Posts posted by James H
- Old Collingwood, lmagna, JeffT and 6 others
9
STAGE 69: ADDING A HEEL DETAIL AND ASSEMBLING FOOT PARTS
Every foot needs a heel, and this is now fitted, with a single screw locking things into position.
Now it's the turn of the toes. Some of these parts are angled, but if you follow the manual, you'll see the toe parts have an indent on one side with a part number on them. I used these ass reference to make sure I got the toes correctly positioned. The grub screw also has a little thread lock to stop it coming part later.
The toe tip and other toe part are fitted using a plastic bush insert and ridged pin to lock into position.
STAGE 68: FITTING THE ANKLE JOINT TO THE RIGHT LEG
All three pistons are removed from their sprue and the two shorter ones fitted with the rubber end caps with a black, flanged screw. The knuckle joint is also assembled and pushed into the lower leg.
I do have to say these pistons are way too sloppy. There's zero traction with the piston bodies and they wobble around like mad. I'll think of something to correct this...maybe a plasticard tube wrap for the shorter pistons. As the longer one has no rubber cap, that can't be changed, but it shouldn't matter with the other two being more sturdy
The foot is now pushed into position.
- lmagna, mtaylor, marktiedens and 5 others
8
STAGE 66: ADDING ANOTHER PART TO THE LOWER RIGHT LEG
Onto another piston fits two end caps. These can only fit specifically to the correct ends, and they are simply a push fit.
Another screw and bush fitting are used to fit to the lower leg assembly.
Small details are fitted using a small drop or two of CA.
A single screw and spring washer is fitted, connecting the lower right leg to the T-800. This can be posed in any position, but I left it neutral. I don't know how easy it will be to loosen that screw when complete.
- GrandpaPhil, Rik Thistle, JeffT and 5 others
8
STAGE 65: ADDING ANOTHER PART TO THE LOWER RIGHT LEG
Another piston is fitted in the same way as the previous.
The lower leg outer casing is now fitted. This also has a keyed system that stops it being incorrectly placed.
The shin is now fitted. A few spots of CA are needed at the top and bottom, and once in position, a screw fastens it to the stationary piston.
- JeffT, GrandpaPhil, Rik Thistle and 3 others
6
- mtaylor, Egilman, GrandpaPhil and 3 others
6
STAGE 62: FITTING THE KNEE CAP AND KNEE JOINT
Another ratchet disc is installed, and along with the knee cap that's assembled with CA, both assemblies now fit to the one in the previous stage.
The knee is now fitted to the leg. A hex key is used to tighten the joint. This can later be loosened so the model can be specifically posed.
- mtaylor, GrandpaPhil, marktiedens and 4 others
7
Pack 7
Pack 7 is finally done, and the T-800 is definitely growing in stature, even if he still doesn't have a leg to stand on. 😆
I am a little wary of now just picking it up via the chest cage, so grab by the pelvis now too. I don't want to put too much strain in one area.
- lmagna, Egilman, marktiedens and 4 others
7
2 minutes ago, captain_hook said:
I‘m going to a endocrine surgery tomorrow, so I will be off modeling for some days but hopefully will continue the build before Christmas.
Hope all goes well. Kidneys can be tricky things at times.
- captain_hook and Canute
2
That looks real good. I'm a little concerned about some of the parts of my jig being warped. I'll need to screw them down dead flat to make the keel fit like you have.
- JeffT, yvesvidal, captain_hook and 1 other
4
STAGE 90: REAR LIGHTS, LED WIRES, GAS CAP, GAS PIPE, CABLE HOLDERS
Before I can start the wiring, the gas cap and gas cap base are fastened together using the small hinge and shortest small screws. This is then pushed into position and secured with a screw. The gas pipe holder is then also fastened into position, using screws from the outside rear.
The right rear light is pushed into position...
