Everything posted by mugje
Congratulations with finishing this stunning ship! Quite a epic journey and wonderful result
- 364 replies
- bellerophon
- victory models
Lovely second layer of planking you did there
- 147 replies
- Flirt
- Vanguard Models
Well a disc sander with adjustable table (like the proxxon one) made my modellers life a lot more enjoyable. It makes it so much more easy. And a Dremel ofcourse...those two are my essentials...for now
Last update this year I suppose The hull is now sanded smooth and the little cracks/deeper lying planks etc. are filled. Ready for the next step I guess. I will test fit the prow/keel and sternpost patterns to see if it fits right, and maybe there are spots that need a little extra sanding (places around the tabs that are connected to the prow and keel). Also need to test fit the lower counter ofcourse. I think I also need to check if the upper hull side patterns are flush with the gunports inside. I haven't done that yet, but also didn't see it mentioned in the manual. Would be a good moment for that.
And be aware....when you are at the part of glueing it in place....don't put glue on the deck, but only at the false deck below. Because the PVA will moisture the wood causing it to swell a bit. This resulted in that the deck didn't fit anymore because I couldn't get it fast enough onto the false deck, and as a consequence...the deck became fixated in this swelled up size due to the glue that dryed. So I messed this up a bit Totally my own fault due to the inexperience working with thin sheets of wood. So maybe I can warn others to not make these mistakes
American Revenue Cutter – Seahorse – 1:72 – Card Kit
mugje replied to Jsk's topic in REVIEWS: Model kits
Looks like a fun project! Will be interesting to see how you tackle it. And nice review/story -
Yes Sphinx is a good alternative, but not sure how experienced you are. I'm building it now and it's a real joy. Your criteria of decent instructions and materials are met with this kit. I can't judge how difficult it is because i'm not that far into the build yet, and i'm considering myself a experienced beginner. But knowing the designer and prototype builder are here on the forum, that gave me enough confidence for trying to tackle this kit
Finally closed! Took a bit longer then expected because I was quite sick last week with a flu and fever, but feeling good now so I could do the last planks. I used some 1mm pear that I had lying around, because I had run out of the lime wood. Not because Chris didn't supply enough, but because I redid such large areas. This gave me the change to get a bit familiar with pear wood and how it behaves, so maybe that gives me a bit of an advantage for the final layer. I couldn't get the first layer exactly as I wanted, without mistakes and knowing exactly what I did, but I have learned a lot! So hoping that I learned enough to get a decent second layer that I could be happy about and leave it unpainted. Otherwise there is always the option to paint it white if it's not too great Now first some sanding and filling here and there to get a nice smooth base for the second layer.
Congratulations! That´s a real beauty!
- 137 replies
- winchelsea
- Syren Ship Model Company
Welkom! And nice model you have there
She turned out very nice! Lovely result
- 103 replies
- Grecian
- baltimore clipper
(and 4 more)
Oh wow...never thought about that either
- 147 replies
- Flirt
- Vanguard Models
Planking looks great! Don't think too much forward about how long it will take, just one plank at a time...
- 147 replies
- Flirt
- Vanguard Models
Bristol 1775 - from Warship to Prison Hulk
mugje replied to westwood's topic in Nautical/Naval History
Even without VR it was interesting ...I did read that Chris wanted to design this one, if he does...that would be an epic kit 😮 -
Little update...i'm just 6 planks and a garboard strake away of finishing the first layer of planking. Going not so very fast, but enjoying the process. Halfway planking the hull I realized I wasn't happy with the shape of the bow and stern. I sanded them a bit to conservative and this resulted in not a real nice flow in the planking. So made the decision to brake away the planking at the places where I thought it didn't look right. So this was a bit of extra planking fun , I learned some extra bending techniques along the way, so it was helpful also. I also realized that with lining off the hull using tape that I didn't took enough time to really check the run of the tape (because the tape didn't stick well). This resulted in a bit of a waviness pattern across the hull. Therefore I did the process of lining off again, but this time with wooden battens. For me this works better because of the stiffness of the planks...you won't have to check every bulkhead if the plank waves up or down the hull. So that was also a valuable lesson for me. So first broke the planks away for reworking the bow and stern: After that I used wooden battens for lining off the hull: And now almost closed! 🎊
Question to whoever has bought CAF HMS Enterprize 1/48 kit
mugje replied to Ulises Victoria's topic in Wood ship model kits
https://modelshipworld.com/profile/33401-cafmodel/
