ccoyle
Moderators
Everything posted by ccoyle
  1. Oops! I missed that detail in her description. Either way, she will require a large display area!
  2. Excellent! I was hoping that we'd have a chance to see her on the water. She really was making quite the headway in a breeze that barely rippled the water!
  3. E6000 is a family of industrial strength craft glues based on a tetrachloroethene solvent, i.e. not water-based. We usually have a tube of it somewhere around the house. Should be available at your local hardware or crafting store.
  4. Welcome, Mike! I hope you will enjoy your time here. Cheers!
  5. Catching up on your log, G.L. What an outstanding model! It is a testament to the fact that the model builder's art can be as much in evidence in a "small"craft as in any 1st-rate man-of-war. Cheers!
  6. Moin, moin! Welcome to our group!
  7. Wyoming was a 6-masted schooner. https://en.wikipedia.org/wiki/Wyoming_(schooner) That will certainly make an impressive model!
  8. Welcome, Phill! Looks like you have already found all, or at least most of, the resources you will need to make a good first go at this great hobby. I look forward to seeing your build log in the new year!
  9. Popeye, you are a master of understatement! 😉
  10. Fabulous! The model in its case should be required viewing for beginners as an example of how large a display area a finished model can require, even at a "small" scale such as 1/80.
  11. Welcome! Paper is a fine modeling medium, and we have a few members who dabble in it.
  12. With one post, Bob has outed me as a lubber! 😝
  13. Niagara will have many of the same issues as Fair American regarding age of kit design, materials, instructions, etc. Still makes a fine model in the hands of a competent builder, but as Bob has pointed out, its design is not on par with that of Syren.
  14. It is a spar to which the foot of a jib sail is bent. If you are working from a sail plan, it should show up there. You can also find images by googling the term.
  15. According to documentation provided at this site, Terror's bulwarks were painted yellow. The exact shade is not described, but the Admiralty must have had some sort of standardized color scheme for vessels of that type and period.
  16. If you can afford a small rotary tool, such as a Dremel, I highly recommend one. A pin vise gives you very precise control when needed, but for repetitive drilling tasks, such as drilling pilot holes for pins, a rotary tool is very nice to have on hand. And of course a rotary tool can be used for a variety of other work as well -- I have even used mine for some household fix-it tasks.
  17. This is coming along handsomely.
  18. What you have done so far looks very good.
  19. Welcome! "First kit" depends in part on what interests you. Browse through the build logs or use the search function to find logs with the words "first build" in the title -- that will give you an idea of what other newbies are working on. Enjoy the search -- it's part of the fun! Cheers!
  20. For the most part, yes. Most kits, if not all of them, come with the necessary parts to build the kit straight out of the box. With experience, you'll gain insight into what extras you may need or want to add in order to enhance or super-detail a kit.
  21. Well, that depends! The first question is, did you read this post here? If you did, you'll note that it isn't impossible for beginners to build kits like the ones you listed, but it is challenging. If you are interested in warships in general, you might wish to consider something with less, i.e. less planking, less guns, and less rigging. Brigs and cutters fit this bill nicely, and there are many great new kits of such vessels now on the market. But -- if you do decide to try one of the kits that you linked to, I would first of all avoid Artesania Latina, mainly because the word on the street is that they have gone out of business, which -- if true -- means that their customer support will be non-existent, should you need it. The choice between OcCre and Model Shipways (MS) largely depends on what you expect from a kit. MS kits generally have far fewer pre-cut elements in them, and a kit like Rattlesnake will assume that the builder has some previous experience. OcCre kits get a lot of positive reviews, and we have reviewed the Beagle kit here at MSW. Hope this helps a bit!
  22. Gary, I think that I will just have you build all my models for me now.
  23. Eric, try using a little white glue, diluted slightly with water, and allow it to soak into the knot; let it dry thoroughly before putting any tension on the knot. Fabric stores sell a glue specifically for this purpose, but I don't remember what it's called.
