I could not help it, Today the Boxing Kangaroo was calling me to work on her . So I thought ok for an hour or so . 10  Hours later here is the build log. I started by truing up all the frames and making sure all the alignments are correct. ( square is square and level is level ) anyone new to scratch building, this is one of the most critical parts to the build ( you get it wrong here, you are fighting it all the way to the mast )Once I was pleased with the frame alignment I glued them in position . while the glue was drying ( I know that I said a hull only build ) I decided to use the plans and lay out the deck , ( I am thinking about a clear varnish over it ) at the same time I decided to make a new transom . I then installed the deck to the Keel and frames , followed by the transom . I then made frame 11 ( 2 pieces ) and installed them. I then started to fair the frames . This Boxing Kangaroo is right on the money , She's is incredibly fun to build , it's hard to put her down . here are the results ( alot of pics )
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
And here are the rest
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Geoff, I did not realize that I spent that much time till my wife told me , She thinks The Boxing Kangaroo is Great
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
She's looking great, Pete! That deck layout looks like it's be tight--it'll look great with those details and clear varnish should highlight the fixtures well! Definitely looks like you spent a long, fun day in the shipyard!
Cheers,
Jay
Current Build:  Ariel
It was Awesome Jay, ( I did not have to go anywhere today ) I just lost track of time . This is the First Cup Boat that I have ever built ( I am totally into it ) Such a great design , The lines just fly off this one , Very Sleek
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Pete. Very, very nice. How do you manage to spend so much uninterrupted time on your build? Are you lucky enough to be on annual leave, or maybe early retirement? Either way, I envy you because time spent doing something you really enjoy is definitely time well spent!
As for KA6, well, she's looking really good. Do you think that you can really stop at just the hull? You could be tempted to sail her; once you see how well Kate sails...what do you think???
All the best.
Edited by Omega1234
Hi Omega, I always have the first few weeks in july off , usually to go Camping with Faimily ( I  got out of it this year ) .The day's to build all day without interuption are few and far between( I think this was the second time )  .On the Boxing Kangaroo,  I will stop at just the hull ,she's just too small .  I may do a bigger cup boat in the future that will sail .( we shall see )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The Planking will come next after the fairing the frames is finished, I have started to think about the Famous winged keel (wich is a key element to this build )
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I Got back to work on the Boxing Kangaroo. I started by putting 2 thin coats of varnish on the deck ( to protect the deck layout ) I then had errands to run ,wich gave the varnish plenty of time to dry. When I returned I finished fairing the frames , She is now ready for planking . She's  right on the money with Ben Lexcen's Drawing . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank You Geoff, She is practically building herself, She is a "treat" like you mentioned before. The Boxing Kangaroo has been a fun boat to build . I would recomend building one
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Robert, Planking should go smooth, the frames faired well
Hi Omega,  planking is one of my favorite parts of the Build, It's when she really takes shape. The hull will be painted white with the blue Keel Accents ( intresting to leave it Natural)
Thank you Michael, She's coming together pretty quik
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
A good start Pete,
the Frame work Looks very nice, it must be fun to build this hull from now on....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils, This boat has been alot of fun to build ,  Fairing the frames went very smooth, like Geoff said she's coming up a "Treat" He's right
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I was able to do one of my faforite parts of the build ( Planking ) I started by soaking my planking material an rubbing alcohol, I do this because alcohol evaporates faster than water esp. when it's 90 degrees farenheight outside . I let them soak for about an hour and started plankihng , The only trickey part is at the transom, it all went together smoothly I planked the boat all the way to the Keel and started Fairing the Hull , Here are the results,  That was fun
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Here she is upside down, Next will be the Famous Winged Keel
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Geoff, It was somthing I learned from a friend that built R.C. Air Planes, and  It works great
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you John,  This Boxing Kangaroo has been extremely fun to build, so it's hard to stop working on her
Thank you Omega, that section was a bit trickey ( I have a great drawing of the boat ) So it was easy to see how the lines come together , executing it was trickey
Hi Keith , I am not going to stop now, the winged keel looks to be the most challenging part of the build, I am excited to start on it
Hi David , the Hull will be painted white < so I went with Bass Wood for the planking
Thank's Jay , I should have some pic's of the Keel tonight, ( fun Stuff)
Thank you Michael, The Winged Keel is very exciting for me , As I have never done one before, Well I never built a 12 meter before either . Lot's of first's for me on this build
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Looks great Pete.
There'd be few Australians who remember the day 'we' won the cup who wouldn't get a smile on their face just by hearing the name Australia II or see the boxing kangaroo flag... I was only 9 and it was BIG news at the time.
Bob Hawke is 84 and can still skull a 'schooner' of beer with the best of 'em (likely to be a few videos on YouTube) - a skill he honed in his University days, a Rhodes scholar I think.
A schooner of beer? There's a bit of history to the actual amount, but these days is a glass of 425ml...
"...the origin of the term, although unknown, is suggested by the comments of a magistrate in a 1931 Sydney court case. A city publican was proceeded against for supplying a schooner of beer instead of a pint. The aggrieved customer was found to be legally entitled to a full pint in a stamped measure if he asked for a pint; he should receive a ‘full-rigged ship’, not a lesser fore-and-aft rigged schooner." From http://www.brewsnews.com.au/2011/01/schooner-wars/ (fws)
Cheers
Leanne
Current build: HM Cutter Mermaid 1817
Next build: US Brig Syren...maybe :)
Thank you Leanne, I was 16 at that time , I grew up in a Sailing Family and had my first solo at 6 , So the Americas Cup was bigger than any other sport in our house.  the Cup was bolted down for 132 years in New York Yacht Club, so to see an inovative yacht come in and force 7 races was spectacular, and the winged Keel taking center stage made for a great story
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today was the day to start the Winged Keel, To say it is difficult would be an understatement. ( this is the first one that I have done or even a Cup boat for that matter) I first finished Fairing the hull to the Keel line , Next I cut frames for the Keel, Then I made the wings, On the frames, I notched in the wing angle , I then used scarp to fill in the spaces between the frames . I got the front 2 sections of the keel finished . I still have the aft section of the Keel with the trim tab fo finish followed by Fairing the Keel ,The Wings have not been glued in at this time, This is an amazingly well designed Boat.  Here are the results
Edited by Pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
You are really clipping along Pete.
Michael
