Everything posted by Landlubber Mike
Landlubber Mike's technique for furled sails
Landlubber Mike replied to Landlubber Mike's topic in Masting, rigging and sails
To keep all my furled sail posts together, here are my posts on how I furled the driver on my Badger build. Furled Driver Sail Here is what I did for the driver sail. I've seen these types of sails under a variety of names, including mizzen sails, gaff sails, driver sails and spanker sails. I think mizzen and gaff sails refer to the overall category of these types of sails. From what I can tell, "driver" and "spanker" are particular types of sails where the driver is associated with a boom, whereas a spanker is set free without a boom. The Badger has a boom, so this sail is a driver. Before I get too far, it might be worth attaching a diagram of a gaff sail's parts: In some ways the driver was easier than the other sails, but in others, it was more complicated. Unlike the other sails where the sail is bent to the yard on only one edge of the sail (the head for the square sails, and the luff for the fore sails), the driver is attached on both the head and the luff. So rather than furling the sails in one general direction, furling the driver takes on multiple directions. On real sails, this was accomplished using brail lines that start along the leech side, and run up to the head and luff ends. A bit hard to explain, but this picture might help. From my research, it seemed like gaff sails had around 5 brail lines, with 2-3 on the head and another 2-3 on the luff. The diagrams I've seen, however, on how/where the clew was furled differed from resource to resource. Some diagrams show a brail at the clew. Others show the bottom most clew on the leech as being about 2/3 of the way down the leech (and not at the clew). Then there is the matter of where the clew ends up. Some diagrams had the clue ending up at the throat, others, midway along the luff. So, a lot of things to consider. The next post will outline my approach. -
Next step was to furl the sail as much as possible off the build before attaching the gaff to the main mast: I was able to completely furl the head area along the gaff up to the throat of the gaff. You'll see I used three gasket type lines to hold the furl here, to somewhat represent the brail lines. Not sure if this would be accurate as I think the brail lines actually ran through brail blocks at the gaff, and then were belayed down to the deck. But, this would have been overly complicated at this scale, not to mention that multiple pins and cleats would have to be added. So, I went with these three gasket type lines. Ultimately, I went with two along the gaff, and moved the remaining line to the throat area of the sail (and not at the throat of the gaff itself). I was also able to get the luff edge furled pretty well at this stage as well. My plan of not angling the foot worked out pretty well, as you can see that the bulk is greatly reduced at the tack, with most of the bulk at the throat. In case you're wondering, I'm using napkins under the red clothespins because I've found that the color on these colored clothespins can rub off on the sail cloth From there, it was a matter of installing the gaff and lacing it to the mast. As noted above, the lacing for the mast is a bit different than the lacing to the gaff - I think zu Mondfeld has 10 different approaches in his book. From my research, part of the reason for the different lacing was so that the sail could slide more easily up and down the mast. I used the mast lacing pattern as in this diagram: Next I furled the rest of the sail, and added two more brail lines against the mast. I also added a block and tackle arrangement at the deck as you can see in the third picture below. I'm also planning on adding the outhauler line, which would run from the tack clew, through a sheeve at the end of the boom, and belayed at a deck cleat at the base of the main mast. The kit plans have two pairs of deck cleats to be installed at the base of the main mast, with only one pair used, so all I needed to do was add an extra pair of eyebolts to the deck. They still need some work to try and get in some folds, etc., but overall it came out somewhat ok I think. I'd also note that in addition to real drivers having brail lines and blocks, there are a number of other inhauler/outhauler lines at the peak, as well as lines at the end of the boom. For my build, I thought they would add too much complication given the kit's pin and cleat configuration, and I had already installed them per the kit plans before deciding on the furled sails. So that's how I added a furled driver. There are probably better ways of doing this, but hopefully this helps give people a jump start on how to approach them - I had searched all over the internet for methods on how to install a furled driver, but couldn't find any so hopefully this helps a bit. Thanks for reading!
