Posts posted by mugje
7 hours ago, allanyed said:
Based on contemporary models this is what appears to have been the common method. I have only seen one that may have a stop on the bottom of the upper sill that forms the top of the gun ports, in this case on the lower gun deck. This may be original or may have been a modern repair, not sure. Regardless they were only about 1 1/2" thick (0.6mm at 1:64) for a vessel the size of Sphinx (20) 1775
Allan
Thanks Allen for clarification...yeah there were a few examples in the topic that I posted, on contempary models but also for example the HMS Victory. But I do think i'm going now for only the bottom and sides of the gunports. It does look good and it's also a bit less work.
I need to see if I have some 0.6 material laying around, otherwise I settle at 0.5 pear that I have in stock. That tenth of a mm...I can handle that difference
30 minutes ago, Cjames said:
Hi Mugje. Re your question about gunport linings, I installed them on the bottom and sides of all the open ports. I used material a little less than 1/32 in and cut each individual lining from a pre-painted strip about 5/16 in wide. See below.
I would complete the finish planking around the ports before installing the linings. You may have to sand the inner surfaces of the ports somewhat to match the exterior planking, and if you install the linings before doing that you'll have problems. I installed the linings the same way Blue Ensign did; bottoms first, then the sides. As he notes, the bottoms are easy, the sides not so much. Each side piece is angled top and bottom, and there are slight varIations in the angles for each piece. Do the best you can and plan on filling some gaps. Also one note. On my build the guns sit fairly low in the ports and with the linings installed the cannon barrels barely clear the bottom port sills. I would mock up one of the guns and test it with the material you plan to use for the linings before proceeding.
Best regards.
Cjames
Thanks Cjames! That's a helpful post . At first I wanted to do all 4 sides of the gunport, but looking at your close-up...3 sides do look good also, so maybe going for that too. 1/32 is about 0.8mm so you used the same material as the outer planking? My thoughts were to use 0.5mm thick linings (not sure how much inch that is ). Will experiment a bit with different sizes, and what looks best.
New update about what I've done this week:
Installed the prow, keel and rudder post, including their outer patterns/facings so to speak.
This gives the ship a whole new appearance.
After that I glued the outer lower counter pattern in his perticular spot. This all went without trouble. Now I could measure the space between this pattern and the rudder post, so I could fill the difference with a thin piece of pear wood that I abstracted from the same sheet where also the outer patterns came out of. So there is no color difference
Because of the thickness difference (the outer patterns of the rudder post and keel are 1mm thick and the supplied outer pear planks are 0.8mm thick) I maybe need a bit of filler underneath the second layer of pear planks against the rudder post and keel. Just to get them at a even height in the end. Will think about how to approach this.
Last step that I've done was soak the fore outer planking patterns and clamped them onto the hull. They have dried overnight and will glue them soon onto the hull.
A bit exciting these larger thin pieces of wood, so I need to gather some courage to get them in a good way onto the hull
I also thought about the gunport stops and if i'm going to do them on all the gunports and not only at the ones with actual lids. I saw this idea in Blue Ensigns log and like the look when all the gunports have the stops, including those without a lid. So i'm going for those...it looks fairly easy to execute this small modification. The two questions after that were...glueing first the patterns onto the ship and install after that the stops? Or do them first and glue the patterns after that. I go with the first option because the outer patterns have a bit of extra "meat" onto the gunports...they are a bit smaller then the mdf inside frame so you have some wiggle room and you can sand them afterwards flush with the mdf framing. So it looks to me easier to install them afterwards.
Next question was...at all four sides a stop or only at the sides and the bottom? I found this topic:
And saw that both options look correct. It didn't seem if there was 1 correct answer, so then I choose for asthetics and will do all 4 sides because I find that look more appealing.
- JeffT, Thukydides, chris watton and 13 others
- 16
Very nice clean work! Love it!
- Knocklouder and jereremy
- 2
You can see it's one of your specialties...very nice painting job and thanks for explaining
- Glen McGuire and Thukydides
- 1
- 1
49 minutes ago, MCo said:
Thanks a lot (reuze bedankt)! The lines are beautiful. But one wonders what the lower deck space would have been like, for a 130 men crew.
Yeah those numbers of crew members are always mind boggling with these old ships. So weird how everyone fitted in and on these vessels. Life was hard back then. 😮
Do I see it right that you also (not sure how to call it, but the small red edge on the inside of a gunport) lined off the gunports, like Blue Ensign also did in his version of the Sphinx?
- Knocklouder and mtaylor
- 2
Really nice, you are doing a great job! Also beautiful lines in this ship
Just sharing my solution how i've dealed with that little gap between the first layer of planking and counter planking. I used some filler to fill up the gap, also to give everything some strength because it's connected to each other. And at the counter planking I glued a extra 1 mm thick piece of pear so it covers the gap nicely. Now with testing a scrap piece of pear of 0.8mm (the second layer planking thickness) there no height difference anymore and it looks nice level to each other. Also if i'm not mistaking later in the construction the bottom part of the counter piece will be covered with a decorative strip of wood.
- Vlax, mtaylor, Blue Ensign and 9 others
- 12
It´s a cool unusual design, I like it! It somehow reminds me of a little tank but then on water
- Canute, thibaultron, chris watton and 3 others
- 6
1 hour ago, glbarlow said:
The overlap of the second planking should cover that. The counter is planked first then trim the hull side planking flush with the planked counter. The gaps should easily be covered, the first planking is a foundation, doesn’t always need to be a perfect match to the final look generated by. 2nd planking. The parts are generally oversized on purpose as every hull is different. You can also sand the counter piece to fit a little better.
Do make sure the second planking is equal, by trial fitting, to the rudder at the stern post, generally this is more problematic than the counter. I wish my Pegasus log wasn’t lost in the great 2013 crash.
Thanks Glenn, that's helpful 👍
I've learned with building the Sphinx that diluted PVA gives you also more time jiggle around before it sets. Nice progress so far! Master Korabel and Vanguard Models are both quite innovative with their designs.
- Dave_E, Glen McGuire, ccoyle and 4 others
- 7
Okay...it's time for me now to place the lower stern counter into the right place, but I have a question...let's see if I can explain it.
Blue Ensign did a great job explaining how he tackled it, with temporary pinning the rest of the stern pieces. So you can see if everything lines up.
Sounded like a great plan, so I did this too. Need here and there a few little corrections, but in general this looked good and on the correct height (if it's not please let me know )
I asume the first layer of planking needs to be on the same height (thickness) of the lower stern counter. One flows in the same height into the other, without elevation?
Well that is what I think it should be but if it's not by design, please let me know.
Because as you see in the lower pictures, you see that my first layer of planking is a bit lower than the stern counter. In the outer corners not so, but closer to the stem it is lower. I can put some filler to get it more level with each other.
HM Cutter Trial 1790 by Dunnock - FINISHED - Vanguard Models - 1:64
Those ropes look great! It looks very realistic, how they just laying there...nice job
