davyboy
Posts posted by davyboy
  1. Hi David,
    You may find this of interest :- Google  The Elements and Practice of Rigging and Seamanship. This will take you to the website of The San Francisco Maritime Park Association, there they have Steeles' work. You want the asterisked chapters of 208,209,210 and 211,numbered drawings and names of the numbered rigging and sail items are there. Should be of great assistance to you. OK, these appertain to a 20 gun ship but the names are the same for all ships. This book covers everything as the title says.
    A lot of reading there to keep you out of mischief for a while :D
    Dave :dancetl6:
  2. Hi David,definitely do it again,that deadeye gap does not look good. Anyway,it will give you some practice ;)  :D  There are a couple of
    books on rigging that I recommend to you. James Lees Masting and Rigging of English Ships of War 1625-1860 and Karl Heinz Marquardts'
    Eighteenth Century Rigs and Rigging. Second hand online booksellers usually have them in stock. Either is worth having,the first being the best.
    Dave :dancetl6:
  3. Good evening Maurice,you have made a beautiful job on your Alert. All your research has indeed paid dividends. I look forward to following your next build,another
    Cutter or something more exotic :D
    I've just spent much of the past week building a Capstan for my Speedwell,had a pig of a job making the spindle. I don't have a lathe so had to make do with using
    dowel,no choice. However much scraping and sanding I eventually got a passable round to build upon. There are a surprising number of parts to make if you count
    all the wood parts never mind all the other things,bolts,pawls etc. The ten bars I'll leave 'til much later.
    Regards,
    Dave :dancetl6:
  4. Hi David,
    Skip what is in the instructions and make them as I wrote as that is the correct method. It's also easier and neater,you would have 8 loops to make taking more space on the masthead.
    I do my shroud siezing like Pat says around a suitable sized dowel. I thread a needle with the siezing line and pass it through one of the legs at the top then take around ten turns downwards about both legs. I then pass the thread between the legs at one end of the siezing then over the siezing and through between the other legs doing so 2 or 3 times. Finally pass the needle & thread through the middle of that,apply some glue (not CA) when dry clip off. You're then good to go. This last bit sounds complicated but is dead easy  to do.
    Dave :dancetl6:
  5. Hi David,
    I assume you are referring to the shrouds. These were made up in pairs by doubling a suitable length of rope leaving enough lenght to tie in the deadeyes. The centre portion was normally served then the two legs lashed together leaving a loop sufficient to fit over the mast head. They were always fitted in the following sequence :- first pair starboard,second pair port,third pair starboard and so on.
    Hope this answers your query,have fun.
    Dave :dancetl6:
  6. Hi Wahka,
    Many builders change the 2nd planking for another wood. Pear is indeed an excellent planking timber and readily available in Europe in
    sheets or milled planks and not too expensive. It also has very little grain showing. Cherry and Maple are also suitable timbers.
    As far as historically incorrect goes most period ships were planked with oak which is not really suitable for modelling purposes at all. BTW,there is
    no such thing as stupid questions on MSW,that's how we all learn "how to do it" correctly :)
    Kind regards,
    Dave :dancetl6:
  7. Hello Doris,
    These are the tackles for the Top Ropes which were used to lower the Topmasts. They were hooked to the top rope pendants which ran through sheaves in the heel of the Topmast. These pendants started from an eyebolt in the Lower Mast cap running through one of these sheaves up to a block on the opposite side of the cap then down to the tackles. There is a very good illustration of this in Lee's Masting and Rigging book (page 55). Also in R.C. Andersons 17th Century Rigging,drawing #13 items 166,167 and 168. Hope this helps with your wonderful model build.
    Dave :dancetl6:
  8. Hi Maurice,very very nice indeed,super job👍. I look forward to the continuation next year.
    I had a rethink on my Speedwell POB. Didn't like the filler blocks fwd of the front bulkhead so they were chiseled out. Made the upper
    parts of the bollard timbers and 4 hawse timbers from pear and fitted them. Had to do some "surgery" on the fwd bulkhead and part of
    the lower filler blocks. Looks very much better. It was quite a job making these parts with a fretsaw,razor saw and files:Whew:
    Regards and I wish you a Happy New Year.
    Dave :dancetl6:
  9. Good evening Maurice,
    That's one of the problems with kits unfortunately. Scratch is the way forward ;) Your idea of using 6 mm stock looks good to me anyway. I was very surprised to see what was provided in the kit for eyebolts and rings :huh: and those ghastly cast cannon,oh dear. Love your Alert print from the Science Museum by the way. I was in their shop 12 years ago hoping to replace a print of HMS Prince I bought in 1974 but was told they didn't sell prints anymore.  Guess they must have started again.
    Dave :dancetl6:
