Everything posted by TBlack
Keith, Nicely explained. And do I understand that you thread the ratline thru the shroud, not just touching it? Tom
Thanks, Keith, bro, and all you others who are taking your precious time to follow my modest attempts. I do think that I've figured out how to accommodate an aft cabin and quarterdeck without altering the brig's lines too much. There are still a couple of issues that I need to sort out. Not the least of these is here: The joint with the stem is disturbing, and I can't get it any closer than what you see. The waterline will come just at the notch, so not to worry below that. Above I'll have to fill with pear paste. And then not look too closely!
- 341 replies
- Sophie
- Vanguard Models
A little more progress. I've gotten the rest of the siding on both port and starboard plus molding strip along the top: As I mentioned in my previous comment, the gun ports on the kit are higher than the painting. Also, you'll note that I finally attached the keel. She sits in the cradle much better now. Tom
- 341 replies
- Sophie
- Vanguard Models
Keith, bro, You're setting a standard for family modelers that I'm having difficulty meeting. Can't you make a mistake once in awhile? Tom PS I don't care what you think; mom clearly loved you the best!
Keith, yes, she’s coming along OK now. I keep thinking I’m at the point when I can start following the kit instructions, but then remember some other detail. If you go back and look at the book cover photo in post 128, you’ll see that the hull planking is different than the kit which is straight pear. Also, the spacing between the tops of the gun ports and the top rail is smaller in the kit than in the photo. So, I’ll have to make some adjustments.
- 341 replies
- Sophie
- Vanguard Models
Stern gunports installed. I kept knocking off the top rail, so I removed it until I'm finished with the quarterdeck detail:
- 341 replies
- Sophie
- Vanguard Models
Of course, my first idea was to donate the books to the NRG library only to discover that we had dissolved the library several years ago (I'm not really up on current events). In terms of an heir; it's actually my mom's dad who has given me the ability to do this. Also, I need to thank "anima" (Jeff Wall) who actually made all of this happen. Tom
Amen to that (see HMS Sophie)! Tom
- 200 replies
- Whaling Bark
- Charles W Morgan
So, the final resting place is your family room? You need to have a lot of "open houses" so a broader audience can appreciate your art/craftsmanship. Tom
If my memory serves, didn't the tortoise win the race? Tom
- 200 replies
- Whaling Bark
- Charles W Morgan
Comfortable looking library. If you’ve gotten plumbers to come out during the holiday, you’re doing good!
- 3,560 replies
- clipper
- hull model
It occurs to me that the fit of the netting is so perfect that a large part of the battle was to get the dimensions right in the first place. Damn you're good, Keith! Tom
OK, Keith, we agree on the davits, but I’ve made two mistakes. If you look where I’ve placed that top rail over the stern, you’ll see that the davits have to go right where the rail meets the transom. Gotta make that rail shorter. The other mistake you can’t see from the picture of the painting of the ship’s stern, but the painting on the cover of the book shows two gun ports in the transom. Guess I’m not done yet! Tom
- 341 replies
- Sophie
- Vanguard Models
OK, so I found the molding material. Did my best on the tricky corners and added the top rail: Now the tricky parts are the stern davits: My understanding is that, normally, these run along the top rail for support. But these don't. They just stick out from the transom. I think I'm going to depart from the photo and put them on the top rail unless you guys think otherwise.
- 341 replies
- Sophie
- Vanguard Models
