The making of this model was started in 2006
After visiting the Wasa museum in Stockholm.
It's my 1st wooden ship model.
Normally I only build military vehicles in 1/72 scale
Ps,
I understand and read English.
But i've never learned to write it.
So. All I write in English will be translated from Dutch to English with google translate.
Sorry for that.
Edited by Baker
Title changed from Wasa to Vasa
Good job,Patrick. I specially like the weathered look of the hull planking. Bill in Idaho
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Good job!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Stunning model Patrick. I think we can put the debate of poor model quality by Billing to rest. You have built a lovely model so far.
Thanks for all the photos.
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Peter
Thanks for the positive reaction!!
I received this kit in 1988 (for free !!) :)  :)  ;) .
Partially started by someone else who had built it completely wrong :( .
What is in the box is good qwality for a fair price !
But. Ther is A LOT of extra work on this model.
  • All visible plywood has replaced solid wood
  • Gun ports are made open
  • extra set of cannons for 2nd deck (correct size)
  • Better detailed cannons on the upper decks
  • new deck planks
  • railing completely rebuilt
  • wooden blocks instead of plastic
  • ect..
  • And, I spent hours and hours searching for information on the Internet and books.
All this extra searching and extra work to build this model.
Was more satisfying than a model  you can build out "of the box". Without al the thinking, searching, and improving to build this model.
Greetings
Patrick
Thanks
it is the millitary modeler in my that likes a weathered look ;)
I have seen the Wasa at the museum.
And. The outer side of the hull has a rough finish in reality
Too true Patrick. I also have an old Billing kit and have been replacing the old warped wood with newer material. However, having built several Billing models, I can say that talented builders like yourself can bring out the best in them. It just takes a little extra care and attention.
Cheers,
Peter
Hello everyone.
I have attached the sails and part of rigging.
It begins to look like a sailing ship.
Really impressive work, Patrick
I must admit that the Billing's version , is - in my opinion - the closest to the real thing
Keep up the good work !
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Thanks,
With each step closer to the finish of this model i get more and more respect for builders of wooden model ships.
With the military plastic models that i build, you need tho think always  one step in advance. Or, you get in trouble !!
With wooden ship models it's five steps !!!
As i have discoverd over the past 10 years ....
The rigging is now complete.
Now still to do :
flags
  • The flags that come with the kit are a 30 year old and are a disaster...
Finishing the rudder with rope or chain
  • I should have done this at an earlier stage. I have now discovered
anchors
Lantern??
  • Had the Wasa a lantern or not???
Creating a base for the model
Patrick,
Nice work indeed. Lantern is a mystery in terms of how it looked. Salvage did not locate the original. Here are some poss. examples.
first two pics are from Landström's book. Thought Fred Hoecker does not think that the angels were included.
pic. 3 may be actually more representative. Hope this helps
PS: I will build mine looking like the book's without the angels (just as well I can't carve (:-(  )
Cheers,
post-735-0-29644400-1468338131_thumb.jpgpost-735-0-29320300-1468338168_thumb.jpgpost-735-0-06518800-1468338212.jpg
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks Michael,
I go for the easiest solution (number 3)
The lantern with the angels is far above my skill.
I have some material to use as a base.
But if that does not give the desired result
Then it will be something scrathbuild. Mayby in plastic and then painted.
Greetings
Patrick
The lantern
I started with the difficult way. We'll see what the result will be
if it succeeds then I will make a drawing of it
But, there is a plan B (picture 1 right side)
The anchors are finished.
The wood parts are painted with oak varnish.
The metal parts are painted with Tamiya acrylic paint
  1. Base coat :Gun Metal X10 + Flat base X21
  2. Let dry for 24h
  3. Apply a wash with a mixture of "home made" rust paint : Desert sand XF59 + Red Brown XF64 + thinner + water
  4. Let dry for 24h
  5. Attach the wire around the ring of the anchor
  6. Applay a wash with a mixture of Flat black XF1 + thinner + water
  7. Let dry for 24h and ready
They will be attached later on the model.
Patrick
Good show Patrick !
How do you come to shipbuilding nowadays ?
