Everything posted by ccoyle
New to modeling where to post a kit build for advice?
ccoyle replied to bosco72's topic in New member Introductions
Nope. In fact, we strongly discourage third party hosting. You can upload your photos here, insert them into your post, and resize them as necessary. Cheers! -
I took a slightly different tack with the other half of the strakes and hope that it produces acceptable results. I made the epoxy slightly runnier to lengthen its working time, and I applied the epoxy to all the puzzle joints first before putting them together. This time around, the process went much faster. Here's a shot of the strakes atop my temporary workbench, consisting of a sheet of plywood screwed down to two 2x4s laid across a pair of saw horses. A nice thing about the plywood is that I can clamp the glued pieces by screwing down a 2x4 strap across the stacks of strakes. I will need to glue the outboard rub rails to the top strakes before they can be stitched, but they other four sets should be ready to go for the weekend.
Yep. Looks like glued wood. The instructions said not to worry about the mess, 'cause it's all going to get epoxied anyway, so I will try not to. I was pleasantly surprised at how easy the rough epoxy was to knock down with a sanding block -- the instructions led me to believe it would be something like concrete after it set. I hope to be able to finish gluing the strakes before the weekend, so that I can start the stitching process.
Learning as I go... Lesson #1: Two-part epoxy mixed with filler to a "jam consistency" pretty quickly progresses to "modeling clay" consistency. Lesson #2: The working time for mixed two-part epoxy isn't very long. Lesson #3: The amount of two-part epoxy needed to glue up ten planking strakes has only enough working time to do five strakes. Ask me how I know. 😬 Lesson #4: My hands must be size extra-large -- large-size latex gloves barely fit. Lesson #5: Disposable latex gloves do not breath, like, at all. When I took them off, sweat literally poured out of them. Can't wait to see what I learn next! 🙄
Okay, far enough along to justify an update. The build sequence for most card model airplanes starts with the cockpit, but for some reason this one starts with the wings. First, the internal formers. You might think that laser cut parts like this should fit perfectly, but they usually don't. Some minor trimming here and there was necessary. The key is to get the dimensions of the internal structure matched to those of the skins before one starts gluing the latter parts on. Skins on next. Each is one large part, so there's a lot of glue that must first be applied, followed by quickly positioning the part. This is helped out by forming the sharp curve in the leading edge before attaching the skin. Now comes the cockpit. Internal formers and seat come first. There's a rectangular part with four holes in the middle of the seat back. I have no idea if it's in the correct position. The diagrams were unclear on this bit, and I couldn't find any P-36 cockpit photos online that showed this particular part (even if one does find such a photo online, there's no guarantee that the seat in the photo is either period correct or correct for the H-75). Interior cockpit skins with their various bits -- radio, throttle quadrants, etc. Right skin on. The control stick consists of 14 separate parts -- bleah! And finally, a couple of shots of the finished cockpit. Unlike many kits I have worked on, this kit did not include optional parts to allow for glazing the instrument panel. It does, though, include parts for building the two fuselage-mounted .30 caliber machine guns, but they are pretty basic structures. I'm going to omit them. That's all for now!
The phrase "model ship" is a little vague -- the kind of model ship your dad saw may help determine what sort of model would best suit your purpose. Can you tell us more about what you're looking for?
Here's nearly $200 worth of tools and consumable supplies. 😳 A bit more than what's usually required for one of my card models, but then again I can't paddle around in a card model. (The epoxy, metering pumps, and fillers in the back were included with the kit.) The canoe has five strakes per side, each made in two halves which are joined by a puzzle joint. The parts are plainly labeled. CNC cutting leaves little tabs on the plywood parts that need to be removed -- just like in many model kits! While I'm waiting for materials to set up a temporary workbench, I've been removing some tabs and giving the plywood edges a light sanding to smooth away some of the fuzziness. Here's some cleaned up half-strakes atop one of the temporary bulkheads that will be used during the construction process. That's it for now.
