kirill4
Posts posted by kirill4
  1. some considerations about rigging coloring... in the begining, when I didn't know too much ... I did it  paint, treads, by  mix of acrylic paints and acrylic varnish... I used syntetic treads " gutermann" without furs... but this acrylic coat is not too resistant stays on treads, and need to be restored again and again after intensive manipulations with rigging trough the blocks...
    But later on I 've found more interesting technique to use oil artistic painta and oil for coloring model rigging
    how it looks like You could see on D.Shevelev models/// https://www.shipmodeling.ru/phpbb/viewtopic.php?f=65&t=71120
    posts 284 -286
    https://www.shipmodeling.ru/phpbb/viewtopic.php?f=65&t=71037&start=270
  2. Good day,
    Fully agree with that !
    Need to make some precautions to avoid bend them...!!!
    when I was busy with standing rigging I tried don't apply tension at all, or did it:
    *as minimum as possible just sufficient to keep lines of stays and shrouds strait but no more.
    I used preliminary painted treads by mix of acrylic paints and varnish...
    but later on I knew that much better to paint treads by mix of  artistic paints and artistic oil...
    sometimes it was very usefull to paint treads such as crowsfeet of mizzen lifts for example, after installation -this way it will be much easy to make them strait and aplly paint after final fixation...
    *some stays(mizen and bonaventure masts and some top masts stays) I fitted at place in reverse order for convenience- started to fitt them from lower stay parts and complete installation and final stay tension adjustment on the mast top...
      in my version of galleon stays it was possible due to I didn't use stays mouse but imitation of seized or spliced eyes...
    *all running rigging I try to show slacked wherever possible.
    To have rope making machine - great idea !!!
    treads will looks more realistic and You will have all rope sizes You need on your model !!!
    some type of rope making machine, of very simple construction,could be made at home even from cartons sheet and pieces of thick steel wire without gears...
  3. there are a few pictures of museum 's Vasa rigging reconstruction - You could see positions of the shrouds and stays loops above masts tops ... more or less similar rigging arrangements could be reproduced on the GH model ... just will be less sails and ropes, but basic remains the same!
    7_b rigg rekons.pdf 6_b riggfästen mm.pdf
  4. Dear bosco72,
    Thanks for the link! :) I see there are more interesting books  available , Thanks!
        Regarding your model, my remarks most probably just about  one of your  "...do I have an eye for detail..."  :)
    in this particular case - details of rigging, I could say, basic rigging details :)
    Actually there are a few basic rules for making correct rigging, there is a certain sequence in rigging which need to be followed.
        I think making rigging according  these rules will be not more complicated(I mean time consuming and manipulations with treads) job than You already did now ,with installed shrouds and stays , in this part which You shown us.
        The only difference will be in corectness, from this point of vew , may be there is sense to start making rigging in correct way strait from begining, don't spend time for irregularities,
    irregularities which need to be corrected  later on , on the next model? or they could be learned like first experience and than reproduced on the other models again ? :)))
    I understand we make a lot of simplifications in plastic model rigging, but general rigging appearance on the model should be correct by my opinion...at least it should be interesting to make it correct way not less than... accurate assembling or painting for example...:)?
       I remember , before start rigging  my model ( let's say first and only one my model where I tried to understand galleon rigging,how it could be arranged, how should it work...and reproduce my "understandings " in model rigging :)))) I 've spent a few weeks to read R.C. Anderson book(book which I knew a few days before start galleon project), and later on start making my rigging plan on paper follow information page by page from this book, and third stage it was making model rigging...which is continue till present time :)))
     Sorry for that lirics :)
    Back to your model,
    I think book of R.C. Anderson will be more suitable for galleon rigging than Mondfeld book which is almost about everything in model making and nessesary information need to be trawled, in this respect Anderson talking more specific about 16-17 rigging.
    In my opinion Mondfeld could second source of information in priority...
  5. Good day,
    Dear bosco72,
    Studing your model pictures I saw You did your standing rigging in some  wrong way...
    sorry for that stupid question,may be You did it in purpose or why?
    *it looks like You did all shrouds and stays of the same thickness( sizes),normaly they must be different in sizes!
    *wrong way of location shrouds loops and stays...normaly it should be  secured above tops plarform,on the mast tops, but You placed them  under top platforms...
       If there is intention to make rigging in more right /correct way, I would like to recommend You to read this easy for reading  books( Anderson and Mondfeld), in this books You could found condenced information practically regarding each important rope of rigging of 16- 17 centure vessel.
       A  few readen pages will serve you very good when You will be busy with  rigging your model.
     There You could find information about purpose and sizes of each important ropes and rigs of the old fasion vessel as well as tables( in Mondfeld book) with rope sizes in proportions to rigs/or main mast dimension/ diam.
      Below I gave some simplified picture with precalculated rigging rope sizes, calculation based on information from this books.
     There is exell table for automatic calculation ropes sizes of standing rigging as well
    Main stay size( diam) calculated in proportion to main mast diam.
    0.166 of main mast , all other ropes sizes calculation based on main stay diam.