...and the rear right LED strip popped into place. I did find that before I could fit the light holder, that I needed to clip down the LED tails on the soldered joints as they protruded a little too far and stopped the holder fitting snugly.
With the holder in place, the cable is run in its channel and the cable clips used to hold it down. Again, a spot of CA was used to make sure these didn't eventually come loose when everything is finally assembled.
Things really are getting close to finish now. Here's where Pack 11 leaves us.
One more to go. I'm really hoping I see that pack before year end!
STAGE 89: LOWER REAR BODY SECTION, TRUNK HINGES AND BRACKETS
The lower rear body part is now offered up to the rear of the main body and secured with six screws.
Both trunk hinges are fitted to the lid and the trunk led fitted to the main body, using the hinge brackets to hold in position. These are metal, so no chance of them being bent with any force.
- GrandpaPhil, mtaylor, Canute and 5 others
8
STAGE 87: CENTER LIGHT BRACKET, HORNS, HOOD PINS, FOG LIGHT LENSES, LED SYSTEM, WIRE HOLDERS
The centre light bracket and holds are fastened to the front bracket. The hood pins are now pushed into place and the hood closed to ensure they located through the holes in the forward hood. I found the hood would then snag them and pull them out again, so I used a little CA to fasten the pins.
Now the headlights can be wired up, with wire 07 to the left, and 08 to the right. A cable tidy helps hold the wires in place when installed.
Some white glue (PVA) is used to fit the fit lights. I didn't use CA here as it can fog clear plastic.
The front is then offered up to the main body and screwed into position, making sure the headlight cables fit neatly through the holes in the front bracket. The cables are then run through the. body channels and held into position with wire clips. I wasn't very confident that those clips wouldn't later come loose so I used a tiny spot of CA to hold them in place.
The hood pin plates are now pushed into position and the lanyards/Lynch pins attached.
STAGE 86: HOOD HINGES
The hood hinges are now fitted to the hood. There are three different types of screw used for this, so care needs to be taken to get this right. There's quite a lot of tension in these when built, and it's a good idea not to keep operating these until fitted to the car as the slider won't cleanly operate until then.
Four screws now secure the hood to the main body. The hood needs to be inserted an an angle and then slid upwards at the rear to locate it. I had to move the hinged slightly to get this into position. I also noticed that the hood wasn't even to the fenders on each side, so the fenders needed to be slackened off and realigned to the hood.
STAGE 85: HOOD, FRONT GRILLE, HIGH-BEAM HEADLIGHTS
To attach the Shelby logo to the front grille, two little tabs need to be bent inwards. These then snag onto the badge locating pins, holding it in place.
The other tags now need to be bent inwards, fully. The grille can then be fitted to the grille surround, and the tags then bent backwards to lock the grille into its surround. The surround is then screwed to the front Cobra assembly.
The next thing to fit are the headlights which just push into the grille surround from the front. The screw position needs to be pointing upwards so they are angled correctly.
Pack 11 - almost there!
By far the LARGEST box to yet arrive from Agora, but hardly surprising when you consider it contains the GT500's main body. This is also a heavy box too as the largest components are metal, such as the body, hood and trunk etc (bonnet and boot, to us Brits!). There's no worry about this arriving in one piece either as the main body is contained inside a secondary bod, packed into dense polystyrene. The other packs are sat on top of this, with some of them now being blister packs again, and not just sleeves. Here's how things look when it arrives:
STAGE 83 : MAIN BODY SECTION STAGE 84: UPPER & LOWER SIDE SCOOPS
This one is quite simple. Before any work started, I used some protective foam to cover the paint stripes as they can be easily damaged when working. The model was also laid on a bed of bubble wrap for extra insurance.
The fender assembly is now fastened to the main body by four screws.
Duchess of Kingston 1798 by glennard2523 - FINISHED - Vanguard Models - 1:64 - Royal Yacht by Glenn Shelton
That really looks like it's coming along very well, and your adjustments have nailed it with the bulwark to deck fit.
