Canute
Everything posted by Canute
  1. Rustoleum, parent of Testors, ended the Model Master line. You may find stocks at some shops, but many colors are no longer available in the Model Master line. Get familiar with acrylics or hunt for the dwindling list of lacquer/enamel providers. The available lac/enamel paints are very good, as paints go, but your matching to your desired color may require mixing custom paints. And handling of the materials may drive where you are willing to go.
  2. Another RFM build. I'm in. That will build into a spectacular model, Craig.
  3. Foot powered maneuvering devices - sometimes. Your details are really enhancing this bird. Well done.
  4. You might want to looks at Pan Pastels here: https://panpastel.com/products.html They have an extensive palette and are easy to apply. Work on some practice pieces before you do Cairo to get a feel for applying these pastels. I like them, because you can top coat and the colors and distribution won't change. Almost like there is a glue involved.
  5. Mark's right, OC. If we all did that for our boo-boos, we'd never get a thing done. 😁
  6. They may have used preliminary data and drawings to do the model. The early F-15 and F-16 models had this issue, too. The JPL info is what NASA really launched. Your choice as to which route to follow for your build.
  7. CO is an odorless gas. Thankfully you have working monitors. Ours are wired into the house, but have battery backups. Those of us in northern climes need to pay attention to our protection devices as the heating season approaches.
  8. Denis, you could file off the outside detail on the front truck to get more swing. I seem to remember the Walthers plastic version of this plow has you remove the outside details. Our model trucks are way too wide with their outside dimensions. Model track radii are way tighter than the real world. Most folks just park the plow as a scenery component in their dioramas. Our dioramas usually model warm weather months, so the plows and flanger cars aren't being used.
  9. Greg, you've treated the Old Covered Wagon with great respect. Another superb job. 👍👍
  10. Denis, I'd be surprised that they included the foundations back then. But maybe they did. The roof could also be done in sheets of galvanized roofing. Build up a frame of rafters and lay the metal sheets you acquired over that. The thinness will look better than the 1/32 or 1/16 in thick wood parts. The walls look good so far. What colors are you painting this?
  11. Interesting to follow the process of blending the matching colors. I'm in, Chris.
  12. I'm in. A Rye Field build should be a nice one.
  13. Excellent diorama. You can almost feel the sun beating down. 👍
  14. Nice framing, Denis. 👍 Brick looks good; just need to dirt them up or fade the mortar. Those old kits leave a lot out. Most real structures have some kind of foundation to raise the door opening above the ground. I've seen plenty of articles about adding structures to layouts and adding assorted foundations to do that. I suspect that Keystone kit was designed in the early 60s, so foundations were not planned for.
  15. OC, you're in the zone with your painting. Thanks for sharing all of this.
  16. Excellent rigging of that leg. The hanger on top is a beaut. Great detail in any scale.. You must be cross-eyed with rigging the eye-bolts. 😁
  17. Nice job with your build. Forming that plow blade was fun.😁
  18. Something that gaudy would help form up the flying units. At altitude, those dull green and gray a/c can get lost against the cloud background over East Anglia. Having some crazy painted "war weary" a/c to attract 4-6 sets of eyeballs in each plane during a rendezvous would help. i did a few (?) joinups over Germany and I had a state of the art airborne radar to help me out. Those heroes had the old Mark I, mod Zero eyeball. The ground crews probably figured the Os got into the gin supply and went a little loopy. Lou, we came home to the San Francisco Bay Area; back then, in all it's psychedelic glory. It was a riot of color. The year we spent in the boonies dulled our sense of color. Out side the dull grays and greens was some orange dirt in some places around the northern Corps areas.
  19. Grant, those old craftsmen really took pride in their work, with the nice coloring and workmanship. This model carries on that tradition and your rendition is top shelf. 👍
  20. Denis, this is another good site for sheet building supplies, the N Scale Architect: https://thenarch.com/ It's more than N Scale stuff, catalog links are at the bottom of the page. Northumberland was a loco facility and yard for the Pennsylvania RR. Had a big many stall roundhouse, fueling docks, etc. They stored many locos there that eventually were moved to Strasburg, PA and the Pennsylvania State RR Museum. Worth a trip to go there, along with a ride on the Strasburg RR across the highway. Maybe include a trip to Scranton to visit Steamtown and an anthracite mine. Dating those kits, probably late 60s-early 70s. Good for their time. Have fun with the build. If you use the kit sheet wood, cut from the back and use tape to draw your cut lines. As I remember, the sheet stock dries out and gets brittle.
  21. Denis, you're turning this beast of a kit into a fine rendition of an assembly bird. 👍
  22. Unless your computer can read your mind, sure. Me, I am waving my hands over my keyboard, in the tried and true "hunt and peck" method of typing. 😁 Being only half Italian, this works for me.
  23. I know a few Italians who operate the same way. Can't talk while sitting on hands. Quite interesting following the discussion on keeping the print area level. Learning a lot. Thanks.
  24. My train club gets these "heirlooms" from folks turning in Dad or Grandad's train stuff as donations. We resell most of it at the semiannual train shows up near Asheville Airport. Any scale, it all sells. We have some dealers who come to the shows who scarf up whatever we don't sell during the show. For the club, it's all profit, since the stuff is donated. We survey the donations and if we have items we could use for the club or potentially offer on the online seller sites. Some items, like Denis's Findex car could attract collectors of these kits. Like Ron said, the sides/ends were a paper wrapper.Without it, it's scrap wood. Very early HO since the body is a solid wood block. Post WW 2, folks like Northeastern brought out precut floors, roofs and end blocks you could attach wood or paper sides and ends. Some kits used white metal castings for the ends. Looking at them nowadays, the castings could be pretty crude. The plastic aftermarket parts run rings around them. But plastic kits are fading away. Many current hobbyists just buy ready to run; the old instant gratification. Luckily a few manufacturers still make undecorated kits. And resin castings are taking over for us freight car fans. The big issue for them is the quality of their instructions. Some are copy machine copies with poor diagrams; others do it up in color and you download a quality PDF or PowerPoint . It's a big, fun hobby. Some of us get together at somebody's model railroad to operate in a prototypical manner, using radios, manifests and obeying track-side signals. Others just like taking their locos and cars out for a spin at our club, enjoying the sight, running through realistic scenery. Different stokes for different folks, as the singer sang.