    Wish You all the Best!
    Kirill
    on the pictures dimensions given in mm
    roughly says , they could be used for the your model scale, strait from pictures
    standing rigging thickness.xls
  6. 14 hours ago, Landlubber Mike said:
    Great job!  I hereby nominate your log as the most epic on MSW :)
    Good day Marc,
    Totaly Agree with Mike🙂!!!
    This is fantastic project, such deep research of the subject and than brilliant reproduction findings on the model!!!
    I deeply admired for your work and this approach to business !
    All the best!!!
    Kirill
  7. Dear Bill97,
    I'm sorry for delay with answer , for some period I didn't have access to the net... this kit is not rare, I saw a few firms did repack of this kit -AOSHIMA- IMAI series Large Sailing Ship No8;No12,
    LEE 0886, scale 1/100
    even russian Modelist repack it - Моделист 110016 1:100 Spanish Galleon (Испанский Галеон),
    in case of difficulties to find it ,than most easiest way to find rare models - wisit Radek site https://www.hismodel.com/articles-category-5 ... sometimes it looks like he has everything I could wish to find( regarding plastic models of sailing vessels) !!! :)))
  8. Good day  Ron,
    Your Victory look nice, and bowsprit quite strait///atleast I don't see it is bended, some blinde spars on the bowsprit a little bit curved yes...
    Make Victory rigged- it is high pilotage I could say!!! :)))
    My respect!!!
    I didn't give my galleon build log thread - actually ,it is in my signature,You can follow it strait from here :)))
    All the Best!!!
  9. Ron,
    If You didn't see that, I guess this thread of eugen.t  alternative reconstruction GH  will be very interesting for You (there need to be registered and You can change language frm German to English to read threads/there is button google auto translator in the lower left corner of the main page)...
    especialy in the part of rigging-see final drwngs\as source of information abt galleon rigging
    https://www.segelschiffsmodellbau.com/t6619f952-Alternative-Rekonstruktion-der-GOLDEN-HIND-11.html
  10. Good Day Ron!
    #Recently I've checked content of the box with this kit, and I saw that masts and spars made from very soft plastic...
    worry there could be a problem with rigging, when we will reach this stage/they easily could be bended even without apply any forces during installation standing and specialy running rigging , such a braces,lifts etc...
    may be there is a sense to replace them for wood?
    I based my observation on experience of building my previous model of spanish galleon///in that kit plastic was twice harder than in this GH kit, but even than I had to replace bowsprit( as much loaded parts of rigs) for wood( made it from artist brush)...all other rigs were left original plastic...
     But in this kit I've strong feeling that atleast bowsprit( consider in that period there was no bobstays in use), and upper rigs all, exept fore and main masts probably(mean lower parts of masts), need to be replaced for wood🤔🙄
    #regarding opening my GH build log...ah, need first to complete my previous project of spanish galleon and than start new one :)))
    Wish You All The Best!
    Kirill
  11. Good day Ron!
    Nice and acurate job You did!
    I have this kit also and plan to build it someday in future( I want to make some small corrections of this kit - to add 4th mast and realign pozition of cannons ports, will try to make it more looks like famous Elizabeth Jonas model), and now it is very interesting for me to watch your building and see this kit "in action" :)))
    Wish You All the Best!
    Kirill
  12. Hello Marc,
    Thanks , :)))
    To preserve potal luster, it need to be varnished or lacquered... there are many special liquids for that effect on the market(decoration hobbies)
    ... after almost 5 months, I found that it became a little bit redish in color, but remained same luster ...so better to protect it
    presently I covered all with glossy acryl lacquer.
    For making medalion...
    as "donor" ,for this tafferal medallion served ordinary chip /less than dollar  price /plastic medalion ... I found it somewhere years ago by ocasion in some small shop on the street , that time I liked medalion picture quality as all smallest details were nice visiable , I bouth it just for case - and now this case happened :)))
     for making negative mould I 've used two components epoxy , like a solid paste, they call it "cold welding"here in Russia, actually it was not designed for this use, but for making small repair of leaking pipes for example , etc...
    I used it because it just was under hand, lets say :)))  and didn't want to spend time for waiting special components delivery from internet shop...
    but quality of the casting , as You could see < not very good... small details missed during "casting" process
    but for better result I think spesial staff need to be used -  rubberized mould medium +resin casting- something , as Dafi used when  reproducing nessesery copies in his VICTORY project
    In my case , for making copy of this medalion,
    first, I made negative sculpt in this two components "clay" and than ,using same staff again,
    I made positive sculpt - to separate positive and negative substanceses, I used silicon grease.
  13. Good day Dear Community!
    I’m continuing experiments with using" potal"( fake gold) instead of gold paint (maybe this idea will be useful for someone to use "potal " for gilding decor on the model.,and ...and not only decor ...
    It could be used for guilding model's stands ... some other parts on the model which surfaces need to be looks like " metal"
    On the first foto you could see difference between gold acrylic paint and "potal leafs"
    Presently I’ll try to replace paintings of all decorative elements. which were painted by gold paint in the past (the first photo shows the difference between the gold paint and potal leafs)
    ...and repaint them with "potal"...
