Everything posted by ccoyle
I, too, did not use most of the PE eyebolts that came in my MK gunboat kit. That's one item, IMO, that does not add much, if any, value to the kit. I use blackened, annealed wire to make mine, and it is simply so much quicker and easier to make them from scratch than to cut the tiny PE versions from a fret, file them to shape, and then blacken them. Plus, the wire ones are easier to set into the pilot hole.
- 275 replies
- phoenix
- master korabel
Welcome aboard! I built model rockets back in my youth. After each successful launch, I would paint a ring around the rocket's nose. The most rings any rocket ever received was five -- usually they met some sad (but often memorable) end before then. Cheers!
Here. Cheers!
Well, yes and no. I agree with YT that the profile formers didn't receive enough shaping. To sand those bent portions round, you'll need to remove a significant amount of wood, which will weaken the first layer at the point of attachment. The second layer can and does hide a multitude of planking sins, but I think it's a good idea to get the shape more or less correct with the first layer. I'll be interested to see how this works out going forward! Cheers!
I agree with Druxey. To my knowledge, there are no kits of any of those subjects. You are blazing a new trail, friend!
You have my sympathy, Peter -- coping with dementia is definitely a challenge, and not one of the fun variety.
Welcome aboard!
Hmm. I seem to recall that at one point this kit was a solid-hull project. Good luck on your build!
- 83 replies
- finished
- billing boats
Launch day for the Falmouth Pilot Cutter is coming up soon
ccoyle replied to Chuck's topic in Nautical/Naval History
Indeed. I also suggested to Chris Watton (hint, hint) years ago that the schooner yacht Coronet, currently undergoing restoration, would make a swell kit subject. -
Good intro, Jeff. Trying to make one of these old kits conform to the dimensions of a known vessel can be a real challenge. It's quite possible that the model is not based on any actual vessel or plans, and it is probably made in what is known as a "box scale", i.e. the model is scaled to fit in a particular-sized box, not the other way around. There is also no harm in just going with the fact that the model represents a type of craft and not any particular vessel; I did this with my first POB kit, Model Shipways' Katy of Norfolk. When I learned that Katy was the name of the designer's wife, I simply chose to have "Virginia-Built Pilot Schooner" put on the plaque. Anyways, carry on!
- 5 replies
- Fishing Schooner
- Constructo
Welcome aboard! I look forward to seeing your projects. Cheers!
One of the things we try to feature regularly at the MSW Facebook page is build logs that showcase noteworthy builds or particular skill sets. Your build tics both of those of those boxes. And the post drew extra sets of eyeballs to your content, which is of course one of the reasons why we make such posts. Cheers!
I haven't yet been able to get back to my build of MK's gunboat, but it is an excellent kit in all respects. Based on what we have seen in other Phoenix build logs, I think you will get a lot of pleasure out of this project. Cheers!
- 275 replies
- phoenix
- master korabel
I hope we will be seeing a full kit unboxing and review here at MSW (hint, hint)? 😉
- 216 replies
- masterkorabel
- ships
(and 3 more)
Welcome! Those are some nice models. Please do start a build log in the kits section when you are ready to start, and don't worry about language errors. Cheers!
Goodness, Greg! At the rate you work, I may be able to tag this build as finished later this afternoon!
- 45 replies
- orp ślązak
- mirage hobby
