Thanks guy's,' yep', on the mend.
Well with the lower shrouds done its to the tops we are.
Using Dafis etched parts and Heller deadeye's.
I have glued the deadeyes to the etched frames, no need to worry about size as there all the same,'phew'.
Note the hooks below, these are for the futtock shrouds, will attach ropes to these before hooking to the main frame of theDEs.
One other thing you may need to file the Heller tops to fit etched parts, Dafi does suggest gluing these in in his hints and tips.
Very good advise.
Frank.  :piratebo5:
Edited by foxy
Speaking of adding detail to the tops: I had used the kit supplied little plastic eyes (Part#40)  for the ringbolts on the after end of the Fore Top. This is where the lashing for the Main Topmast Stay is made off and it turns out this ringbolt takes a lot of tension, any motion of the mainmast focuses a lot of tension right at that eye and mine pulled right out, broken off at the neck. My advice is to use a loop of wire and secure it very well to the top and discard Part#40 here.
Quote
 Niagara USS Constitution
Well its to the tops I be going.
Removed the DE etched parts from Dafis  fret and found some of the deadeyes loose.
So after making sure all was fixed down ship shape I then filed the burrs off both ends of the etched parts.
Drilled out the holes in the tops so the etched futtock shrouds would push fit through the holes.
Left loose till later.
Then its six aside for the Fore and Main tops.
four aside for the Mizzen.
Now I know why I did not complete the ratlines yet, is most fiddly at this point to secure ropes etc to the belaying pins.
With that in mind and having Dafis etched motives for the fire buckets, its to that I am next working on.
DSCF6507_zpsg7wbh6qn.jpg.
More soon shipmates.
Frank.  :piratebo5:
Edited by foxy
A great joy to follow this build. Not because of the etch you use, but because of what you make out of them!
Great job, Daniel
Thank you Daniel.
Tis to the fire buckets using dafis etched KG parts.
First how NOT to remove fire buckets from spru.
Note bad cuts to the rear of the buckets.
Use a proper cutting tool and leave a little to file to shape.
The KG etched parts were formed with round pliers.
Should look like this.
Twenty one are needed for the quarter deck, but a few extra will help later for the crew to carry maybe.
The buckets come in black plastic, but to make a difference I painted them leather(as new).
They were tarred inside and later outside.
'My choice'!!!!.
Frank  :piratebo5:
Edited by foxy
Well its been a bit hard going, as I should have done the fire buckets earlier, anyone having a go at this should think on this.
Now having enuff KG etched crests(thanks to Daniel)I started thinking on how to place them with the shroud ropes done.
I added a strip of plastic from the tops left over part, stuck this behind to the top of the plastic rear bulkhead of the poop deck.
Then used plastic glue to hold buckets, later will add CA to the handles.
Later when all settled will paint handles and surrounding area black.
Next its on to the upper shroud ropes.
Used .63mm for the lower and for the upper will use .30mm black.
For both shrouds I will use .08mm for the ratlines.
Frank.  :piratebo5:
supper job on the Victory Frank
        will read your build over and over untill I get this kit I have two questions
     where did you buy the little lathe you used for the mast and also where did you get the wood planking for the
     decks and what size are they, I will ask you more later thank you
                               Ronald
Thanks Lawrence, There are so many good builds here its a job to take them all in.
Yours is no exception.  :cheers:
Hi Ronald.
The deck planking are 2mm and 3mm, mostly 2mm wide maple.
I got mine from Cornwall model boats(England), there 1'000 in lengths, but they cut them down to export.
The lathe is of German make and I believe I got this from Axmister tools in England.
I am sure you could also get these in the States too.
Hope this helps.
Moving on a touch with the top shrouds.
Keeping them loose on the running rigging till all done, then its the stay's to tension up and then tighten up the shroud runners.
You could if you wanted to make all adjustable, but as this is a static model all will be fixed.
Frank.  :piratebo5:
Edited by foxy
Thanks very much Lawrence, much better now thanks :) .
Well have been busy of late with all the top ropes strung.
Left loose till main stay ropes have passed over mast/shroud.
Then tightened up.
With the main stay ropes in place.
One point is the main stay ropes to the bowsprit.
As all know they pass through the bowsprit and then attach to block and tackle.
For those doing this build, its advisable to add the blocks near the knights head before adding the netting and booms.
This will be a lot easier.
The blocks I used for this were of Syren manufacture and can move if ness.
Next its the stay ropes from masts to channels etc.
This is the sequence I am following for this static build.
Having good plans of the rigging helps, so far its standing rigging I am working on.
Thanks guys for all your imput and likes.
All the best Frank.  :piratebo5:
One question on the last picture, this shows a raised part block on the sprit bow above the marine walk.
Looking at many pictures, there does not seem to be this item.
Can anyone help weather this needs removing or not.
What's its purpose if so.
Frank  :piratebo5:
I think it is meant to be something like this :-)
The  fairlead saddles.
                                          #86
XXXDAn
Edited by dafi
Cheers for that Daniel, well can remove ok and will add your version.
