davyboy
Members-
Everything posted by davyboy
Hi Stergious,rig your boom topping lift (L) as shown in Peterssons book. #19 is a cleat which I can see in your photo,there should be one on the other side of the mast also. The bottom end of the tackles on your plan appear to be hooked to eyebolts in the deck and NOT to the Mizzen channels as seen in Petersson. I expect where they are will be shown on your plan. Where your question mark is would be a good bet I would say. The blocks you marked A and B are fitted on each side of the boom. They are the boom sheet blocks,correctly shown aft of the cleats. Where these tackles are hooked and belayed should be on your rigging plans. Unfortunately Petersson shows a different arrangement. Hope this helps, Dave
- 1,144 replies
- snake
- caldercraft
Hi Ferit, go back to page 3 on this the masting,rigging and sails section. The third thread down is the question I asked last October. 4 replies,1 diagram from Levers' book,a photo of an actual mast cap/truck and a photo of one of Doris's Ship model caps. Your two pics show the flag halliard going through a hole over the top of the mast cap then down through another hole. There should be a sheave fitted there,otherwise the flag halliard would be quickly worn out. Hopefully that will answer your question. Regards, Dave
Good evening B.E. To coin a quotation from an old,old film. "You're a better man than I am Gunga Din". I did fit a key bolt but trying to make a key with chain to fit was a no go,for me anyway. Full marks for your one only another 11 guns to do,have fun Got the Catblocks stropped with the brass ok. I rivetted the hooks in,they look quite good after all. Made up my anchor cables and attached them to the Anchors. For info,you'll need about a half metre of rope for each one,that gives you enough length to play with. I'm still thinking about those Anchor Buoys,get round to it eventually. Serving them is not a problem it's the slings or rather the rope bands that the slings are attached to. Maybe some blackened copper or brass wire rings may work. Oh dear,decisions,decisions. BTW,were they painted,tarred or what ? Regards, Dave
- 574 replies
- cheerful
- Syren Ship Model Company
Ferit, Why would you make hanging blocks for this ? The flag halliard sheave is fitted into the Mast Cap. Just drill two holes close together in the mast cap running fore and aft to simulate a sheave. Dave
Hi Tony,I agree with wefalks comment. This pattern of swivel gun called Falconets were at least in English navy ships obsolete by the early 17th century. I would imagine the French navy was much the same. Dave
- 9 replies
- swivel guns
- cannon
Hello Ferit, I asked this question last year. The general consensus of opinion was that the flag halliard sheave or sheaves usually run fore and aft either side of the mast. Dave
Very nicely done B.E. I drilled through each carriage bed then placing the carriage centred at a gunport then drilled through into the deck. I wrote the position under each carriage Pt 1,Stbd 1 and so on to ensure the completed units went into the right place. I kicked the idea of using the copper wire stropping for the Catblocks into touch,it looked awful. Made some from brass sheet a la the drawing in Lees,much better looking,a PITA to make though. Also made the anchor buoys,having a real problem making up the rope work That's on hold for the time being. Have a nice weekend,regards. Dave
- 574 replies
- cheerful
Hi Stergious,it's standing rigging. That line is one of the topmast backstays. Dave
- 1,144 replies
- snake
- caldercraft
Hi B.E. These chainplates were a bit of a pain to make,I had to remake a couple of mine which were not up to scratch. Yours look very good indeed. Will start making my cat blocks this weekend,I have some .020" x .040" copper wire. Just about the right size for the "iron strapping",I hope. regards, Dave
- 574 replies
- cheerful
Fred,dip the end of the thread in cyano glue then cut diagonaly across the glued part. You then have a needle point,goes through evey time. Dave
Chris, Have a look at www.massiv-holz-werkstatt.de Frank Horschigs website. Example prices for Beech,Cherry and Pear sheets 1000mm x 100mm x 1mm are €3.10,€5.00 and €7.20 respectively. Cheaper to buy sheets and mill your own strips He has a large selection of other wood and also does strips. I buy my wood from him,good quality timber. Hope this helps, Dave
Hi B.E. I too thought that about the outboard steps so I just added a fourth. The 5/8" gap to the top rail is 2'6" in reality. They must have had very long legs considering the average height then was around 5'6" I've just finished making the stocks for my anchors. Went into Laverys' Arming and Fitting to find out the bolting patterns for them. Read a bit further on and he says that the round Crown Anchor and Arms shown on my copy of Chucks plan were not around in 1806. The first of this pattern was not made until 1813 and by 1815 only 25 had been made and 14 issued,probably starting with 1st rates. I also had a look in Steel but no mention of a new pattern there. Up to you of course,just thought I'd let you know. Regards, Dave
- 574 replies
- cheerful