Only the thought of painting,... ( how small some parts may be ) makes me sweat already  :)
Kind regards
Christian
A few drinks a day, keeps the heat away
New Belgian way of life ..... ;)  :P  :rolleyes:
And I might have luck with the lantern  :)
Patrick
Hello everyone
Jan,
I Hope you find our Belgian beers delicious ;)
I stick to maximum two beers. Otherwise I have always a hangover the morning  :wacko:
well,
The lantern is fixed on the ship
It is not a plan or a plan b
But something in the middle.
After three unsuccessful attempts to make wings for my angels. I decided that my angels will remain wingless.
I had reached my limits in scratch building.
On my lantern I have used figures in 1/72 scale.
Therefore, there is not enough space between two figures to put wings on them.
But,
I found pictures of a lantern on the Duth VOC ship The Batavia (build in 1627-1628).
Here is shown a lantern with approximately the same figures, but without the wings.
Wasa and Batavia are both build by  a dutch master
So why not go further with this example, I decided.
So if someone wants to build my lantern with angels and wings.
Make the lantern wider or use figures in scale 1/87
Any figures that you want to use, use figures without helmet. Saves a lot of work!!
I have attached a pdf with a drawing
Dimensions are in mm (1 millimeter = 0.0393700787 inches)
(Extra small details in plastic strip are applied on the lantern)
Painting is gold and gun metal)
post-24614-0-37896400-1469944723_thumb.jpgpost-24614-0-99587100-1469944725_thumb.jpgpost-24614-0-87350900-1469944727_thumb.jpgpost-24614-0-90359800-1469944729_thumb.jpgpost-24614-0-74811100-1469944731_thumb.jpgpost-24614-0-29477600-1469944733_thumb.jpgpost-24614-0-29477600-1469944733_thumb.jpgpost-24614-0-80688600-1469944734_thumb.jpgpost-24614-0-30389900-1469944736_thumb.jpgpost-24614-0-33183500-1469944738_thumb.jpgpost-24614-0-33183500-1469944738_thumb.jpgpost-24614-0-31261100-1469944764_thumb.jpgpost-24614-0-02113100-1469944767_thumb.jpgpost-24614-0-71582900-1469944765_thumb.jpg
schets lantaarn.pdf
The rudder is fixed  with rope and the anchors are in place
Now it is searching for flags and attach them. And then the model should be finished.
For now it's back to military modeling. And in the meanwhile think what model ship I'm going to build hereafter.
Patrick
Edited by Backer
Patrick,
Brilliant work with your lantern !!!  thanks for the pdf. Enjoy your next project
Cheers,
Under the table:
Completed:
Vasa-Corel -
I have attached the plans from Billing Boats.
The PDF is reduced to get below 2 mb but is still from good quality
Normally they can by downloaded from the site from Billing Boats. But apparently they are no longer available on their site.
After the holiday period I'm going to order the flags.
Patrick
BB490 Wasa_Instruction-2-min.pdf
BB490%20Wasa_Instruction-min.pdf
I found flags on the internet of the Wasa from Corel.
For some reason they sent me two sets for the price of one  ;)
The flags are cut out and fitted with brass rings and then mounted on the masts.
Maybe there are more appropriate methods but I find its ok in this way.
My model is now finished  :champagne:
When I started in 2006 I wanted from the beginning to build a model as accurate as possible.
For my. This was not completely successful. But I'm happy with the result !!
( Apparently, the success rate to finnish your first wooden ship model is about 19%. So, happy my!! )
When I  started to build i had just the pictures of my visit to the museum.
The drawings from Billing, a keel with frames that were partially built wrong and a box with wood and parts.
Then, there were no correct color schemes available.
So there is too mutch red paint on the hull. And the figures do not have the correct color.
And, I did too many nails into the hull .....
Conclusion
The model from Billing is a good model for a  reasonable price.
But there is a lot of extra work on it.
Thanks to everyone who has followed my build log.
Now it is first study time for my next project
Greetings
Patrick
Edited by Backer
Congratulations Patrick  :cheers:
I'm looking forward to your next build.
Any chance for a front-seat reservation ?
Kind regards
Christian
Congratulations Patrick.  You've done a superb build of her.   I do agree that Billings kits need a fair amount of work and a lot of scratch building but you got this one perfect.
Thanks for the positive comments
The next build is still in preparation.
It is too early to start a build log.
Ps,
All reservations are free of charge  ;)
