Spent more time working on the the deck planking today, I have now completed the real hard work, i.e. clearing the gun deck openings for the gratings, companionway, masks and bitts.
Given Pegasus is a 64th scale model, you can appreciate just how big HMS Victory is in comparison, as this a 72th scale model:
Main Mast Gun Deck Openings, with gratings dry fitted
Companionway opening with coaming dry fitted and bitt holes cleared
Capstan and rear grating, not properly dry fitted.
Foremast area with bitt holes cleared
Build hyperlinks
1. Prework - dry fitting bulkheads
2. Beading Line and Rabbet
3. Lower Gun Deck Fittings
4. Grating Assembly
5. Dry Fit Main Gun Deck and Fitting
6. Gun Deck Fitting Prework
7. Lower Gun Deck Glued and Pinned
8. Pre Gun Deck Planking Work
9. Start of Gun Deck Planking
10. Gun Deck Opening Cleared During Planking
Edited by Glennard
Glenn (UK)
Hello Glenn.
I'm taking the weekend off from model building but was happy to see your post.  I believe Victory is 72:1 not 64.  Am I missing something?
Jerry
Time for a progress update, as I continue on with the gun deck planking. I have made good progress today and have broken the back of this task and I would expect to complete next weekend, noting the planking near the bulkheads that have to removed will be completed once the gun ports patterns have been fitted.
Pictures of progress to date.
Build Index - hyperlinks
4. Grating Assembly
11. Gun Deck Planking Work In Progress
Edited by Glennard
Glenn (UK)
Hello Glenn.
Nice to see some more progress on Pegasus.  For somr reason the definition between planks doesn't seem to show up strongly in the photos.  Are you coating the edges of the planking with anything or are you forgoing indication of caulking?  Maybe it's just my bad eyesight.  Best,
Jerry
Hi Jerry.
I'm using a pencil on the edges, but only a light colouring. According to Chris Watton adding effects for caulking and treenails is not necessary for this build based on scale. Hopefully once complete, smoothed with razor blade and varnished it will look more appealing.
Trust your model boat social event was a great night out.
Glenn (UK)
It was a fine time.  There were about 20 models to gawk over and the food was okay.  Good thing I brought my own beer.  Charlene had a good time and it was good to watch her study some of the ships indicating her interest.  We rearranged my space yesterday and made room for her workspace.  She ordered a desk to work on and next comes some hand tools of her own.  She said she's going to have her own log so I suppose her first post should be coming along soon.  Hope your weekend was nice.
Jerry
Been a good weekend, back at work tomorrow, after a few days off with my glass back which seems to be on the mend but going for a MRI scan in a few weeks time. I will look out for the Bounty build log. I'll start work on completing and fitting 34 gun port lids on Tuesday as tomorrow I'll be babysitting the grandkids.
Edited by Glennard
Glenn (UK)
Glenn,
nice Progress on your Pegasus, the gundeck planking Looks very nice....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Glenn -- I've just found your log and have enjoyed reading about your progress.  It all looks really nice, with plenty of attention to detail.  I for one am glad to have another Pegasus/Fly builder working and actively posting (though I have to blush here, since I'm pretty bad about posting myself).  I'll look forward to seeing your progress.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
I have completed the gun deck planking, except for the part which has to be planked after the gun port strips have been fitted and the bulkhead supports have been removed.
I have also fitted the 4 off stern extension pieces.
Finally I had over faired the top section of the first three bulkheads. I noted this at the time, before the bulkheads were glued in position. I did try to get some replacement parts from Victory Models / Amati without any luck which is very disappointing. Perhaps I have been spoil by the tremendous customer service from Caldercraft with regard to obtaining replacement parts. In the end I had to glue some additional strips and fair again as necessary.
Once I'm happy with the fairing I will start looking at fitting the gun port strips.
4. Grating Assembly
12. Gun Deck Planking & Fairing
Edited by Glennard
Glenn (UK)
It doesn't matter, Glenn...You compensated well.  Real nice work on the deck planking; I think it's something special to be able to work two builds at the same time.
Jerry
The forward edges were fine but I managed to take some depth of the aft edges. This was only on the top section of the front three bulkheads as the lower sections required additional fairing. There was no problem with the rear bulkheads.
Edited by Glennard
Glenn (UK)
  • 1 year later...
I last worked on this build 12th April 2015 when I decided to put the project on hold. Anyway over the last couple of days I have been looking at my build and working out what needs to be done.
First task was to order some paints from CMB which arrived today so I painted some of the deck fittings. I took the opportunity to also paint the cannon parts before removal from the sheets, as I think it may be easier this way. I'm still debating what colour to paint the bitt cross members either matt black, red or leave natural. Any thoughts welcome.
I then fitted the deck support beams and installed some of the main deck fittings
Next week I plan pin the two upper decks in place (but not glue in place) before I start bending and fitting the gun port strips.
4. Grating Assembly
13. Main Deck Fittings Painting
Edited by Glennard
Glenn (UK)
Today I was planning on bending and fitting the gun port strips but I realised I needed to spend a bit more fairing the bulkheads. I then decided to fit some balsa inserts to aid to ensure I have a good shape at the bow end and to help with the planking.