Hi John,nice to see another Cheerful being started. Blue Ensign has an excellent build log in the kit build log forum here on MSW. My own build is almost finished,scratched except for the windlass and guns. I will be following your build also. Dave
- 160 replies
- cheerful
Good evening B.E. That ladder detail is not on my plans which are from 2015,that is obviously a later amendment. Still,it wasn't a problem to make the ladders,milled 1/32" slots in some 1/16" sheet pear. Marked out the required angles for the stiles then sliced them off on my table saw. Glued up,job done. BTW,remember we are our own worst critics,your work is excellent 👍 Thanks for the thought about my hands. Left is now OK but right still giving me "jippo". Dave
- 574 replies
- cheerful
Hi B.E, Looking perfect as normal. I also left my cleats unpainted,looks much better than being painted would. Out of curiosity where on the plans are the ladder profiles shown ? Certainly nowhere to be seen on my plans or else I'm going blind Anyway I just made a pair to fit,look the same as yours with unpainted stiles. Haven't done anything these last few days,cold,damp and frosty weather do wonders for the rheumatics I have in both hands NOT. regards, Dave
- 574 replies
- cheerful
Hi B.E. It's looking very good. I was right when I said 2mm looked overscale as you've shown,I'll order some 1,8mm cabled rope for my anchor cables. Funny you should mention about a cathead support bracket,I thought that too. The Science Museum model hasn't got any and of the NMM models only one appears to have them fitted. regards, Dave
- 574 replies
- cheerful
Thanks for that B.E. I had purchased some 2mm dia. cable laid rope but it looked much too large. 1.8 mm dia would likely be ok but I'll wait until your post on cables. Dave
- 574 replies
- cheerful
Hi B.E. I'll post these items to you tomorrow or Wednesday.and will tape the files and drills to a piece of wood to prevent breakage in the post. Not sure about the anchor cables. I've had a look in Steele's list of necessary ropes and can find nothing about the size of anchor cables although every other rope related to anchors is given. Sods law I guess or I'm looking in the wrong place. Have you any idea of their sizes in comparison to the mainstay ? I read somewhere sometime that they were the thickest ropes on the ship,but............ Regards, Dave
- 574 replies
- cheerful
Patrick,you are making a very good model,very nice indeed. I watched a programme yesterday on English television about this ship and Drake. There were many parts of the programme taken on board the replica in London. Not a lot of headroom below decks and extremely cramped living conditions. Hard to believe that the original ship circumnavigated the world. BTW,the pivot point for the Whipstaff is called the Rowle. Dave
- 756 replies
- galleon
- golden hind
Very nice job on the ordnance B.E. There are a lot of parts for each gun assembly aren't there. I've moved both my long guns to the #2 gunports and have made up 4 swivels to place in the #1 gunport areas,my choice. The rigging is nearly finished,just the lower yard braces to do then make the cat blocks and anchor buoys etc etc. BTW,if you can find a use for a couple of 1mm sq x 80mm long jewellers files #4 or 5 cut plus some .7 and 1mm drills drop me a PM with your address and I'll post them to you. All are unused courtesy of the Basel fleamarket,cost me next to nothing Regards, Dave
- 574 replies
- cheerful
Matrim, The tops should not be at right angles to their respective masts but tilted down at their fronts at the same angle as the mast is raked aft. As the tops are fitted to the trestle and cross trees Steele says :- "the foremost ends (trestle trees) are to drop as much below a square with the middle line on the mast as the mast is to rake aft in the length. That they may be level when the mast is in its place". Sorry about the somewhat archaic English. Hope this is of help. Dave
I would say yes. The Spritsail yard would certainly have at least standing lifts and was also used as a lead (via thimbles or eyebolts) for the Jibboom and flying Jibboom guys. Has to be safe access for any repair/maintenance req'd on those whether or not a sail is bent. Just my opinion of course. Dave
Well done with the Boom Crutches B.E. I did say they were a bit of a pain to make I like your addition of bolts in the Transom Knees,I may crib your idea and do mine,have to remove the Flag Halliard cleats first though. C'est la vie. I bit the bullet and made 4 swivels and posts for the bow area,I'm the Captain so it's my choice They also will not be added until the build end. Incidentally,I'll bet you will catch those Crutches sometime,they are a bit vulnerable there,even when pinned. Mine have been off a couple of times already,I'll glue them finally at the end of my build. regards, Dave
- 574 replies
- cheerful
An excellent start to the New Year B.E. I just carefully cut down the transom frames 'til the knees were a snug fit,those Boom crutches are a bit of a pain to shape right. I had two attempts before I was happy. I'm currently in the process of rigging the Yards which I fully dressed before hanging them,makes life a bit easier. I wish you a happy,healthy and prosperous New Year. Dave
- 574 replies
- cheerful