Well its Organised Chaos at the moment with one side of the stay ropes done.
For the blocks I am using Syren 3mm and 2mm for the lesser ropes, with Dafis eyelets already positioned.
The main top.
Running down to the channel.
Some of the chaos on the deck.
The shrouds on the top masts are run through the top and left loose at the moment.
The tuther side is next with the blocks made up, so should be faster.
Frank.  :piratebo5:
Hi Ronald.
The photo etch comes from Dafis wonderful etched sets.
If you contact him I am sure he will help you.
Just hit on his sig and send a message.
As for the wood deck, well its 2mm and 3mm I used and came from Cornwall model boats.
Just type this in and you should be able to find there site.
I used maple wood for this build.
Moving on with the stay's done for standing rigging its time for the ratlines to be done.
I thought in this scale that if I tied them it would be oversize.
So the simple way seemed the best.
Just glue to the shrouds.
To save time and glue I did all the shrouds with three rows, then left to dry and cut off the excess.
This is time consuming but it works!!!.
One other thing I did was to move the Anchor rest forward between the first two chains, this allowed the anchor to sit right later.
Frank.   :piratebo5:
Edited by foxy
What a great!! build...... just loved what you did on the stove ( plus everything else :P )...... I'm a big fan of LifeColor too !
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks Frank, Mark.
Yes the stove was fun to work out and thats half the fun, ain't it.
Well moved on a tad with the overhanging shrouds(futtocks).
Used a small piece of brass rod and Dafis etched parts.
So as not to bore you I will finish this side and the other before more pictures.
Frank.  :piratebo5:
Hello Frank, just came through your build log.... and i have not much to say... I'm speechless ... AMAZING DETAILED WORK!!!! It's seems you've been very intent for every step you take throughout your perfect build... :) Well done!!
Kind Regards
Dimitris
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
Hi Foxy
    I went to the web site where you got your little lathe couldn't find yours would you know the
       model number  wasn't able to find one in the states thank you
                           Ronald
Hi Foxy  I have another question for you would you have the paint list for this kit since it is in French  or would it be the same paint colors
    for all Victory kits rather it's a big kit  or small
                                Ronald
Hi Ronald.
The Paints I am using are APS9014W HMS Victory Set.
These are water based and very good, you get all the colours needed for this ship.
I used a primer first on the plastic hull and then sprayed the colours needed.
I got these from Cornwall Model Boats Ltd
Unit 4D, Highfield Rd Ind Est.
Camelford.
Cornwall.
PL32 9RA
United Kingdom.
Phone- 044-01840211009
I am not sure if the first three numbers are right, so maybe check these when phoning from the states.
I also use Life color water based paints for this project.
For the Lathe.
Its a Proxxon- DB 250.
They do a fantastic range of tools that are use full for modeling.
Frank.  :piratebo5:
Hope this helps you find what your looking for.
Two more pictures of the hanging(futtocks)shrouds.
Foremast
Mizzen mast.
Some tidying up to do, then other side.
Thanks again folks for all your Interest, most appreciated.
Frank.  :piratebo5:
Edited by foxy
Hi Frank
    I was wondering and didn't about till today could the Unimat Lathe work for the job required
     because I have a Unimat 3 it's stored away and it still works
                         Ronald
Hi Frank
      besides the Lathe question  which I still want to know for future builds, is it possible to get the realism and the affect you are putting in the Heller without the extras as in out of box category for now incase I'm unable to afford the photo etch set and resin, But I will try to
 get the extras for the kit
                                        Ronald
Hi Ronald.
Well as for getting a good representation of this ship from OOB, its up to the modeler.
I started this project because of the challenge in producing all three fighting decks with there detail.
After seeing Daniels  etched/resin set and liking scratch building, I decided to take the plunge.
Having little or no experience of sailing ships I purchased some books after chatting with more experienced ship builders.
It is from this that I have got so far in the build.
Weather it be larger scales it means more detail.
I started with the Airfix 180 scale Victory.
From that experience I went onto the bigger 1/100 Heller ship.
I messed around with all sorts on that earlier build.
Thus made a diorama with it in the end.
So what I am trying to show is anything is possible.
Just have ago.
You would of course be better with an English speaking plans, but if you have some books, then they will help out.
I hope this helps you in deciding which way to go.
Frank.  :piratebo5:
thanks Frank
  I tried the 1/180 scale airfix kit and was doing fine until I got to the  part where I tried to put the top deck on with out breaking off one or two columns off or a cannon off it's carriage it was a disaster, all that time I put in to that kit wasted the kit fortunately  was free so  if I do the 1/180 scale kit again, I will need help from you and everyone on this forum that built the airfix Victory successfully especially when It will  come to part when I have to install the top deck I tried to get help from Airfix triburte forum  but one fellow no names mention gives me a hard time never nice me so I'm only going to come here for help from now on, so if you can remember that build I would appreciate your building skills on that kit
                        Ronald
Edited by ronald305
This is the friendliest, most helpful site I have ever used so you  will only ever get help on here not abuse...
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
