Everything posted by ccoyle
Sometimes yes, sometimes no. Sometimes it is easier to do the edge coloring after the thing is put together.
A few questions: Are you looking for a Baltimore clipper in particular, or just any ol' topmast schooner? The OcCre kit is not a Baltimore clipper; the other two are. Have you got a budget? Do you want a historically accurate model (or at least reasonably so)?
So, I don't believe I told anyone around here about what happened to the poor Sha-Sam-Kat. After taking her out for only the fourth time last year, I had her turned over on the lawn to dry after rinsing out some dirt. A few hours later, I flipped her over and lo and behold -- the seat had fallen out! Not only that, but some of the paint had reacted badly with the seat's contact cement, causing the paint to peel up. Needless to say, I was not pleased. In the meantime, my womenfolk had taken over my work area and proceeded to use it for a seemingly endless series of furniture refinishing projects (which the two of them are actually pretty good at), and it only became available again just this week. So, step one was to remove all of the old contact cement residue and peeled paint, then sand down the area. Fortunately, I still have leftover paint from the original work, and here's the Kat after two coats of primer. Next will be several coats of the top color. Each has to dry for at least 16 hours before the next coat can be applied, so I might have the repair done by next weekend. By then, her new and better replacement seat should have arrived, at which time I'll post a pic of the finished work. Cheers!
19: 20mm Gun Tubs So, skipping ahead for a bit as suggested by the instructions, I thought I'd show a bit more of how one of the sub-assemblies comes together, featuring the second starboard 20mm gun tub. This took about 2 hours to build. 🤪 First, some of the sub-assemblies of the sub-assembly. Oddly enough, the laser-cut detail set did not include ladders for the two Step 19 tubs -- go figure. To help maintain the shape of the tub while gluing its floor and wall together, I joined the two parts together around the end of a dapping tool handle. And here's the finished tub mounted to the hull. One more tub to go!
One suggestion I would offer is to make your panel lines much lighter. If you look at pictures of contemporary ships, you'll notice that sail seams are scarcely discernible, if at all. You can see how I did this by clicking here.
- 35 replies
- Constitution
- Revell
Welcome aboard! Many of us, myself included, started in this hobby by building plastic models in our teen years. Good luck with your project!
18: Funnel This is the basic funnel structure. It's not difficult to build, but it would have been easier if I hadn't rolled the outer skin incorrectly. 😬 This necessitated some fiddling to correct the shape, but no 'special words' were required. There's much, much more to add to this (e.g. ducting and piping), but the instructions suggest skipping to Step 19 (20mm gun tubs and a few other bits) before coming back to add the funnel. Cheers for now!
Just a reminder to not use tags in the non-ship-builds area. I just finished scrubbing tags from four pages of logs. If any of these were you, don't feel bad -- even I forget this rule sometimes, and I think I may have been at fault for some of the tags I just now removed! 😬
The answer that Baker linked to above addresses mainly wooden kits. In your case, you don't really have a kit, even though you are using some commercially available parts. Since you are essentially cobbling together a model from a variety of sources, I'd classify this as a scratch build, though plugging the phrase "semi-scratch" in the title would alert the reader to its true nature.
Your New "cautionary tale" posterchild here!
ccoyle replied to Valkyrja68's topic in New member Introductions
I grew up in Humboldt County, where folks think that places like Santa Cruz and Capitola are in Southern California! 😆 -
Fairey Gannet by RGL - FINISHED - Trumpeter - 1/72
ccoyle replied to RGL's topic in Non-ship/categorised builds
Nice work! -
17: Aft Gun Tub Next up was the aft gun tub for the #3 3"/50 mount. The depth charge mandrels really drove up the parts count for this sub-assembly, bringing the total to 106. Happily, I hit on a quicker way for assembling the mandrels by gluing their tubes to the laser-cut cradles and then painting the mandrels before cutting them free from the card fret -- a much faster process, with the added benefit of keeping all of the little parts together for as long as possible.
Treasure Galleon La Nuestra Señora de Atocha, 1620
ccoyle replied to davos522's topic in Nautical/Naval History
Okay, call me silly, but I had expected that a "treasure galleon" would look a bit more flashy. But then, it probably wasn't a great idea to attract attention while carrying a fortune aboard. -
Outstanding! Card + pre-Dreadnought + Captain Slog = win.
- 13 replies
- Dom Bumagi
- Admiral Nakhimov
Welcome! We also have a section in our gallery for models in museums and exhibits.
In the upper right corner of each of your posts is a symbol composed of three dots -- clicking that brings up a drop-down menu from which you can select 'edit.' You can also edit your title, but only from the first post. I gave your title a fine-tuning so you can see the proper format. I also tagged your build log; tags help members quickly find all of the topic threads that bear the same tag, e.g. clicking the 'Revell' tag brings up a list of all the topics that have a Revell tag. You can also resize your photos, should you feel the need; simply double-click on the embedded photo to pull up the resizing menu. Cheers!
- 35 replies
- Constitution
- Revell
To learn more about the touchy subject of pirated models, click here and here. In a nutshell, there are certain kit manufacturers who are engaged in the nasty business of ripping off the designs of other companies. These unscrupulous companies and their products are persona non grata at MSW. -
16: Bridge (completed -- yay!!) Okay, the last bits of the bridge have been added (for now -- some other bits get added later). These include navigation lights and some electronic doohickey on the forward bridge wall whose function I do not know. This wraps up Step 16. Whew!! Total parts count for this sub-assembly came to 142.
