Everything posted by Canute
They've been used in some port cities for water tours of the port. Interesting build, all loaded out.
That's a real shame, Paul. Hope you don't give up on doing more plastic ships.
- 17 replies
- Colombo Express
- Revell
USS Tenacity looks like a Measure 12 Modified scheme. Here's the page on the Ship Camouflage website: https://shipcamouflage.com/measure_12_modified.htm It was an early war scheme, used on a number of USN ships.
Fowler Class Z7 Steam Ploughing Engine by wefalck - 1:76 scale
Canute replied to wefalck's topic in Completed non-ship models
Nice lineup, Chris. There is a cable/satellite TV channel here in the US called RFD-TV. It has several shows on a lot of this stuff. -
Gentlemen, that's due to TMB - too many birthdays. My eyesight was very sharp up until age 42-43, then slid down hill slowly. Glasses helped me keep up. Last year, at age 72, the growing cataracts got bad enough to require surgery. Now, my distance vision needs no assistance; however, I do need readers/optivisor for closeup work. I think that's fairly typical. I attempted some 1/700 PE, but it's been a while. I think I'll work in bigger scales, mostly for the manual dexterity rather than the visual issues.
It may have to do with the footprint of the tractor. There is a small point for each tire contacting the ground. The tractor weight, including the fluid inside each of those rear wheels, is concentrated in a very small area. [Yes I did say fluid in the wheels. Adds weight for traction. I forget what it is, but getting a puncture was a pita. Luckily, the tractor wheel mechs are traveling workshops to make repairs.] Heavy weigh, small footprint= high PSI, compacting the soils. -
Greg, the twin engine amphibians have twin tails. Any idea what those are? My flying boat recognition is sadly lacking. Oh and I'll be following this build. I have a soft spot in my heart for the star-crossed ships of ABDA.
Jagdtiger by Jörgen - Tamiya - 1/35 - PLASTIC - Weathering
Canute replied to Jörgen's topic in Non-ship/categorised builds
Great work, Pictures look good. -
The links didn't work for me. -
If you ever find yourself near Savannah, GA, there is an 8th Air Force museum just off I-95. They have a B-47 visible from the Interstate as a marker. They have a number of a/c in the museum building and a few out side, too. The B-17G is open to peek into a bit and you see how tiny this mainstay heavy bomber of that war actually was. My old F-4 carried a heavier bomb load at times than the old Fortress. And the a/c skin still is all that protects the crew. No armor plate, except in the A-10, that I can think of. And they reconstructed an English parish church on the grounds, bell tower and all. Nicely done.
Yes, this one was designed back in the age of aztec stairs. The flared main battery is unique. Hopefully you run down a replacement set of turned brass or replce the complete turrets with 3D prints.
A lot of structures have something called selective compression, shrinking segments to "fit'. Also, the walls and floors aren't scale thickness, so that eats up your workable volume. You'll probably need to complete all the figures for the first floor, then add the next floor, sealing them in. That will keep you bouncing back and forth between the structure and your excellent figure painting. Won't get bored.
