russ
Members-
Everything posted by russ
Your rigging is coming along well. Very nice work. Russ
- 153 replies
- constitution
- revell
The number 11 blade is the very basic triangular shaped blade with the point on the end. Russ
Very nice bit of rigging there. Good work.
- 246 replies
- revell
- constitution
Andy: The braces look good. Everything appears to be suitably taut without anything pulled out of line. Russ
- 246 replies
- revell
- constitution
Your rigging looks like it is coming along fine. Nice work. Russ
- 153 replies
- constitution
- revell
Andy: Looking very good. Great work. Not long now. Russ
- 246 replies
- revell
- constitution
The stern timbers look great. That seems to be just how Hahn showed them in his book. Russ
I would not use CA on wood, but some folks do. It is just super glue. It can be used if you want to get a much quicker bond or you cannot get a clamp on a joint where youa re using wood glue. Personally, I like Elmer's carpenter's glue, but others have their favorites as well. If you use wood glue, make sure to have a damp rag close at hand to wipe away any squeeze out. This will make finishing a lot easier. CA needs to be applied carefully because if it soaks into the wood, you will have a tough time with any stain or clear finishes. There could blotches where the CA has dried into the wood. This is a general statement and there may be exceptions depending on what finish you choose. If you are painting over the surface, then it will not matter as much. Russ
Bob: My only thought is that you left A LOT of wood on that frame. I was thinking about maybe an extra 1/32" on both inside and outside. That will be enough for fairing purposes and it will make it easier on you doing it by hand. The frame looks good though. Nice work. I envy you doing this by hand. Russ
The blocks and shackles look very good. Great work. Russ
- 2,215 replies