- 153 replies
- badger
- caldercraft
My approach Like the other sails, I started by drawing a general outline of the driver sail, tracing the plans for the gaff, main mast and boom, and then just drawing a line for the leech end of the sail. The next step was to draw the pattern for the reduced sail. Here, there were three considerations: (1) how to reduce it enough that I could get a tightly furled sail; (2) how to design the pattern so that the furled sail bulk would be thinner at the peak and tack, and thicker in the area in between; and (3) mechanically, how would I proceed with the furl given that the furl takes multiple directions along the brail lines. Here is what I came up with: The total bulk of the sail is reduced to about 40% of the full sail size. The depth along the head and along the luff is about the depth of what I used for the furled fore and main course sails. The shape is a bit odd in that at the head area, the leech end is angled inward, while at the foot, it runs parallel to the boom (on actual mizzen sails, I believe the foot of the sail was curved). This was because of the way I planned to furl the sail. First, I furled the sail up to the gaff, similarly to how I furled the square sails. So, the leech end, like the sides of the square sails, was angled inwards to reduce bulk at the peak. Second, I furled the sail at the throat area and the luff side. The foot is parallel to the boom and not angled as the head was because I realized that as I furled the gaff area, the outer edge of the foot would be pulled upwards, essentially angling the leech end near the foot upwards. So, there was no need to cut the pattern to an angle like I did with the head (otherwise, I would have almost no sail to work with at the tack). Hope that all makes sense. The other thing to note is that I added a mock clew at the edge of the sail. Given the shape of the overall driver sail, I thought the clew on the actual sail would end up midway along the luff, rather than at the throat. I also wanted to add an outhauler line that was attached to the clew. I modeled this off the MS Brig Niagara instructions, where the clew is brailed up the middle of the luff. With the pattern cut, I prepped the sail to attach it to the gaff. I added lacing holes along the head (5mm apart) to run the lacing to the gaff. I also added cringles along luff area (10mm apart) so that I could subsequently attach it to the mast. I also added clew and tack cringles at those areas. From my research, it seemed that these sails were bent to the gaff with simple lacing that ended at the throat of the gaff. I went with 5mm apart for the holes, which was what I used on the square sails. The sails are bent to the mast using a different lacing pattern (shown in the next post) using cringles, which I represented by running a line of thread along the edge using fabric glue, and pulling it up every 10mm to create the cringle. Given that the sail will be furled, these will not be visible later on. They did serve as a good guide for the mast lacing however, which I couldn't accomplish using holes drilled into the sail itself.
- 153 replies
- badger
- caldercraft
- 153 replies
- badger
- caldercraft
Jib sail. The jib sail was simpler in some ways (not requiring the netting/horses or figuring out what kind of stay to use), but requires a special piece of hardware called a "traveler" which is detailed below. Similarly to the staysail, I had to cut down on the size of the jib sail to ensure a tight furl. Looking at pictures of ships with furled sails, as well as the pictures in the Harland book, it's amazing how tightly these sails were furled. The jib had more running room, so I went with a larger sail than the staysail - I also wanted to run it up the jib stay a bit higher than the staysail, so I needed more cloth to work with. Construction was very similar to the square sails on the yards - using fabric glue I added bolt ropes and cringles. As mentioned above, for the hanks I used very thin beading wire which is much more flexible than using brass wire. The wire was looped around a brass rod in a spiral shape, painted, then cut as needed and shaped into a loop. Real hanks had a more complicated shape which I couldn't duplicate at this scale, so I just went with simple loops. I also painted them brown because it seems like these tended to be wood. The pictures below show the sail (with the sheets installed), as well as bent to the jib stay. The pre-furled shape of the sails is probably a bit different in the angle at the tack is the angle formed by the jibboom and the jib stay. I figured that this would make furling the sails down to the jibboom a lot easier. Setting up the jib was a lot easier than the staysail, except to the extent that I needed to built a traveler. The traveler has three main pieces: the main loop that goes around the jibboom, the shackle that runs forward to the end the jibboom on which the outhaul is attached, and then a hook to which the jib's tack cringle is attached. These were created using brass wire and a hook from the kit. A block is also attached to the traveler for the downhaul. The traveler itself (minus the shackle) was covered in leather for protection. I didn't bother to simulate it as such but just left it as blackened brass. Here is how the rigging proceeds: 1. Jib stay: The jib stay is attached to the traveler ring, through the hanks on the sail, up through the top sheeve on the cheek block on the starboard side, and down to the aft end of the starboard fore channel. Given the size of this ship, it seemed correct to tie it off directly, rather than use a block and tackle arrangement as in larger ships. 