Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
18th Century Longboat by tlevine - FINISHED-1:48 scale - from Modelshipways kit - TriClub
  • Please log in to reply
72 replies to this topic
#1
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
This is my build of Chuck's (Modelshipway's) kit of the longboat.  I am building this as part of the Chicago TriClub group build.  The Chicago TriClub is comprised of the three Chicago groups: Midwest Model Shipwrights, Northshore Deadeyes and Nautical Research and Ship Model Society of Chicago.  I plan on painting the model based on the prototype.  Although I had originally planned on building out-of-the-box, I personally found the basswood strips too soft and fuzzy and so all the planking is castillo boxwood.  I have plenty on hand from my Atalanta build.
Two of our club presidents designed a building jig to help with installation of the bulkheads.  This is simply some plywood with two wood strips separated by the width of the keel.  There is a block with the stem width routed in to it anteriorly.  This keeps the keel from flexing as the bulkheads are installed.  Because this is a laser-cut kit, there is some char which needs to be sanded off.  Also all of the cut surfaces must be sanded to that they are exactly perpendicular to the basswood sheet.  Otherwise the keel scarf will not be correct and the bulkheads will not slip into their slots easily.
Once all of the bulkheads were installed, I glued in spacers between the scrap portions of the bulkheads to prevent the hull from flexing once it was removed from the jig.  Finally, the hull was faired.
Toni
Toni
Current Build:  HMS Atalanta-1775 - 1:48 scale
Completed Build: Longboat by tlevine - 1:48 scale
Gallery:  Hannah http://modelshipworl...bum/186-hannah/
#2
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
Chuck suggested twelve strakes of hull planking.  All of the planks were spiled.  I used the tick-strip method of spiling.  A strip of card was placed along the edge of each bulkhead.  That card was then divided into eleven segments.  Because the gargoard strake is a special case, I fit that strake by eye.  Rather than a single run of planking (as suggested in the kit) I used planks that were approx. twelve feet long.  One long and one butt edge was rubbed with pencil to hightlight the run of planking.  The key to a good run of planking is the garboard strake.  As shown in the instructions, the fore end of the garboard strake ends at bulkhead "F".
Toni
Toni
#3
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
The next photos show the hull after nine rows of strakes were installed.  As you can see, the stem snapped off.  I decided to leave it that way until the hull was completed.
Toni
  • pythagoras likes this
Toni
#4
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
The hull planking has been completed.
Toni
#5
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
The hull planking has been completed.  The center of the bulkheads were removed and the ribs were thinned out.
Toni
  • harvey1847 likes this
Toni
#6
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
The sheer rail was installed.  The key to this is making it very oversized and then trimming it with a No. 11 blade and sandpaper.  I also drilled two holes in the keel for insertion of brass rod for mounting.  The frieze was applied with dilute yellow glue.  When I start painting I will improve the appearance of the freize by the stem.
I am going to take a break from this build to return to Atalanta.
Toni
  • harvey1847 and Elia like this
Toni
#7
Ryland Craze
Ryland Craze
  • Members
  • 318 posts
  • LocationMidlothian, Virginia
Thanks Toni for posting your build.  It is a great help for us that are building this kit.
Ryland
              - Nautical Research Guild
Current Build - Armed Virginia Sloop
                      - 18th Century Longboat
#8
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
It is a fun build.  Nice break from something as complex as Atalanta.  Everything I used to build this (other than the thickness sander) fits in the kit box.
Toni
#9
Chuck
Chuck
    Administrator
  • Administrators
  • 7,316 posts
  • LocationRutherford Nj
Looking great.   Its wonderful to see the log up again.  Thank you for that.    :)
Hopefully you will get some company in this forum soon too!!  I will try and reach out to some of the folks who also started logs of the longboat.
Chuck
Chuck Passaro - MSW Admin
Current build - HMS Winchelsea - POB scratch build
                            HM Cutter Cheerful - POB scratch build
       Royal Barge - POF scratch
www.syrenshipmodelcompany.com
#10
Trussben
Trussben
  • Members
  • 1,502 posts
  • LocationQueensbury NY
Hi Toni
Glad to see you have restarted your logs, I just put both of mine back on today, longboat included.
I look forward to seeing your Atlanta and longboat progress, I shall be watching.
Ben
Edited by Trussben, 17 February 2013 - 12:16 AM.
Current builds: HMS Pegasus TFFM, USF Confederacy,
Completed builds:  ECHO cross section.18th C Longboat.
#11
Wintergreen
Wintergreen
  • Members
  • 243 posts
  • LocationÅtvidaberg, Sweden
Great, another longboat :) perfect, since I am scratch building the ships boat for my build.
Thanks for re-posting your work Toni!
Happy modelling!
