
Time to complete making up the quarter deck fittings and add them the the model, I first added the pin rails all of which had the holes opened up to take the belaying pins, next came the deck cleats (which were drilled and pins added) then I added the eye bolts to the deck and the channels, here I did make a boo boo and drilled the holes the wrong side of the main mast hole, so now there are eye bolts right around the mast hole. Next the cavil blocks were modified to bring the top away from the side of the bulwark this will allow ropes to be tied to them see photos, if not altered you could not tie off on them. I made up the barricade a bit fiddly but not to bad at the moment I am undecided as to whether to leave it unpainted or paint it black.
Pin rails
The barricade
Barricade dry fitted
Cleats
Cavil blocks
Ray
 Completed  HMS Diana
Thanks Ray for sharing, very nice progress pics, shes really coming together.  Love deck shots.  On the barricade, I have seen a few admiralty models with these painted/stained black and thats probably the route I would choose knowing the wood would probably not look the best left natural with what I'm assuming is ply.
Cheers,
Jason
In the shipyard:
Many thanks for all the ticks and comments.The barricade will turn black later today, it is black on my Pegasus and on a lot off other models and I think it is the way to go.
Ray
 Completed  HMS Diana
The barricade has now been painted black and I think looks better for it, the ships wheel has also be painted and made up, and the rail on the great cabin roof has been fixed on.
Black barricade
Ships wheel
Cabin roof rail
Ray
 Completed  HMS Diana
