davyboy
Posts posted by davyboy
Hi Maurice,why don't you not just sieze the breeching ropes to the eyebolts before fitting them into the bulwark ? Much easier to do it that way you should have enough slack to slide the rope through the cascabel ring from side to side to do this. Certainly more space to do your siezings there than up against the bulwarks. Just a thought but that's how I'd do it.
Dave
- Richard44, Mr Whippy, Blue Ensign and 1 other
4
21 hours ago, hdrinker said:
Significant error discovered. I should have added a fifth deadeye to the mizzen channels to accommodate the mizzen topmast backstays. But didn’t recognize that the 3-D computer images omit a mizzen top gallant. Instead, I used the deadeye aft of the quarter badge for the topmast backstays, leaving no deadeyes for the top gallant back stays in my version of Pegasus. We’ll, it seems that my choices now would be to 1): redo the entire mizzen and its channels , or 2): redo the stool aft of the quarter badge to accommodate an additional deadeye. I’m leaning for the latter, but would be welcome to hear from the group.
Hi Henry,your Dilemma is easily solved. You can fit an item called a deadeye plate,one of these can be seen in Blue Ensign's HMS Pegasus build log part 9, 6th pic down. Dead easy to make,just an eybolt through small circular piece of wood (Slice off a bit of dowel). The bottom deadeye just hooks into it. I had exactly the same problem rigging my Speedwell build. The Mizzen backstay and Main T'gallant backstay and attaching fittings are totally missing on the rigging plan although they can be seen on the NMM model. It was BE who put me in the picture.
Hope this is of help,
Dave
8 hours ago, Kenchington said:
Three different things. Dr.PR's arrows point to baggywrinkle. "Service" is twine (usually tarred marline) wound very tightly around a larger rope. Chafing mats come in multiple forms but they are rope mats.
Ashley's shows them all.
Trevor
Thank you Trevor,one always learns something new. At the end of the day however they all serve the same purpose.
Dave
I've never used bits of paper as templates. There is usually a standard distance between Ratlines of 12" to 15" ",I use 12". A piece of wood 1/4" wide (I build in 1:48th) clipped across the shrouds below where the first ratline is to be rigged. Rig the ratline then clip your piece of wood directly above it and rig the next and so on. The beauty of doing it this way is you can ensure good alignment of all your ratlines with out struggling to align them with lines on a sometimes wobbly piece of paper. It works very well for me,try it.
I'm sure I read this tip here on the forum years ago.
Dave
Hello Wefalk,
That practice is called pollarding and is still carried out to a limited degree in England for various reasons. Plenty of information on google and other search engines.
Dave
Looks very nice indeed Maurice,certainly a great improvement.
Dave
- hollowneck and Blue Ensign
2
Hi drftrman,
Cruizer was my first ship model a long time ago. Don't worry about the bulkhead tops,at a later stage of the build when the hull is planked they're cut off. Just lightly tack glue the gunport patterns to them for that reason after fairing. I found that out the hard way. Have fun with your build,plenty advice on the forum,you just have to ask.
Dave
Hi Maurice,
She's looking good. These fashion pieces look much better than that shown on the prototype build. The Speedwell has exactly the same arrangement on the lower counter,I suspect that would be fairly common construction practice back in the day on small ships still using the older style square tuck . I'm currently chipping away at the boxwood carved figures of the two ladies ornamenting Speedwell's tafferel,then there are other smaller pieces to be done. Heigh Ho,get there eventually I guess.
Dave
- hollowneck, Ryland Craze and ECK
3
39 minutes ago, tom q vaxy said:
anyone have success cutting thick (.060" & .080") styrene strips with any of the suggested saws (except the basically unobtainium Byrnes saw)
thanks
Have you tried sticking it to a backing piece of thin (1/8" or so plywood) I can't speak for styrene but I successfully cut 0,015" copper and brass sheet doing that on my Proxxon KS 230 saw using their thin fine toothed # 28020 50mm blade. Just take it slowly so you don't melt the styrene plastic.
Dave
While my interests lie in the 18th Century it is an absolute joy to see your wonderful metalwork Valeriy.
Dave
- mtaylor, FriedClams, Keith Black and 2 others
5
Hi Maurice,I see you've started already,lots of fun ahead for you.
