Everything posted by ccoyle
Rear fuselage skeletons complete. This is the easy part . 🤨 Next up is the internal cockpit structure. As you can see from the diagrams, Lech chose not to make this a simplified element -- there is a lot of open and delicate framing involved. This will not be a sequence for the faint-of-heart builder.
Hello, and welcome to my build log for the 1930s Polish trainer, the PWS-10. Many westerners are unaware that Poland had a vibrant aircraft industry in pre-war Europe, producing both military and civilian aircraft. Some of the designs produced were cutting-edge and among the best aircraft types of their time. The PWS-10 was not one of them. 😬 Designed by the Polish Aircraft Factory (Podlaska Wytwórnia Samolotów) and first flown in 1930, the PWS-10 was intended to be a fighter, but from the beginning its performance was underwhelming, so the type was quickly relegated to training duties (the excellent PZL P.7 first flew the same year and quickly became the backbone of the Polish Air Force fighter corps). Only 80 were built. A parasol monoplane powered by a 12-cylinder, 478-hp W engine of French design, the type was armed with two 7.7 mm machine guns and had a top speed of 150 mph (240 km/h). In 1936, twenty examples were sold to Spain, where they also served as trainers for the Nationalist side. The kit is designed by Lech Kołodziejski, who first made it available under his own brand and website, CardPlane. CardPlane has since closed for business, but Lech's designs are still published by WAK. The first "real" card airplane I ever built was one of Lech's free models, the WZ-X, and I have since built two more of his models (below, l to r: WZ-X, Bartel BM-6, PWS Z-17). As you can see, Lech's design interests lean towards obscure and experimental aircraft types rather than those that went into large-scale production. After completing the WZ-X, I sent Lech some photos to use as promotional material at his website. Not too long afterwards, I received a very pleasant and totally unexpected surprise in the mail -- a set of all of Lech's designs then available in print, among which was the PWS-10 in Spanish markings. Later, a different designer made a free repaint of the model available in Polish white-tail markings. For this grand adventure, I will be building both models side-by-side. Lech's designs, including this one, typically have very robust skeletal structures. Unlike the recently deceased P-36 attempt, whose fuselage consisted of a number of conic sections glued end-to-end, this model's fuselage will be built using a profile former and a number of transverse bulkheads coupled with longitudinal formers. The wing is built around two spars. It should all prove very stout. I recently found some laser-cut formers for this kit and snapped them up. The retailer only had one set, though, so one model will use the laser cut set while the other uses formers cut from brown chipboard. The laser-cut set has been coated with shellac for additional strength, but the chipboard already cuts like iron, so it will not get the shellac treatment. Construction is already underway. The first task was to mix up the necessary edge color paints, which I was able to successfully do using only paints that I already had on hand. I'm quite pleased with the results, which I tested out on a part from each model. Next time: fuselage construction. Cheers!
Trumpeter has been in the plastic kits game for a long time and is particularly known for their steel navy kits. I noticed right away that the molding of your kit's hull looks very good and appears to have a nice level of detail. I also like that they used a tan-colored styrene instead of the more commonly seen black or dark brown used for sailing men-of-war kits. I think that will make things easier when it comes to painting. One thing I might suggest, though, is that you replace the deadeyes -- they don't look nearly so nice, and replacing them should not be difficult. Have fun on your project!
Welcome! I love indigenous small craft of every stripe -- your model looks great!
Well, I'll wrap up this topic by letting you all in on a plan I have been mulling. Since I have two PWS-10 kits and essentially two sets of formers, one printed and one laser-cut, why not just build both of them? 😯 One of the biggest obstacles for me for starting a card model is getting the edge-coloring media correct. With these two kits, the primary colors are shades of gray, brown, and olive drab. I already have most of the paint on hand that I anticipate I'll need to mix the correct shades, so not too much difficulty there. These are also nice kits that I was blessed with gratis by their designer, so I have little in the way of capital investment tied up in them -- nothing to lose, so to speak. Might be important considering my current dreadful run of form on card models. 🙄 Here's a few photos. Three-view of the PWS-10. "White Tail" markings. Spanish Nationalist markings. Laser-cut formers. Of course, if I move forward with this, I will start up a new topic with more details about the plane and kit. Cheers!
Welcome! I always advise SoCal folks to check out the Ship Modelers Association. They meet in Fullerton, if that's near you. There's nothing quite like meeting your fellow modelers alive and in person to socialize, look at models, and swap tips and advice.
