Posts posted by James H
24 minutes ago, glennard2523 said:
The instructions are clear as day and follow a nice logical sequence. Mine was a simple error. After pre fairing the parts as instructed I simply forgot to fit the mast supports as I had put them away for safe keeping. Old age I'm afraid.
I get moments like that too and I'm 50!
Carry on! 🤣
- chris watton and Glenn-UK
1
1
2 minutes ago, Jim Rogers said:
Yes, I wrote Technical Documentation for Torpedo Maintenance. The Technical Manual would have in depth procedures whilst the checklist would be abbreviated. Example the technical manual would explain that part 15a should be installed in bulkhead 15 after removing char and test fitting. It would explain any placement processes. The checklist would say: Install 15a (para 3.1) . Using a checklist means steps don’t get missed in the verbiage.
I don't want to hijack this log at all, but this is in the manual I wrote:
1 hour ago, druxey said:
You should patent this design and get Byrnes Machine Tools to manufacture it under license! It is far superior to the usual plastic cutters.
Definitely.
There is a metal rotary circle cutter but the blades are very fine and not suited for stuff like cutting those abrasive paper sheets.
Moved to correct forum area.
8 hours ago, Jim Rogers said:
It would be great if an abbreviated checklist came with the written instructions.
Can you explain what you mean?
It happens.
Look at the part numbers on these early stages. If low numbered, you can guarantee they are needed very early on.
- BobG, chris watton and Glenn-UK
2
1
2 hours ago, Landlubber Mike said:
Really nice work James! What a cool little project. Are you planning on painting it?
Not on this one as Tom wants to use it for an English language instruction manual/leaflet.
Still, it actually looks very pretty in bare timber.
- Tankerman, Canute, Old Collingwood and 5 others
8
That longitudinal pattern should fit snugly, but you need to tease it down all of those slots a bit at a time or it won't seat properly. There are a lot of slots you need to make sure won't snag those parts.
This was why I thought it a good reason to dry fit a lot of this and then paint glue into the joints when assembled.
I was wondering where you'd gone 🔭
Hope things are back on an even keep soon and wed can see this one progress.
- popeye the sailor, mtaylor and Canute
3
I've not been idle this last week.
In between finishing build work on a Tiger Moth for a mag article, I've been cleaning my man cave and getting things back into order. What time I've had left, I've put into some extra work on this. As I said, Tom will use this for his manual, and that's why I've not used any paint.
The next step was to glue the column bases into position, followed by the columns themselves. To ensure I got those columns vertical and evenly spaced whilst setting, I slid the pavilion upper former into position. Small pots of paint (same size) were used to make sure that part was even all around until the columns dried. It was then removed.
Next come the 5 sets of walls. It's important that you get all these so the pattern is the same on the outside or it will just look odd. If these look familiar, remember that the symbol was a Buddhist one long before it was misused in the 20th century.
Those walls are now glued into position using the etched markings on the floor, and the benching part slid down the columns. At this point, I glued that upper former into position at the top of the columns as it provided that extra rigidity.
These parts here are the frames onto which the seat backs will mount.
The seat backs were soaked in hot water for 30 mins and then wrapped around a 2kg weight and bound tight. This was left overnight on a radiator.
The seat backs were now carefully glued into position.
Time to pretty up the top area of the pavilion. Several panels, both decorative and plain are now glued into position.
The next stage is the roof, but that will take a week or so until I can get onto it as I need to finalise my magazine project.
This pavilion is a real nice kit and a wonderful diversion whilst still sticking with timber modelling.
- marktiedens, JeffT, gjdale and 13 others
16
Something real satisfying in adding those walnut strakes.
Looking real nice.
I'd still paint that upper area all black instead of using a third colour though, but that's me. Will look nice with a registration number added too.
- Keithbrad80 and EKE
2
To protect the painted hull against any char on the cradle, I glued a few strips of thin styrene over those contact areas.
- BobG, chris watton, Jim Rogers and 2 others
4
1
Just remember that there is a lot of soaking to do on key parts and pear expansion is a LOT.
It really is a good idea to leave those parts overnight (at least 12hrs) as you can still have a reasonable amount of expansion present in the last hrs before use.
- Glenn-UK and chris watton
1
1
I was going to say 'precision clamp' is generally an oxymoron in this hobby, but I'm definitely wrong here!
Beautiful work.
- mtaylor, Ryland Craze, druxey and 1 other
4
Skipton is a lovely place and I'm not 'too far' away.
For clamps, I don't think you can beat these:
https://www.amazon.co.uk/gp/product/B06XFRCRLH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Hope to see that build log here real soon. Oh, and...
52 minutes ago, glennard2523 said:
Do you add any mast rigging such as the shrouds, less the deadeyes prior to installation, as it might be easier to size them under the crosstrees prior to installation. I am also interested to know how tight the shroud is sized to the mast as it is not clear from your build photos.
I added the rig blocks to the masts as on the plans, and the deadeyes to the channels only.
All shrouds were added after fitting the masts, and it was quite easy. There's nothing stopping you adding the seized lines to the masts before you fully assemble and add the cap blocks. You could just tie them back while you fit the masts. I didn't tie them hard around the mast. There was a little play to allow me to spin them round the mast and thread them through the correct side of the crosstrees/mast top.
I"m also keeping this one unpainted as the timber looks real nice as it is. The laser char on the roof tiles should really set itself off against the pale ply.
- lmagna, yvesvidal, Ryland Craze and 6 others
9
On 11/3/2020 at 12:01 AM, glennard2523 said:
I have pre ordered this kit and you have done an awesome build.
Do you find it better to build and install the entire mast assembly before you start the shroud rigging?
I always build the complete mast and then install. Being able to handle it separately means I can eyeball and measure things to make sure all sections are in alignment.
That turned out exceptionally well
Those little unused 'triangles' are yard cleats. Not used (from memory) on this model.
As I'm currently in ship-building hiatus (not for long), I thought I'd make a start on CAF Model's Ancient Chinese Pavilion kit, reviewed here.
At the moment, I've only got the base built up, but the fit is superb. This consists of two hexagonal plates with one of these being engraved and containing the holes for the pillars. There are six side pieces which have engraved bevel marks. The material is ply, but really nice stuff with no warp. Before starting, everything is given a nice light sanding with some 320 grit paper.
I found a knife the best way to evenly bevel the size piece ends.
These are then glued in with Titebond and the the lid temporarily fitted whilst the sides dry. The lid of the base is then finally glued in position and elastic bands used to hold things nice and tight.
Char removal is now done with a piece of 80 grit paper, followed by finer grades so there are no surface scratches.
...more as soon as I've actually done some!
- Ryland Craze, JeffT, RichardG and 10 others
13
Chris Watton and Vanguard Models news and updates
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Fresh from Vanguard Models. A 'sign' of things coming...
