Everything posted by Ronald-V
Ronald-V replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Looks handy! Before and after pic? -
Welcome! And good choice for a first build! You can't go wrong with a Vanguard kit
Looks amazing! Really nice work Chris!👌
- 38 replies
- 18th Century Longboat
- Model Shipways
I also used that Amati "form a plank" bender a lot with my build, I find it very easy and useful 👍 Lovely build so far!
- 11 replies
- Black Falcon
- Mantua
L'Ambitieux by Nek0 - Altaya
Ronald-V replied to Nek0's topic in - Kit build logs for subjects built from 1501 - 1750
Indeed! It's spectacular! Also love your color pallette, nice soft tones 👍 -
Update: All the channels are mounted, including their knees. It wasn't a difficult job, only the knees were a bit fiddly when it came to removing the laser char. They're small and difficult to hold, etc. But I'm happy with the end result. The color of the channels turned out a bit darker than I'd like, but that's just how it is when you're dealing with different sheets of pearwood...they're not all the same. But it's not really a problem. I initially thought the channels should be flush against the decorative moldings, but I discovered in other build logs that several people didn't have this. So I abandoned that idea. By the way...the manual advised to paint them black, which looks indeed nice with a painted hull. But I have chosen to leave them natural, I think it looks nicer with a unpainted hull. Here's a brief description of what I did. First, I used a needle to center the channel, which will soon be drilled with a hole for a reinforcement rod to give the channels some extra strength for attaching to the hull. Drilled a 0.7 hole (with a dremel in a vertical drill stand) so that it is straight. Small cut nail with CA glued in it Some channels still needed a bit of sanding to fit (which is understandable, as every hull is slightly different, of course). You could clearly see if they fit properly from below. Then, I pre-coated the bottom of the channels that are against the painted hull with WOP (so the varnish doesn't touch the painted hull). I didn't put the entire channel in the WOP because so many parts still needed to be glued. I thought that would be better on bare wood. I made a mistake here... somehow I didn't thin the varnish or even stir it (my mind was elsewhere). This resulted in a very thick layer, which is still visible in the final result. I could have sanded it down and re-varnished it, of course, but since it's on the underside and I almost never look at a ship that way... I just left it as is. The respective knees used as guides to glue the channels at the correct angle (parallel to the waterline). End result after putting 2 layers of WOP on the channels Here you can still spot the error between the diluted and undiluted lacquer I'm really looking forward to the next step...all the prow/bow stuff. HMS Pickle didn't have any of this; it was a very simple bow, so this will be really fun to do for the first time (I think ).
Welcome! Good nickname and nice little project in a bottle! 👌
That's a very nice planking job! Well done! 👏
- 38 replies
- Model Shipways
Worst Planking Job Ever
Ronald-V replied to rhephner's topic in Building, Framing, Planking and plating a ships hull and deck
Great improvement! Well done!