KI-43 Oscar by Javlin - FINISHED - Hasegawa - 1/32 - PLASTIC
ccoyle replied to Javlin's topic in Non-ship/categorised builds
Sadly, I don't know the answer to that question. But if you google his name on the usual plastic forums, e.g. FineScale Modeler, he's probably got it described in more detail somewhere. Edit: Here is one such article. -
I have a friend (Brian Criner) who has done some amazing finishes on Japanese aircraft. After he pre-shades his panel lines, he sprays the aluminum undercoat followed by a coat of Futura floor wax, and finally the topcoat. Then he uses crumpled cellophane tape to randomly chip the finish. It is very convincing. This is one of his models. Maybe a little depressing for us mortals, but certainly something you could try if you are handy with an airbrush. -
Wow! Your remodel is amazing -- makes me want to come over and play. One comment about your gaff jaws: The jaws should not have hooked ends that wrap around the mast; they should just be open like a letter "Y". Hooked ends would make the part rather difficult to afix to the mast. Cheers!
- 195 replies
- enterprise
- constructo
Yep, agree. As I said in my introduction, I have finished a model from this designer, so I'm a little taken aback by the overall quality of this kit. Not his best work, and the diagrams -- or lack thereof -- certainly didn't help. I have one other kit from this same designer, and a study of its parts and diagrams suggests that it is more up to the gentleman's usual standards. It's a technique for stiffening the internal formers that I have read about but never tried. I'll discuss it more in my intro for the next build attempt (subject as yet undecided). Amen!
The Golden Bear kits were really quite nice. They used to be sold as digital downloads from a site called Gremir Models that went out of business a couple of years ago. The place to inquire about Carl (aka Golden Bear) is at papermodelers.com, where he has been a longtime member. But he hasn't visited the site since June, so I don't know what the story there is. Michael Mash (also his username), who is also a member at Paper Modelers, has built several of the GB models, and expertly so, so he might have some insight into Carl's recent whereabouts. Cheers!
Well, I came home after work and looked at the diagrams again, hoping for a moment of clarity. None was forthcoming. So the decision has been made and the bench has been cleared. I didn't toss the model, but it is currently occupying a place of dishonor up on a high shelf. So, what is next? One of the things I would like to experiment with is using shellac to stiffen laser-cut formers. I have a number of kits that I think would suit the purpose. To be a candidate, the kit had to: have clear diagrams be a kit I had a vacuformed canopy for or else have only a windscreen -- no scratch-built canopies not be an especially high-value kit, like anything in my Halinski collection. Candidates include a Fokker E.V from Kartonowa Kolekcja (I have successfully completed two KK kits), a PWS-26 trainer in Hungarian livery (a Marek Pacyinski design, of which I have attempted two and completed one), and a PWS-10 from CardPlane (I'm three for four on CardPlane kits), for which I have two different liveries (Spanish Nationalist or Polish "White Tail"). I'll have to meditate on these options -- and of course I have been known to go off the rails and choose some previously unconsidered option. 🙄
Not a problem. A lot of people get into this hobby with no awareness of the knock-off kits problem, so you're far from being the first. One of our goals is to educate those in the hobby about the issue.
Well, however durable the finished product may turn out to be, it's sweet of you to build something for the grandson.
- 14 replies
- Mississippi Lady
- Matches 21
Sorry to say, but if the instructions are in Chinese, then the first thing you need to do is read our statement on banned manufacturers. The vast majority of kits coming out of China are infringements of Western intellectual property (i.e. knock-offs), though there are a couple of Chinese manufacturers who don't engage in the practice. Kits from manufacturers on the banned list are not allowed for build logs or discussion here at MSW.
Well, this kit continues to be exasperating, and I'm emotionally about ready to bin it. After finishing the engine, which as I pointed out earlier is very oversimplified, and getting its cowling done with little difficulty, it was on to the landing gear. Now, the P-36 had a very complex set of landing gear doors, and the kit has, I'm sorry to say, made their construction virtually impossible to figure out. To begin with, the kit includes separate parts for inner and outer surfaces of the door bits (i.e. exterior color, interior color); higher quality kits often accomplish this with two-sided printing. Laminating two parts together results in a part that is too thick, so I have been ditching the interior parts and painting the reverse side of the exterior parts instead. This isn't an insurmountable problem, obviously. The real issue is the large number of door parts and their indecipherable diagrams (below). At first glance these might seem very detailed, but the problem is that the gears and doors themselves consist of so many parts that the diagrams fail to clearly show how some of them fit together. For example, there is no clear view of the forward end of part 61, nor is there any hint at how parts 60 and 60' are articulated, nor how part 60' is supposed to fit to the wing. And this is by no means an exhaustive list. This is all very exasperating. I don't like models that are half model kit and half mind-bender puzzle. And as I have ranted about previously, this isn't the first aggravating construction stage I've encountered with this kit. But I also don't like feeling 'defeated' by a kit. The problem is that an annoying and unfulfilling kit tends to get less and less construction time devoted to it and simply ends up delaying the start of a kit I might enjoy much more. Frustrating ... And for a cherry on top, I managed to get a large dollop of interior green right on top of the recently completed engine cowling, with no idea how I accomplished that. 😡
Привет! We look forward to seeing your work.
Good question, and one I'm not entirely certain about how to answer. It was commonplace for small warships like these to be sold out of service, but I'm no expert on how their private owners would have fitted out such a ship.