    As You could see, I changed a little color of my sails...made them more dark - on the foto you could see difference in color between mizzen and bonaventure sails and main and fore sails as well
    Also I repaint anchor's wooden parts partuatly and rearange imitation fasteners which joining two wooden halves- bolts imitation made from acrulic contur paint
    and I prefabricated " plates " for main tacks and made "boarding" anchor, which later on will be fastened to the bowsprit ...
    and yes, I decided to replace Stern Shields,and made it in relief but not flat picture (foto print) as before...
    as example boarding anchor /approx  size compare to human body you could see on these pictures ..
  14. Good day,
    Lanyards looks nice!
    "Mara " serie, I didn't try...but on your foto it looks good,means it must be suitable material for ropes making, as well as gutermann " scala" and " tera"...
    regarding trying to find suitable color No ... I don't know... I prefer to use white or very light color and than to use paint for making desired rigging color...as seems to me, if not paint...than some kind of stain need to be used and matt varnish...
    but this of cause very personal feelings about right model appearance  :)))
    Regarding rope coil making... I used almost same techniques as Gregory, and deluted white clue as well to keep desired coil form...for making process faster, I use hair dryer.
    The only difference - I make rope coil in two parts,and than assemble them in one piece...You could see it on the last few pages in my thread abt galleon building- link in my sinature...
    When placing prefabricated coils , I use small q-ty of CA gell, to make some additional" gravity" effect to the rope in coil...
  15. On 9/4/2019 at 10:32 AM, Peta_V said:
    This is my biggest trouble with supplied ropes. Each diameter has different colour. The 0,2 and 0.3 have greenish tone. I would be happy with 0,4 but 0,5 is too White to my taste. I do not want the ship looks like X-mas tree after all the hours I have spent on it.
    As I said I still have to find some good material to work with!
    Good day,
    Dear Peta_V,
    Ah,...now I see,that ropes which You used , it was supplied together with kit...?
    in such case, looks like/could I guess/ there are sizes of the ropes correct only...according to the model rigging plan,
    but I think( looking at the foto with supplied ropes) they coudn' t be used on the model straight from the box (on the foto,  lay of the ropes looks too loose, and  color too shining)I think , this supplied ropes need to be "processed" a little before use.
    probably need to be rewinding,to get more tight lay...as example refer to the Gregory 's foto with ropes,which are looks right in appearance and color...may be it will be easy to make new ropes ,correct in size and lay from the begining? :)than try to correct supplied ropes? :)
    recently I ve found good staff , I think it is very convinient to use it ::)for making ropes any size we need for the small scale model - this is Gutermann products...I bouth a few realy "big" coils of different size...it is serie "scala" threads N #  200;240;360,
    which is kind of "mono" thread and could be winding in any direction when making your own ropes...I found them in this shop - https://legus39.ru/products.php?category_id=44
    than combining already made ropes from this threds  and use different thread No ...we can make ropes of different sizes we need...
    there are also treads serie "tera"...which is also good for making ropes,but they less interesting because they are already made as ordinary thread, and not so easy for making small ropes...
    color... :)
    personaly I prefer to use white...or bright thread colors and later ,when rope made, to stain or paint them in color I need...actualy we need only two color for rope painting...
    I use acrylic paint, made mix of bright and dark colors for painting running and stay rigging...but better result could be obtained using artist oil paints deluted in thinner - reffer as example to the works of this high rank modeller Dmitry Shevelev...
    https://www.shipmodeling.ru/phpbb/viewtopic.php?f=65&t=28865&start=330
    how looks his artystic paints painted ropes
    there is translated text from D.Sh. advices regarding ropes painting techniques
    ...Re: How is this done? Dmitry Shevelev »Mon Jan 16, 2017 13:24 Good afternoon, Oleg! I paint white threads with art oil paints. I’m breeding a half-liter jar. I mix a tube of paint with liquid oil. On a standing rigging is the Leningradskaya Umbra. On running to this paint I add ocher. I paint by pulling the thread through a jar or a poured puddle of paint. Then I pull the thread through the glove several times and hang it up to dry. You can use it in a day....
    All the best
    Kirill
  16. Good day ,
    Peta,
    Very good, accurate, precise  and " sharp" work You did!
    Watch it with pleasure...but the "ropes" , you used ... :(...they somehow drops out from the entire style of the model...
    Agree with Dubz, could it be replaced for (?self made ropes as option?), with more realistic looks?
    there are a few very simple rope making mashines on the market I saw, but the ropes which You made by yourself will looks much, much better, than just ordinary ,unprocessed threads You used now...
  17. yes...need to experiment... need smthng like 10-20 ml volume of such solution- mix powder - water-spirit-very small drop of dishwash detergent(?fairy?or similar brand...i think doesn,t matter which one...some chip brand...)
    how much need to make powder:) ... not too much...gram/less... it works good , dark powder(black-red-brown mix) on bright surface ...or viseversa greish colors on black ... ...but of couse, concentration better determine by experiments...
