Everything posted by Ronald-V
Fine looking stealers 👌 Personally I never really cared about color difference, because it gives a bit more life in my opinion. But some people like to make it as flat and perfect as possible, it's a matter of taste. I like to see individual planks, as long as it's not too much of a contrast, but that doesn't seem to be the case with you. Plus you have to take into account that e.g. staining as you did the top, connects the planks with each other in terms of color
Congratulations! That's a nice looking ship , you can be proud of her!
- 129 replies
- vanguard models
- Sherbourne
Congratulations! Beautiful result, I also really like the color combination of the upper hull pear and lower hull copper.
- 73 replies
- Harpy
- Vanguard Models
Indeed what Andrew said...I find every log helpful of the particular ship that i'm building...because everyone approaches problems slightly different and it's nice to look for different solutions in other people's logs.
- 36 replies
- Duchess of Kingston
- Vanguard Models
New update: Finishing the lower part of the quarter gallery. First of all some support for the lower part. Again made from boxwood and of course the dimensions taken from the original kit parts Then I copied the "berthing patterns" but with larger dimensions so that I have room to make a seamless connection with the top and bottom of the quarter gallery. Maybe it would work with the original part, but personally I find this easier. And with a table saw and sanding disc it is almost no extra work A bit of bending with the original MDF parts glued to a piece of scrap wood. It's not all super precise but that's not a problem. I noticed that with a plank nipper from Amati I did get the final curves that were needed Fits nicely! Here and there I cheated a bit with some glue and sanding dust. I try to make it very precise, but it doesn't always work out as intended. Beyond my skills haha. Then it was time for the "lower finishing parts". Again a piece extended at the front with a piece of boxwood, so that I could get a reasonably close connection with the "stern upper counter pattern". I placed these parts loosely on the wales and glued them there on each other (so not on the wales, but on each other). This is because the wales have a vertical curve and you also need this in the "quarter gallery finishing patterns". Especially the "drop shape" must be sanded at a slight angle on the top so that it lies flat against the wales and pieces 29 and 45b. Most of this rough shape sanded away with the sanding disc and the last with some sandpaper. Of course left something so that when glued to the hull it can get its final shape Just glued here but not yet in its final shape The final shape was obtained with a mix of small files and sandpaper. As you can see the wales are a little bit damaged in terms of paint, but that can easily be touched up. I used a little bit of filler on the front of the finishing pattern, where it flows into the "berthing patterns". This is because the berthing patterns are lower because they are lying against the wales and the finishing patterns are ON the wales. So I had a bit of a strange transition there..solved with some filler. By the way, I think this should be approximately the shape that the whole thing should have. I didn't find it the clearest and it seems that there are some differences between many builders. The most important thing I think is that it should look aesthetically pleasing, so a nice flow with the rest of the quarter gallery. I chose to place the drop shape at the bottom a little forward (towards the bow), a small millimeter from the upper counter. This is because the PE decoration that comes on top had exactly the shape of this drop. So it was important to keep the shape (this also answers the question I asked myself in post #280) Hadn't shown a photo of the stern yet. Here too all the seams have been worked away with filler, so everything looks nice and tight. By the way, I thought the view over the deck through the windows was nice in this photo. (quality of the photo is a bit bad because I had to sharpen it quite a bit) Oh yes...a nice glimpse into the "seat of ease"
Very nice finished boat! Well done, love the colors also
- 47 replies
- Annapolis Wherry
- Chesapeake Light Craft
Congratulations! Very well done! Must feel nice to complete this one
- 114 replies
- Vanguard Models
- Speedy
Very cool those decorations in combination with the windows! And the figurehead looks also very good! Well done!
- 111 replies
- Christiania
- Vanguard Models
I found it really helpful with my Sphinx build to approach the first planking like it was the second. Yes it takes more time, but I made some valuable mistakes that helped me to get a better second layer. And I really began to understand how everything works regarding planking. But I haven't had a ton of experience at forehand so maybe you yourself don't need it
Update: Okay...The last few days I've been busy with the quarter gallery on the port side. Now halfway...and here's a small photo report Started by filling in the slots where the parts that would normally be used without the openwork galleries would go. First check carefully where exactly they should start and end so that you know later where the replacement parts should go. Copied the pieces (used boxwood for this) Then started with the construction of the "seat of ease". First a base plate on the back so that there is a flat surface The "seat of ease" made from various pieces of boxwood. I found the sanding disc easy to use here to get the right angles. Just work your way up to it slowly instead of sanding away large chunks. Painted it a nice coat "off white", like the rest of my interior Rooftop piece: Then the first underlying window piece. Used many different clamps here to get it right. Tip: practice clamping without glue beforehand...so you know when you're working with the glue where everything should go...less stressful I extended the window piece that goes over the base layer because I want to use as little filler as possible afterwards. This way I can slowly work towards the perfect shape. To be honest, I have to say that it didn't work out as well on the port side as on the starboard side. I was still a bit too impatient or something and had a small seam here and there . I worked these away with some glue and sanding dust. Eventually there will be a layer of paint over it anyway so it doesn't matter. But I think these are fun challenges (which don't always turn out well haha ) Finally the roof placed...not much to tell about that other than slowly working towards the final shape. For the most part used the sanding disc again. That's it for now. Will continue with the bottom part and post an update later. Haven't placed the floor of the quartergallery yet. I personally think it's easier if I place it together with part 29 (it will become clearer ;) )
What a beautiful work James! Lovely kit so far! 👍
- 48 replies