Håkan
Previous builds
Gallery: BB Regina Build log: Regina by Wintergreen
Billing Boats Dana
Billing Boats Wasa
Upcoming projects: TBD
#12
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
Thanks Ben and Hakan.  It's good to see everybody back in the water.
Toni
#13
Geoff Matson
Geoff Matson
  • Members
  • 569 posts
  • LocationHarvard Illinois
Hello Toni
Great job on the long boat. I will have to put it on my to do list. Thanks for the build long
Geoff
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
#14
gjdale
gjdale
  • Members
  • 3,886 posts
  • LocationCanberra, Australia
Nice to see your Longboat log back Toni.  I have this kit sitting in the cupboard waiting for a "rainy day", so your log will be a good reference when I finally get around to it.
Grant
______________________________________________________________
Current builds:
1949 Chris Craft 19' Racing Runabout - Dumas - Radio
Previous builds: Bomb Vessel Granado, 1742 - Cross Section - ScratchbuildHMS Victory (Mamoli 1:90), Cutty Sark, Armed Pinnace, Bounty, Santa Maria
At another place: Stephenson's Rocket (OcCre 1:24) (click the title to follow the link)
In the Gallery: Lancia Armata 1803, Bomb Vessel Granada, 1742 Cross Section
#15
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
Time again to take a short break from Atalanta (and resurrecting build logs).  I used the second to smallest freize downloaded from MSW for the transom.  The kit supplied ones were too large.  I used very dilute yellow glue to apply the freize and then painted over it with Testor reflectance reducer.
The rail, inner bulwarks, etc. were painted with Polly S Soo Line Red paint.  The rub rail and edge of the top rail were painted with flat white enamel.  The kit instructions suggest using black paint on the stem adjacent to the freize.  I had some blue paint (Testors Blue Angel enamel) which matched the color of the freize and used that on the stem.  I then feathered the paint onto the freize where the blue darkened to near-black.  I will try to remember to take a picture of that and post it next time.
  • Chuck and harvey1847 like this
Toni
#16
Trussben
Trussben
  • Members
  • 1,502 posts
SWEET. :D
#17
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
I went back and took a picture of the painted stem.  Even though I painted over the dark blue/black at the bow, I left the dark color aft.
The floor boards were installed next.  The central one is wider than the two outer ones.  The instructions say to keep the distance between the floor boards the same.  I was uncertain whether that meant constant along the length (and as a consequence tapering the floor board towards the bow) or symmetric so I tried both ways.  Keeping the floor board a consistent width and gradually decreasing the distance between the boards looked better to me.
Once they were installed, I made templates for the fore and aft platforms. The photos show the aft platform stopping at bulkhead 7 but the plans show that it goes aft to the sternpost. I followed the plan.  I used pencil on one edge of the planking to highlight the individual boards.
The riser strake was installed next.  I scribed the top and bottom with an 11 blade using a straight-edge as a guidel  It turned out that the correct distance from the rail was exactly where the paint-natural wood transition occurred.  Another template was used to get the correct shape for the trunk, located aft of bulkhead 7.  Once this was installed I applied a coat of Watco's Danish Wood Oil to the entire hull except for the painted rail.  I am still planning on painting the hull below the water line white.  I don't think I will have any problem with paint adhesion.
  • Chuck likes this
Toni
#18
Chuck
Chuck
    Administrator
  • Administrators
  • 7,316 posts
Nicely done.  :)  :)
Chuck
#19
tlevine
tlevine
  • Moderators
  • 860 posts
  • LocationIllinois
Thanks, Chuck.
I scribed the edges of the thwarts to match the risers.  The top edges were camphered but the bottom edges were left sharp.  The thwart at bulkhead B is wider because of the mast.  I took the scribing along the edge of the bump-out for the mast.  The holes for the belaying pins were marked, scribed and drilled with a #64 bit.  I will install them later.  The mast bracket and support strips were made with the provided brass strip.  I heated the strip in a gas flame to remove any laquer finish and temper the metal for easier bending.  Once shaped, they took a bath in isopropanol and a dive into Birchwood Casey.  The metal surfaces that would be glued were filed to remove the blackening and then installed with CA (one of the few times I have used it on this model).  The thwarts were installed and then a coat of finish was applied.
The cockpit seats and trunk lid were made using the provided basswood pieces.  Even though the thwarts and risers are boxwood, I decided to use the basswood as this area will be painted.  In the pictures they are press fit in place.  I have no paint with me this weekend so they will be permanently installed later.
Edited by tlevine, 24 March 2013 - 06:30 PM.
  • Chuck likes this
Toni
#20
Ryland Craze
Ryland Craze
  • Members
  • 318 posts
You have done a great job on your Longboat.  I enjoy your updates.
Ryland
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