Here are some pictures
Glenn (UK)
Today's task was to start fitting the gun port strips. I started this by soaking the gun port strip in warm water for 1 hour, noting I did change the water a couple of times to ensure the water stayed warm.
I did also fit an additional support to stern side of bulkhead 9 last night to help secure the dovetail section when I glue the strips in place.
I took the first gun port strip (starboard side) and begin to pin and clamp to the frame. I found the easiest method was to start with the forward gun port strip and align with the top edge and then clamp the top at bulkheads 8, 7 and 6. Once I was happy that all the gun port openings were clear of the bulkheads I pinned the bottom edge at bulkheads 8, 7 and 6. I then continued to pin and clamp until the strip was eased and secured around the bow. I then fitted the rear starboard gun port strip from bulkhead 9 moving to stern.
I then repeated the above fitting the port side gen port strips. I will now leave the gun port strips in place until the strips have dried out.
Build Index Hyperlinks
4. Grating Assembly
13. Main Deck Fitting Painting
14. Fitting Basla Inserts Bow
15. Fitting Gun Port Strips
Edited by Glennard
Glenn (UK)
The gun port strips dried nicely and retained their shape. I dry fitted them to be double sure and all looked good so I was able to glue them in place without any problems.
I thought this whole process was going to be more onerous and complicated than it actually was; it turned out to be quite a simple task.
In the following pictures I have placed the upper decks in place, but I will remove them when I start the next task of the first planking.
Build Index hyperlinks
4. Grating Assembly
Edited by Glennard
Glenn (UK)
Congratulations on getting those gunport strips on.  From your photos, I have to say they look well aligned.  The back of the quarterdeck seems to tilt a bit to starboard, but that just might be a fluke, since the tilt doesn't show up in the other pictures.  I also have to be impressed that you got the jigsaw joint line up without any big gap.
Well done!
Martin
I've been away for a few days, but managed to spend a bit of time today on HMS Pegasus and fitted the first plank. I used my plank bender to shape the planks and the fitting went very well.
It did required a little bit of sanding in a couple of places, once the glue had dried, to get a good smooth finish between the first plank top edge and the gun port strip. I will sand the hull properly and fill as necessary with filler / primer once I've finished the first planking
I have a busy weekend so I will have continue with the planking next week.
post-7550-0-20168400-1477671264_thumb.jpgpost-7550-0-57227400-1477671277_thumb.jpgpost-7550-0-22864600-1477671291_thumb.jpg
Glenn (UK)
Today I was able to spend a little more time with the first planking. It seems to progressing quite smoothly at the moment.
Front end view
Side view. To help fill in some of the gaps I have been mixing plank sawdust with watered down wood glue and then brushing the pulp into the gaps.
It seem from this picture some of the planks are sitting really proud, this is not the case its a trick of the light casting shading.
Edited by Glennard
Glenn (UK)
Continued on with the 1st planking today.
Bow end. This will look good once I've filled in the gaps with plank sawdust mixed with watered down wood glue and the bumps have been sanded smooth.
Side View
Stern view, I have trimmed the planks and test fitted the stern counter, and all looks good.
I decided to add some planks from the keel.
Bow end, its not a great joint, looks worse in the picture than it actually is, can be easily be sanded smooth and filled without too much effort.
Stern end, I have ensured the gap between the planks is an exact plank width at the stern
Side view
Edited by Glennard
Glenn (UK)
Looks good, Glenn.  Spy's got a good point there.  The first planking doesn't have to look terribly tidy, and I wouldn't worry too much about the gaps yet.  This is the step where you can really see what happens at particular points along the hull, where gaps do want to appear, or where the planks tend to rise too high.  That's the knowledge you can put to work on the 2nd planking (detailed notes help).  And you'll be sanding this layer quite a bit, and that's where the smoothness appears.
The rows just below where you've gotten in these last pictures are the ones I had to work with the most, as that area along the stern makes for a sharp twist.  It's a real education . . .  and loads of fun!
I'm looking forward to your progress!
Cheers,
Martin
I've continued with the first planking today and I thought I would share with method I have been using.
This is a picture of my untidy workshop, showing HMS Pegasus and my two HMS Victory builds [Caldercraft (on hold) and DeAgostini]
My preference is to use peg board pins to hold the planks in place. I find these pins are easy to position and tap in place using a small hammer. These pegs are easy to remove and reusable. As can be seen I have used the kit supplied panel pins in a couple of places.
Sometimes I do adopt different clamping methods to ensure the planks lay smooth together as can be seen in picture below
And this is the end result when the pin are removed. HMS Victory has HMS Pegasus in her gun sights!
Edited by Glennard
Glenn (UK)
Build Log Index
I have finally finished the first planking and I'm reasonably happy with the end result. It's not perfect but its more than good enough to accept the second planking.
I have also completed the initial sanding and the hull is now quite smooth, however there are still a couple of small areas to be filled and sanded before I'm ready to start the second planking. I'm just waiting for a delivery of some squadron white putty to complete this activity.
Edited by Glennard
Glenn (UK)