Oh, ho! Another potential convert to the Dark Side!
- 35 replies
- allege darles
- wak
Hi, JEB. I saw your Flying Fish in the gallery, and it came out very nice indeed, in spite of all of the kit's shortcomings (and there are many). I actually wrote a pretty scathing review of that kit for the old Dry Dock Models forum that went down the water closet of history when that site folded.* The kits coming out today are lightyears ahead of those old Corel kits in both quality and design philosophy. Cheers! (*Now there's a bit of history to curdle the nose hairs of some of our newcomers. Dry Dock Models, or DDM to most of us, was the go-to ship modeling forum back in the days before MSW. But, unlike MSW who are owned and backed by the NRG, DDM was privately owned. One day, for reasons not entirely known, the owner just pulled the plug on the operation. All the content was gone -- kinda like our Big Crash of 2013, but without the intent to start things up again.)
In case you were wondering (or maybe I missed it somewhere earlier), this type of rig is called a spritsail in English.
Ahoy, friends! One of the things I have had on my bucket list for a long time is to build a boat, one of those "hole in the water into which one pours money" things. My choice of boat was based on these criteria: light enough for one person to carry able to carry me and some fishing gear suitable for first-time builder car-top portable small enough to store in the garage good on-the-water performance reasonably cheap. This past winter, I came into a small inheritance and also happened to move to within a couple of miles of not one but two publicly accessible lakes here in SC, so the time seemed right. The Sassafras 12 canoe kit from Chesapeake Light Craft (CLC) ticked all the boxes, so I ordered one. I didn't have time to get started last winter, since we had just bought a new house and moved into it, with all of the painting and landscaping that entails. Then the miserably humid deep south summer set in, so no building then, either. Now the weather has cooled, and the missus has made nebulous threats and implied that vaguely defined harm may befall me if I don't get the kit boxes out of the way, so it must be time to start! So, what does the kit include? Box #1 includes all of the parts: CNC-cut planks in okoume plywood, permanent bulkheads, temporary bulkheads, sapele decks, rails, wire, center thwart, seat, back band, and fiberglass sheathing. CLC calls the construction method 'lap stitch' -- it is a combination of lapstrake planking and stitch-and-glue assembly. Box #2 includes the nasty, liquid goodies: 2-part epoxy (with dispensing pumps) and fillers. The instructions run to 116 pages and combine text, photos, and diagrams. I've read through them once, and they seem pretty thorough. Hopefully, when all is said and done, I'll have something that looks like this ... ... rather than this. Cross your fingers! First things to do are read the manual again, make a shopping list of tools and consumables, and get a work area set up in the garage. Cheers!
It was not uncommon, even well into the 20th century, for civilian ships to be taken into military service and vice versa. The naval cutter design began life as a smuggler before being adopted by various navies for inshore duties. It would not surprise me at all if one were sold out of the service for a second career.
Nice -- quite the logical follow-up to your F3Fs! I have the Halinski 1/33 scale card version of the F4F. It's an older model that lacks the usual top-notch Halinski weathering, but I'm still reluctant to build it, mainly due to the need for building the nightmarish landing gear assembly essentially from scratch.
Good call with the boxwood. I have the Victory Models HMS Fly, one of the very first examples of that kit, purchased and started back in 2006. It's still sitting on a shelf, waiting to be finished. I confess that one of the reasons that I'm not particularly motivated to finish her is that after I got all the walnut planking done, I eventually decided I didn't much like the look of it -- both the dark wood and my not-especially-good planking job. Turns out I like models done in lighter woods better. Oh, well -- live and learn. I may finish her off as a hull model -- someday. The financially prudent part of me doesn't want to let a $300 kit go unfinished, but my modeler's heart knows that I won't be entirely happy with the finished product.
Great job, Harry! Nice presentation, too. Cheers!
- 29 replies
- maltese fishing boat
- fulgaro