Dave
Hi JimO,
There is a very good build log of her at 1:45th scale on the forum by a Belgian member who posts under the name Baker. May be of some help to you. Also welcome aboard MSW.
Dave
- Old Collingwood and mtaylor
2
On 11/29/2024 at 12:47 PM, wefalck said:
How did you make the slot for the sawblade, as on the KS230 one cannot raise or lower the blade?
Simply done. I just run a length of aluminium tape on both sides of the blade when I use their 0,5 mm blade. When I use their wider blades I simply remove the tape.
Dave
On 11/22/2024 at 5:34 PM, wefalck said:
I think I'll try some self-adhesive aluminium tape (as used to cover the seams in dry-walling) on my PROXXON KS230.
It works perfectly,I've been doing that for ages on my KS230 when using their 0,5 mm blade. Best to remove the splitter then you can tape right to the back.
Dave
14 hours ago, Snug Harbor Johnny said:
Now the Mary Rose was built way before there was anything like a Sears catalog, but a source indicates that in Roman times there was a sponge on a stick placed in a water bucket at the latrines, and all the men used the same implement to clean themselves. Maybe there was something like that in Henry's time.
That brought back a few memories for me. Back in the 1960's I was in the RAF and stationed in Bahrein our sea angling club used to regularly go on weekend fishing trips on Arab boats. No such luxury as a sponge on a stick there,a packing case hung over the stern with a plank knocked out of the bottom and a bucket on a rope for ones ablutions. No one I knew took bog paper with them
Happy days,at least the sea was warm there.
Hi there Slowhand,
Google Proxxon FET table saw review. There you will find a video and info on the tool,the article is just under the row of adverts. Go for it,it's a good buy,I've had mine for a number of years. Only thing I didn't like was that stupid plastic blade guard,I removed mine straight away.
Dave
Hi James,
FWIW David Antscherl and Greg Herberts books on building a Model of HMS Speedwell 1752 can be obtained from Seawatch Books. You have a choice to build at 1:48th scale a model in solid lift,plank on bulkhead or fully framed, the plans are excellent and fully detailed. There are several build logs of Chuck Passaro's kit of Speedwell at 1:32nd here on the forum in the kit build section,look at these to give you an idea of what's involved with a POF build of a just a small ship. Chuck also has his original build in the scratch build section which is considerably further on than the kit builds.
My build of her at 1:48th is POB in Box and Pear which is almost finished after 5 1/2 years and is 85 cm long from Transom to jib boom tip,POF would have taken me much longer. You could of course easily have the plans enlarged,bear in mind if you doubled up you would have a model 1.7 metres long from Transom to Bowsprit tip
Thats about the size of a 3 decked first rate at 1:48th with a damned sight less work involved.
Anyway I wish you luck in your quest.
Dave
- JacquesCousteau and mtaylor
2
Hi Johann, that is very interesting indeed,one learns something new every day. The English had something similar,the Topsail Tie Block itself was connected by a strop to a Bullseye free to run on the Backstay. I expect it had much the same purpose,however I read it was just to prevent the Tie Block and Halliard falling onto the deck causing damage or injury if the Tie was severed in battle. One shouldn't believe all that one reads I guess.
Kind regards,
Dave
- Jack12477, Keith Black, dvm27 and 2 others
5
Hi Johann,
You asked in a previous post about the correct attachment of braces to the stays. Karl Marquardt's book 18th Century Rigs and Rigging
has on Pages 101 & 102 brace rigging diagrams of English,French and German methods which may be of assistance to you. You may of
course have already found an answer but I thought it was worth mentioning anyway.
Gruss.
Dave
- Keith Black, mtaylor, cotrecerf and 1 other
4
Hi George,
If I remember correctly from my schooldays 7 decades ago 1sq yard is 9 sq ft,3 x 3. That would give RRS Discovery a sail area
of Approximately 1,366 sq yards. Re your flying Fish multiply the 8250 sq yds by 9 and you have your sq ft.
I think/hope I've got that right.
Dave
- Canute, gak1965, Keith Black and 1 other
4
Sloop Speedwell 1752 by Chuck - Ketch Rigged Sloop - POF - prototype build
My thoughts also,the Helmsman must have had bruised ribs fairly often. I imagine relieving tackles would have been fitted though nothing on the original model shows this.
Dave
