Hi world!
I want to show you my current ship model project: the sloop Mediator.
I found the plans of this ship in Howard I. Chapelle book named 'The search for speed under sail, 1700-1855'. I thought it would be an interesting ship for a first scratch work.
In the National Museum of American History, Washington, DC, there is a ship model of the Mediator:
http://etc.usf.edu/clippix/picture/the-mediator.html
And it is my ship model today:
Please, let me to show slooooowly the building process step by step.
P.S: Apologizes to everyone for my awful English.
P.P.S: I put my drawings in this first post. I'll update if any change happens.
P.P.S: Add a direct link to all photographs I have about the Mediator buid:
https://picasaweb.google.com/113346618105593843079/6058494423241948545?authuser=0&feat=directlink
Mediator plans set.pdf
The plans.
The plans i've used for the sloop Mediator are in the book 'The search for speed under sail, 1700-1855' written by Chapelle. I've scanned these plans and I've resized to scale 1:48, I think this is an interesting scale that allows to work with some detail.
Chapelle's plans are two. The first of one is the hull drawings, waterlines, buttock lines, diagonals...
CONV_0688Mediator%2520volumetr%25C3%25AD
And the second one is the sail drawing.
There is an original drawing taken in 1745.
I've started to work with Chapelle's drawings because i found these plans before.
http://collections.rmg.co.uk/collections/objects/86159.html
Edited by carlosgf
My idea was to make a plank-on-bulkhead ship model. The bulkheads and false keel were designed with Autocad. The drawings of Chapelle needed a lot of correctios because the small size of the drawing in the book, distortions of the paper, etc...
I put the plans in the first post and I will to update them if any change occurs. Please, feel free to use them, if You are interested in this model.
Some points:
- The bulkhead and false keel are designed to have a thickness of 5 mm (5 millimeters).
- Under the tramson, there is a rounded stern. I'v seem models wirh plain (square) stern.
Bulkheads are glued to the false keel. This is made in two pieces because size considerations. Chocks (?) are glued between bulkeads to ensure the stiffness of the ship. The edges of the bulkheads are beveled order to facilitate the settlement of the strakes. These edges are drawn but the inner line is only valid if the thickness of the bulkheads is 5 mm (in other case, sand by eye).
Edited by carlosgf
The stem, keel and rudder post are part of an interesting set. Unlike the kits solutions, I've tried to simulate a 'real' approximation.
I have a very few information about America Colonial ships. My assumption is to made this pieces in an English (Great Britain) way. I've made a mix of Cutter Alert (Peter Goodwin), Granado (Peter Goodwing) and Swan Class Sloop (David Antscherl).
Edited by carlosgf
That looks a very nice build.  Unusual for a small ship like that to have a wheel instead of tiller steering.
John
Carlos,
you`re doing very well with this Cesapeake Bay sloop
I love the lines of that upfront Picture of the planked hull in your post #1
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for your coments!!!
The planking of the hull begins with the wale. The main wale (the lower wale) dominates the position of the planking. I put strakes alternatively up and down, joinning in the center.
In the forum you can find manuals of how to make the planking of the hull. I strongly recommend you to read these manuals, The final look is better than the suggestions of some kits... and the time spent in this process is the same (more or less).
There is a reduction of distances fore an aft. The strakes should be reducted in the joining with the stem and stern. There are several methods (i've used both):
- to reduce the width of the strakes
- to make that a strake ends into another one or in the junction of two strakes.
Edited by carlosgf
You have a good start on the Mediator.  I'm pulling up a chair to watch.
Bob
Current build:  SS_ Mariefred
A question: what made you go with a rounded stern rather than a square tuck? most the other models I've seen of this vessel seem to have a square tuck stern in fact I have another set of POB plans for this ship showing a square stern, is this just a matter of preference? or based on historic data?. I'm wondering because I may build the Mediator (or simelar vessel) in 1:20 scale RC once I am done with my Byzantium.
Thanks.
PS. Some of the drawings in the PDF aren't showing up properly such as the rudder which just shows up as the red lines for the table joint.
Lextin.
"I have no special talent. I am only passionately curious." - Albert Einstein.
Thanks.
Lextin.
Hi, Lextin.
As you can see, The horizontal curve 6 ends in the rudder post exactly in the point marked as 'A'. Follow the vertical line until letter 'B'. If the plans of Chapelle are correct, at least in the points B or C, the surface is round. There is no indication about what happens over this point, but in my opinion, this point is too near of the transom and it's is not possible a square stern.
I have no probles with PDF file. Has someone else this problem? Do you have the last version of Acrobat Reader?
Hi, Lextin.
Ok thanks for the information.
I have
Adobe Reader 6.0 and don't know if it the latest version but will try to update it.
In the forum Model Ship Builder you can find a very well done plans of the Mediator, including masts and rigging.
The MSB plans where the ones that I was referring to as having a square stern.
Lextin.
  • 5 months later...
Hi, all...
After a relax months, I've continued with the Mediator. The things I made are:
- gun ports
- sweep ports
- waterways
- spirketting
In addition, I made the plans for spars an mast. They are virtually the same of the Armed Virgina Sloop of Model Shipways, adapting sizes. I will not to include these plans to public release due to copyright restrictions.
Edited by carlosgf
  • 5 weeks later...
Hi all. A few progress:
- fixed blocks in bulwark
- reinforcement in the deck order to put the hatchways, scuttle and companionway.
- holes fot the pumps (note that pumps are inclined, nor vertical)
- hatchway, main hatchway and scuttle
- begining og the deck
- hawse holes
She's coming along and looking good.
Bob
Hello Carlos,
Congratulions to your model. I especially like the combination of  the POB construction and your phantastic timber work on the surface of the model, much like in full scale ship building.
Greetings Rudolf