2. Outhaul: This line is tied to the shackle of the traveler, runs forward along the jibboom through a sheeve, to a timberhead on the starboard side. This functions similarly to the tack for the staysail in that it establishes a fixed position for the sail along the jibboom. 3. Downhaul: Similarly to the staysail, it attaches to the peak cringle, runs through a few hanks, down through the block attached to the traveler, and belays to a starboard timberhead. 4. Haliard: Similarly to the staysail, the haliard is run from the peak cringle but up through the lower sheeve of the starboard cheek block, and belays to a timberhead opposite by the aft end of fore shrouds, starboard side. As with the staysail, I ran these without a block and tackle for two reasons. Historically, it seemed smaller ships did not use a block and tackle. From a practical standpoint, and probably more importantly, adding a block and tackle would have been very hard to achieve given the scale and general size and busy-ness of the ship. So, I felt comfortable not using block and tackles. 5. Tack: The tack is attached to the hook on the traveler. 6. Sheets: The sheets are run just like for the staysail. Here's the end result (sorry, had the TV on in the second): Hope all this is helpful (and accurate and correct!). I found that there was a lot of information online for furling and adding square sails, but not much really on the fore and aft sails. I spent many hours trying to figure all this out from the resources mentioned above, and at least to my eye, I think they really improve the ship. So, if I can give back to others for all the help I've received on here in the past five years, I'll feel very happy. -
Fore topmast staysail. This sail took a ton of planning as there are a number of ways that these could be installed on a ship - bent to a fore topmast preventer stay, bent to a fore topmast staysail stay, and I think they could also be set flying (no stay at all). Then there was the question of how to run the haliards - single, double, etc. Based on Lees and TFFM, I decided to add a fore topmast preventer stay and bend the sail to it. Not sure if this was 100% historically accurate, but this route helped simplify things a bit as the preventer stay would use the existing bee sheaves in the bowspirit, and the running end would end in an eye and mouse around the mast, rather than have a running end that ended in haliards somewhere down the mast. It also added a sense of symmetry with all the rigging, which is more artistic than anything. Another reason to go with the preventer stay over a staysail stay was that there was not much room to furl the sail as it was given the proximity of the fore stay and fore preventer stay, but using the bees gave a couple of millimeters of extra space. As you can see in the picture below, the staysail is probably only 25% of what the full sized staysail would look like. This was to ensure a tightly furled sail and keep the sail in front of the fore stay and fore preventer stay. Two other things I had to add to the model for the staysail. First, I needed to add a cheek block on the port side of the fore topmast head (I also added one for the jib sail on the starboard side). Second, from Lees, Petersson, and TFFM, the staysail was not laid on top of the bowspirit, but instead was laid on top of a netting between the bowspirit horses. So, I added the horses and a simplified netting run between two staves that the horses went through. I unfortunately don't have a picture of this, but the staysail covers all of it so I didn't go all out with a very detailed netting. After all that, the rigging of the staysail is fairly simple. The staysail is triangular in shape with a peak cringle at the top, the tack at the fore bottom corner, and the clew cringle for the sheet pendant at the aft bottom corner. After threading the fore topmast preventer stay through the hanks on the sail (constructed of beading wire from a local craft store and painted brown): 1. Peak cringle: The haliard (to pull the sail up the stay) is run from the peak cringle up through the lower sheeve of the port cheek block, and belays either to the foot of the fore mast or to a timberhead opposite the after fore shrouds, port side. Also attached to the peak cringle is the downhaul (to pull the sail down the stay). The downhaul is threaded through a few of the hanks, through a block attached to the foot of the stay, and belayed at a port timberhead. 2. Tack: The tack is tied to the cringle. This is the one fixed corner of the sail. 3. Clew cringle: The sheets are attached to the clew cringle, which in turn split into pairs of whips. The sheets go to each side, ending in a block. The standing end of the whips are attached to an eyebolt, run through the block on the sheets, and the running end is belayed to a timberhead (I haven't done this step yet). That's it for the staysail. Next the jib. -
Here are the posts from my Badger log on how I added a furled fore topmast staysail and a furled jib. Before I get too far, let me mention the resources that were of immense help in figuring out what to do: 1. Lennarth Petersson - Rigging Period Ship Models - pictures say a thousand words, and this book really simplifies the mysteries of rigging. Helpful to see the pictures of how the rigging for these sails works, but I would say that it shows rigging for larger ships so, for example, the haliards would be more simple than the block and tackle arrangements shown in this book. Still, very highly recommended. 2. The Fully Framed Model (TFFM) Vol. 4 - This Swan series book is an incredible resource for anyone that wants great detail into rigging period ships. Antscherl compiles a lot of research into this book, with excellent pictures, to help one go step by step. 3. Lees - The Masting and Rigging of English Ships of War - Good detailed historical account and narrative description of these sails and their rigging. 4. Harland - Seamanship in the Age of Sail - Excellent descriptions of the actual mechanics of bending, raising, furling, etc. sails. Very helpful discussion of what went into furling sails, particularly how the sails were gathered and then a "skin" was draped over the entire bundle. The remaining 2/3rds of the book goes into fantastic details on how the sails operated in various conditions, etc. Here are the pictures of where I am now, and I'll set up the next couple of posts to talk about the construction of both sails. Needless to say, for what ultimately looks like rolled up wet tissues, these things took a while to figure out how to construct and to install. But, I very much like the end result, which to me anyway looks better than a ship bare of sails. The staysail needs a bit more positioning, which I will do once the sheet whips are installed. -
Sorry to have not posted pics in a while. I've been busy in the shipyard though, and have made some good progress. The bow and fore masts are just about completely rigged - just need to belay the lines from the staysail and jib sail, and add the braces. I'm taking an alternative path to what the instructions would have you do. Instead of going spar to spar, then line to line (like all buntlines followed by all lifts), I've been pre-rigging all the lines to the spars (aside from the braces) then attaching them. It gets to be a mess of lines, so you have to be a bit careful, but it seems to me to be easier to belay them and align the spars in the right orientation if all the lines are pre-added. It also helps because the furled sails are attached to the yards, which make running the lines a bit trickier. Another deviation I had from the plans was to not install the backstays before the running rigging. I can see the merit of installing them before the running rigging to help keep the masts from moving forward as more rigging is installed, but I think it would be pretty difficult to belay the lines with the backstays in place - it seems to me to make more sense to work from inside the ship to outside so that you can get at the inner belaying points. So, I'm going to leave them for the end, or maybe just before I add the braces. My thinking on the braces is that they can be used for final adjustments to the spars to get them in the proper orientation (I think my fore topsail yard needs a bit of tweaking, while the other two are in pretty good shape). I also installed the driver gaff now, rather than at the end. I figured that it would be easier to add the furled driver sail now, before the main mast yards are in place. I'm going to wait on the driver boom for now, as I am adding an ensign and want to belay the ensign halliards before the boom is in place so that I have a little more room to maneuver. I'll post my method for adding the furled driver in my next post. Here are some pictures of where I am at the moment. The finish line is near Thanks for reading!
- 153 replies
- badger
- caldercraft
Happy New Year to all my friends here on MSW! Hope it is a happy, healthy and prosperous 2014 for you all!
- 153 replies
- badger
- caldercraft
Hi Mark, happy new year to you and your family. Your Licorne is looking fantastic. I actually thought about using ebony for my next build, but I'm glad that I read about your travails (as well as others) with that wood. Dyed/stained pear will likely be my approach. Sure looks nice on your Licorne though
Hi John, very nice work! She (or is it technically a "he"?) is really coming along very very nicely. Just out of curiosity, did the kit come up with the lettering or did you have to add it yourself? It came out great.
- 2,250 replies
- model shipways
- Charles W Morgan
Absolutely incredible. I can't even come up with words to describe how beautiful your model is.
- 883 replies
- royal caroline
- ship of the line
Hi again Ferit, Sorry, I should have been more clear - I was referring to the fact that the Euromodel kit has almost an identical demon-looking face around one of the sheeves in the side of the hull. But yes, the lines on the Berlin and the Friedrich Wilhelm zu Pferde seem very similar The Euromodel kit is really incredible. The quality of the wood and other pieces are really top notch - especially the cast metal pieces, which are very very well done unlike other kits that I've seen. The plans are fantastic, but there aren't many instructions. It's definitely a kit for people with more experience, so I will start it after I finish my Badger and get another kit or two under my belt. By the way, I am happy to hear that you will be adding sails to your Berlin. I agree with you that these are sailing ships, so to not include sails on the model seems incomplete. I've been very happy with the look of the furled sails on my Badger (will post photos on my log soon).
Hi Ferit, I'm a little late responding to this, but I came across a very similar figure (both in form and location) in the Euromodel Friedrich Wilhelm zu Pferde kit that I just picked up (which is a very similar 17th century German frigate). Pretty creepy looking isn't it?
Thanks very much Ferit, I really appreciate the kind thoughts. Are you thinking of adding sails (furled or otherwise) to your Berlin? By the way, your Berlin is really coming along nicely. I've been following your log for a while and really am impressed by your work. I was able to get my hands on the Euromodel Friedrich Wilhelm zu Pferde kit, which is a very similar 17th century German frigate. I'll be referring to your work all the time once I start on the kit
- 153 replies
- badger
- caldercraft
Hi ZyXuz and John. Merry Christmas and Happy New Year/Winter Solstice to you and your families as well, thank you! I had a few hours to add some more of the running rigging. I think I spent 70% of the time making forward progress, and the remaining 30% of the time fixing things I broke - blocks inexplicably separating from their lines, I knocked into the bowspirit and the spiritsail braces and fore topgallant shrouds came undone, etc. But, I did manage to get the fore course and topsail yards up I'm really glad that I decided not to install the backstays per the kit instructions. I don't know how I would have been able to get at the rigging in the interior of the ship, particularly attaching the deck cleats. i'm also glad that I installed the ship boats early on (the kit instructions have that as the last thing to install). It seems to me to be a little better to work from the inside of the ship out, and from front to back. The kit, on the other hand, has you install the yards, then attach all the lifts and buntlines, then the clew lines and sheets, and then the braces. I was going to do all the braces at the end, but the fore topsail and fore topgallant braces are belayed to deck cleats right near the galley, and I think they would be extremely difficult to fit at the end once everything else is up.
- 153 replies
- badger
- caldercraft
Euro Ship Kits - moved by moderator
Landlubber Mike replied to pirozzi's topic in Wood ship model kits
I have the Friedrich Wilhelm zu Pferde kit. The plans and materials are all top notch. Even the cast metal parts, of which there are a ton, are all fantastic. -
Nice work Peter - did you decide to go with sails on this build? Happy holidays to you and your family!
- 431 replies
- pegasus
- victory models
Hi Ian, happy holidays and 2014 to you and your family! I'm looking forward to joining the Unicorn gang next year. I was thinking/hoping that I would finish the Badger by the end of the year, but that's looking quite iffy at this point. Now that I've run a few lines and have a better handle on things, I think I can wrap it up next month. We'll see. In the meantime, I've been giving a lot of thought to the modifications to and colors for the build. I think I'm going to plank the hull in pear, and I've bought samples of a variety of stains, dyes and paints to test out. Should be a lot of fun, particularly working alongside you and Zyxux!
- 153 replies
- badger
- caldercraft
Buntlines and their relation to the shrouds
Thanks very much Frankie. When running the lines last night, I had a feeling that nothing should run outside the shrouds for the reason you say. I'll have to look into fairleads, as these might be a good way to guide the lines in the right direction. -
Hi folks, I'm working on the fore course buntlines for my Badger, and am trying to figure out how they run from the blocks under the tops to the fore shroud pinrail. Do they run inside the shrouds? Outside the shrouds? Can they start outside the shrouds and then cross through the shrouds so that they belay on the pinrail inside the shrouds? For the Badger, it looks like I can get the inner buntlines to run inside the shrouds at all times with no problem. The outer buntlines, however, seem to only be able start outside the shrouds, so I'm wondering if it is proper to run them through the shrouds at the right point. I've been looking at pictures, but can't seem to make out this detail. Thanks so much in advance.
